touchy gas pedal
Hey everyone, I've been on this forum for a few years but never really got involved until now. I just bought a 67 the day before Halloween. It's super rusty, loud, very unapologetic, and in your face. It's got a truck load of problems but seems to run fine mechanically. it has a cammed 350, 4 speed, 750 carb, and kegs for fuel tanks...
![]() One thing I need to fix while I wait for the tags would be the gas pedal. I drove it a half mile up the road to the notary and couldn't stop bucking from the pedal being too sensitive. It seems like it's set up to be mashed to the floor at all times. Plus the springs are cut so it's like riding in a bouncy castle. I was just wondering if anyone else has come across this issue before. I thought about changing the length of the bracket on the carb or maybe changing the springs on the carb to softer ones. I found tons of stuff online about this but nothing for an old rusty truck. Mostly just new stuff. So anyway, any help at all is much appreciated! Chris
Re: touchy gas pedal
Have you looked at your throttle linkage? 67-70s had a solid rod linkage to the carb, and it might have been butchered when the carb was swapped.
My 69 acted like that when I got it. When the PO installed the Edelbrock carb, he tossed the linkage from pedal to the carb. He installed a throttle cable bracket, and cut off a throttle cable and just looped it through the pedal and crimped it together. Combined with 2 return springs and it was touchy. I replaced the whole mess with a proper pedal and cable. I used this thread for inspiration, but different parts: http://67-72chevytrucks.com/vboard/s...00#post1383300 |
On my 69, the carb has more than one hole for the throttle rod. You can move the rod to different holes to get a different response. See the picture:
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
WOW REALLY , You need a spring on it from linkage to front of engine
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
![]() Join Date: Sep 2007
if you could post pics that would help immensly. if any parts are needed im sure the guys here or myself have what you need.
also if you wanna get rid of those kegs id be interested
1967custom |
Restoring it $200 at a time...
Something else to check would be how freely the accelerator piston moves in the bore. My Buick's AFB acted this way - moving from a 3/4" pump to 11/16" helped immensely. I really think that the apron was just too tight and wouldn't start to move gradually. It was either on or off.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society '68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327. DD '09 Pilot Weekender '65 Skylark 300-4V-4 speed Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine. Son's '04 F250 SuperCab 6.0 |
#7 | |||||
Thanks so much for the feedback! Forums like this are so awesome! ![]()
![]() Join Date: May 2016
Mine was bouncy to. The shocks were totally shot. I could push them in and out with no effort.
#9 | ||
"I ain't nobody, dork."
Sounds like its just an old truck...
Welcome to the world of 40+ year old rigs. ![]() Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#10 | |
Goes with the huge steering wheel right in your chest, wind up windows, and lousy gas mileage. Great eh!
![]() Join Date: Oct 2011
...it sounds like a blast.
I've got to add a few performance mods and some internal upgrades to get a touchy pedal...lol. enjoy it. Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
That's what I was thinking. Mine is touchy too. Could be the gobs of torque and that low first gear with 4.10's. Tires chirp, people gawk, engine grunts and off I go.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#13 |
blood type; Retumbo
good thing you don't have a Caddy 500 in there.
Are you used to driving old stuff without electric throttle? Serious question. I hate drive-by-wire due to soggy throttle. May just be a learning curve
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
#14 | |
I've driven plenty of carbed things with cables. Can't say the same for rod linkage though. And I guess I don't know what I've driven with drive by wire. I like to stay away from new stuff as much as I can. I'm sure this truck will take some getting used to, but I'd like to be able to take off from a start nice and slow or even drive slowly/cruise around and not launch it one car length at a time in traffic.
#15 | ||
If the 4 speed is a "granny low" 4 speed. Don't take off in 1st gear (granny). Take off in 2nd and only use 1st if your pulling or hauling. That will alleviate the bucking and short shifting.
The shift knob might even be labeled L-1-2-3-R. At least the knobs in my 1967 and the 1979 I had were labeled that way. These transmissions should be called 3-speeds with a pulling gear. Gary
#16 | |
#17 | ||
having an extra long shift lever doesn't help.
![]() Gary
#18 |
![]() ....but it's all the rage right now....lol, 5' long shifter handles scrapping the roof inside the cab. All Good Coley
#19 |
Ha. Yeah I took the beer tap handle off and put on a grenade I had laying around. Some folks at work said it could have been real at one point too... At least I'll be able to grenade the trans whenever I want!
#20 |
![]() ![]() ![]() Here's some of the pictures I promised a few days ago.
#21 |
I cannot see the pics. Just says click for more photo's.
#22 |
![]() Last edited by kingchris401; 11-11-2016 at 09:55 AM. |
#23 |
I think you have about an hour or so to edit posts.
There is a small kit you can buy to use the larger top hole. Your linkage is too close to the center pivot. By the way-GM switched to the cable style throttle linkage due to the danger of the engine mounts breaking and the engine moving to the side and then the accelerator would throttle up the engine to full throttle whether you like it or not. This does not happen with the cable. They made a kit with cables to tether the engine to the frame for a quick fix. It only works with stock exhaust manifolds unless you modify it. More pics of truck and engine please!
#24 | |
I'm finding out more and more that this thing is rusted out like crazy... ![]() ![]() ![]() ![]()
#25 |
Probably find one on Summit's website or Holley. A lot of these trucks are real rusted. I see what some of us go thru bringing them back from the dead and I realize I am a lucky man. You may be too. Thing is do you want to fix it or drive it? If you fix it it will most likely be years if ever before it's done. Some of us do it faster but time and money and a place to do it sometimes makes us sell them instead. Sad to see them go on more than one occasion.
