#26 | |
Re: Things to avoid when buying a C10?
![]() Ah, okay. Great suggestion. |
#27 |
RUST is the deal killer for me. anything else is just part swapping. if it is rusted around windshield or if kick panel vent area is bad I would avoid it
#28 |
![]() Join Date: Jan 2001
I think it's more akin to passing off a SS clone as an original. As long as the seller is honest about what's been done, I don't see a problem with it.
#29 | |
![]() Join Date: Oct 2011
![]() Quote:
Although it seems like many sellers don't want to draw attention (if at all) to it being a modified/shortened long bed. If its done well, the seller doesn't have too much to fear except a bit of cost reduction relative to an original short bed....but its always best to be up front about it. However, the buyers (on the other side of the equation) might get spooked if they don't know the quality of the work done on such an important and valuable piece of the truck...the frame. C. ![]()
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
#30 |
Also, this should be factored in. If one does not have the three criteria listed below for restoration, stay away from any C10.
1. Time 2. Money 3. Patience |
#31 | |
#32 |
My intent was to learn about things to look for and avoid when buying a C10, and then there was some discussion about a long wheelbase being shortened to short.
Here's a list of all of the suggestions so far: Problems or facts to be aware of: A points distributor Play in the steering system Gas tank inside the cab Is the motor and trans rebuilt, or oily filthy dirty Wiring is chopped up? Take it for a ride and notice the handling and any sounds Look for rust in these areas: Floors, rockers, doors, cab, box, cab mounts, A pillars, roof, kick panel vent area, firewall, area around the master brake cyl, corners and bottoms of doors, door jams, tailgate bottom, wheel well edges, under the battery by the radiator support, frame rail the connecting points with all the cross rails, trailing arms, rockers, cab corners, cab floor on the inside and out, above/around the windshield, back window, dash area, and tarred (undercoated) underside hiding rust. LWB to SWB conversions: Look for cut and welded frames. Read the SPID (glove box label) 127 inches means it was originally a long bed. Positive items: 71 and 72 had front disk brakes standard C10 parts easily available. Other items: Have plenty of time, money, patience Thank you again to everyone who chimed in. That's a lot of collective experience! |
