Old 12-11-2016, 11:25 PM   #1
Classic v6 GMC's
Classic v6 GMC's's Avatar
Factory 327 engine
Pulled our 63 327 apart today and found some interesting grind marks on the crank. Has anyone else seen marks like this?
The pan looked like it had never been removed. A bad casting at factory?
When we rebuilt our power-glide a few months ago it had some grind marks under the valve body and had been welded on the case by the band servo.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 12-11-2016, 11:30 PM   #2
Classic v6 GMC's
Re: Factory 327 engine
Pics
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 12-12-2016, 12:55 AM   #3
Captainfab
60-66 Nut
That is definitely a messed up looking crank. Maybe that was done to get the crank in balance specs? I don't think a '63 327 would have come with a double roller timing chain.
Old 12-12-2016, 07:20 AM   #4
luvbowties
luvbowties's Avatar
Question Re: Factory 327 engine
I 2nd ^^^^, plus I surely think it was done after it left the factory.
S
luvbowties is offline   Reply With Quote
Old 12-12-2016, 10:50 AM   #5
crossy
Oh,you can't buy that new
crossy's Avatar
pull the bearings on at least one rod & main. they will have a have a manufacture on them and a date. that will tell you if anyone has ben in there before. I just pulled apart a 63 SHP 327(it's on ebay now ) with no serial numbers on the front pad, and even though I know it was been where it was for the past 40+ years, I was told it was never apart yet I found the bearings were dated 75. Crossy
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 12-12-2016, 12:17 PM   #6
jayoldschool
Moderator
It's been apart previously. Your last photo shows a stamping on one of the counterweights.
jayoldschool is offline   Reply With Quote
Old 12-12-2016, 06:45 PM   #7
andyh1956
Just so you know that's a forged crank. You can tell by the wide parting line on the rod throw.
andyh1956 is offline   Reply With Quote
Old 12-12-2016, 08:30 PM   #8
Classic v6 GMC's
I was thinking the same thing.
Possibly or maybe for clearance.
I did not think it would have a roller chain either but the 63 data book shows that it would.
S
I would have thought so to but this engine still had most of the original paint intact.
I will next weekend. This engine is out of a original truck and it still had most of the original green paint so I don't think it has been apart.
The factory would not have stamped it? I will get the stamping and post them.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 12-12-2016, 08:33 PM   #9
Classic v6 GMC's
Yes already looked that up.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 12-12-2016, 09:07 PM   #10
jtrichard
Just so you know that's a forged crank. You can tell by the wide parting line on the rod throw .
Please explain "wide parting line"
jtrichard is offline   Reply With Quote
Old 12-12-2016, 09:44 PM   #11
Classic v6 GMC's
Here are some more pics.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 12-12-2016, 09:45 PM   #12
Classic v6 GMC's
And a few more
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 12-12-2016, 09:48 PM   #13
Classic v6 GMC's
One counter weight is stamped (2) 3 times
One is stamped 5
One is stamped 8
One is stamped G
Also one of the counter weights has a chalk check mark on it.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 12-12-2016, 09:56 PM   #14
LT1 Burb
LT1 Burb's Avatar
My powerglide case a weld on it too, about 1" long.
LT1 Burb is offline   Reply With Quote
Old 12-12-2016, 10:16 PM   #15
Classic v6 GMC's
Yes ours was about an 1" long as well. Might have been a common problem but seemed interesting.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 12-12-2016, 10:52 PM   #16
urmyboyblue
If you don't see what it was grinding against in the oil pan or block, chances are it was a crude attempt to remove metal for balancing. Pretty crude. Probably still usable but i would have the engine balanced if you rebuild it- and checked for cracks. Something got medieval on that crank!
urmyboyblue is offline   Reply With Quote
Old 12-12-2016, 11:25 PM   #17
Classic v6 GMC's
No grinding on the other parts just the crank so you are probably right. I will defiantly have it checked out.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 12-13-2016, 12:33 AM   #18
andyh1956
Lookit the second pic in post #11. The wide line on the rod throw that runs 12 oclock to 6 oclock that has the horizontal grind marks on it is the "Parting" line where the forge dies stamped the crank from it's billet. It looks to be 1/2" wide or so. Cast cranks have a very narrow & sharp parting line where the form is broke away from the crank. Cast & forged cranks will have a distinctly different tone when struck with a metallic object.
Old 12-13-2016, 01:18 AM   #19
jtrichard
"forged cranks will have a distinctly different tone when struck with a metallic object."
I knew that but all the hitting on my screen did NOT result in the tone that I am familiar with LOL
Did not know about the parting though
Old 12-13-2016, 01:21 AM   #20
ryanv70c10
All small journal 327 cranks were forged IIRC
ryanv70c10 is offline   Reply With Quote
Old 12-13-2016, 01:28 AM   #21
ryanv70c10
Factory small journal rods had 5/16" rod bolts. Those appear to be 3/8" from the pics. What size socket fits on the nut?
Old 12-13-2016, 01:43 AM   #22
crossy
crossy's Avatar
On the roughest part of the throws you will see the parting line as either 3/8" wide(forged) on very thin like 1/16"(cast)
98 Vortec project.
94,3500,6.5L 4L80
Old 12-13-2016, 02:23 AM   #23
Brad54
Brad54's Avatar
Some of those pictures almost look like the crank counterweights were "knife-edged," which is an old racer's trick to reduce windage as the crank goes through oil.
It's a lot more crude in places than I've ever seen before, but it definitely looks like it.
That first series of pics also looks like material was missing from the side of the counterweight, like it was a void in the casting, or metal flaked off.
If it balances (which seems hard to believe), and isn't cracked, there's no reason not to run it.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 12-13-2016, 09:12 AM   #24
gabbin
gabbin's Avatar
I think it would be a good idea to have a machine shop check the balance and for cracks. If it is ok run it, well, as long as it can be turned and cleaned up.
gabbin is offline   Reply With Quote
Old 12-13-2016, 02:01 PM   #25
andyh1956
HAHAHA! Hope you didn't hit it too hard & it's not your WIFE'S computer!
