#26 |
Re: Factory 327 engine
Paint on the main caps and they have been numbered with a punch...absolutely a rebuild. Grinding on the crank was not done by GM...
#27 | ||
![]() Join Date: Mar 2015
If I decide to use it I will have it checked out.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD 1966 GMC Long Step 1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6 1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435 1960 GMC Custom 1968 GMC 3/4 ton 4x4 Short Bed 1962 K20 Tow truck 1961 GMC Extended Suburban Panel and a few more |
#28 | |
Maybe the engine had a vibration and they pulled the crank and tried to re-balance it? I would not have thought GM would grind on a crank. We have another original 327 we will take apart in a couple weeks. It will be interesting to compare the two.
#29 |
I agree, they would have milled into the balance weights till it was even (true)
#30 |
![]() ![]() Join Date: Apr 2012
Been reading this thread , They DID paint the main caps and number them from the factory , those are assembly paint inspection markings to signify the steps were done and checked. I have a brand new NOS 327 crank I will dig out , some of the cranks even had paint markings as did rods. Perhaps Keith Seymore could explain it better. Also , this crank is NOT knife edged , that was done only in extreme racing situations and does not at all look like it was done here. I worked in an automotive machine shop for 20 years and ran the crank grinder in that shop everyday. Your crank is stock. The only explanation I can give here for the unusual looking milling is it was done to correct the balance . Clean it up , check everything, balance, clearance and re use it. If you bore the block you need to balance it anyway.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
#31 |
I too have been following this thread (very interesting).
I worked in a chevy dealership back in those days but that by no means makes me an expert. I never knew of a 327 being in an original truck until 1966, but like I said , I could be wrong. What is the date code on the block? What numbers are on the stamping pad? Just curious !! Ken |
#32 | |
Main caps numbered with a punch by hand from GM? I haven't seen that. And some of the bolt heads are also damaged (and maybe some rod bolt nuts flipped?). IME the engines I've taken apart that had not been messed with did not look like this. Why are we certain the heads haven't been off before? Steel shim gaskets? I just rebuilt two engines recently and used them on both. I'm up for learning something, but I'll be surprised if this wasn't a rebuild of some sort. |
#33 | ||
I didn't and don't see "punch marks" I see a number stamp , 2 , on the second main cap , that could be factory.
#34 |
#35 | ||
The numbers on the pad are F0310U Looks like the same stamping's.
#36 |
Heres another 327 crank with the first counter weight milled off similar to yours . Notice yours is drilled twice for balancing in the same area plus milled on that side. I really feel it was all done to correct the balance on that engine. The crudeness is unusual looking with the burnt look , possibly done with worn tooling at that moment or in haste.
#37 |
Hey 60-66, just curious if those 327 cranks you have are large or small journal?
-Brad (Sorry to hijack the thread)
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
#38 |
Hi Brad. Both shown are small journal . I do have a large journal also.
#39 |
Thanks for the pictures. It does look similar.
#40 |
Moderator
![]() Join Date: Dec 2012
I feel bad for providing misinformation
#41 |
Don't feel bad. I created this thread to see what people thought about this crank. We are all learning here.
#42 |
I'm figuring the "2" on the main cap is a mark someone put there when they took it apart to mark it as the #2 main cap. Considering everything as a whole, I'd guess it's been apart before...just kind of looks like it IMO/IME. Pictures could be misleading, though.
As was said, pull some bearings and see if they are original...I'm curious. |
#43 | |
#44 |
I learned something from this thread about the 327 truck engines being installed in the larger trucks before 1966.
(never too old to learn !!) Thanks everyone Ken |
#45 |
Were there ever any cast 327 cranks made in either large or small journal? Ive had several 327s years ago and can't recall any having other than a forged crank.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
#46 |
![]() Join Date: Jul 2014
Pretty sure 67 and older were small journal forged, 68 and up not steel they were cast. Large journal , I know in the cars for sure. Trucks?
#47 |
1962-1967 Car are small journal 327s . 1967 truck started the use of a large journal crank, usually forged and cars had the cast version from 1968 1969. 1967 Camaros with a 350 had a large journal crank also.
#48 |
Moderator
So my 65 Impala 327 is small journal forged, correct?
#49 |
All small journal 327 cranks were forged. Most large journal 327 cranks were cast. The hi po 327 large journal cranks were still forged. I had one a few years back in my Nova.
