#26 | |
Re: touchy gas pedal
I made myself a bracket today from some aluminum I had laying around the shed. I found a air cleaner spacer/riser at the local auto shop and that brought the bottom of it up enough that I could fit some more metal in there. Now the pedal is a little too easy to push so I'm thinking a tougher return spring and everything will be fine again. But the pedal travel to rev ratio is way better. ![]() ![]() ![]() I also got a cover for one of the kegs. I'll have to look around some more to find another one. Might just keep it like that until I can fix it the right way. ![]()
#27 |
It seems the pedal side might be a bit short as well. The linkage rod should be almost level.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
