Things to avoid when buying a C10?
Hello there! I am looking for a 67 to 72 SWB C10 to restore to be a daily driver. When looking at trucks, are there any problems specific to this generation of trucks that I should avoid? For example, are there some parts that are difficult, impossible, or really expensive to buy used or new?
Thanks! |
Re: Things to avoid when buying a C10?
Two things: these trucks were designed to rust, so be real careful with things like cab mounts, A pillars, the roof, and so on.
The other thing is that pretty well anything you'd ever want or need to restore or modify these trucks is available out there. If you want a truck to drive, I'd concentrate on the 71 and 72s, as they had disk brakes standard.
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
![]() Join Date: Jan 2001
Based on what I'm most comfortable with, I favor a solid body over mechanical considerations. Look really carefully for rust, especially if the truck has been repainted.
#4 | ||
Thanks to everyone who replied!
Good to know. I have seen more than one vehicle where a pretty paint job was hiding rust. Two years down the line the bubbles in the paint only mean one thing... |
Just remember, when you're adding up what you think it will cost to get your project rolling, take your final number and double it, especially if this is your first older vehicle.
I agree with the above - look carefully for rust and if you're handy with a wrench, these trucks are easy to work on, so a solid body makes more sense than anything else for your dollar (within reason). Also, since you're looking for a SWB, know that as they get rarer, more people are cutting down LWB trucks to drive or sell as SWB. Look for cut and welded frames. Good luck and have fun!
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED ![]() |
![]() Join Date: Feb 2009
The only problem on these trucks is a points distributor. Just kidding, sorta.
Good chance the steering has some play if it's original. I don't know much about it, but seems to me the steering box is the likely culprit. You can buy those or have what you've got restored. Other than rust as mentioned (e.g., window frame), disc brakes is a good one too.........I can't think of a real downside. Some prefer the gas tank be outside the cab ![]()
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#7 | |||
#8 | ||
"I ain't nobody, dork."
If you want a true original short bed... always check the frame just under the cab for welds where a long bed has been cut down to a short bed and welded back together. It's really common nowadays for a seller to claim a cut down long bed is an original short bed.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
![]() Join Date: Nov 2001
good ? to ask. I wish I gave more thought to that then when I bought my truck that I been into for all these past years. well this is me, I like both long bed and short but, I wanted a short bed. Funny how I keep finding shorts but they were far beyond what I wanted to repair. How's your skills, time and allowance? I'm more mechanical and the help of friends, then there's body work but I'll give it a shot when the time comes and also with the help of friends.Then there's money, parts, equipment needed, a place to do your thing and alot can be done in a driveway, yard, and with the help of good site's like this one. What you don't know you can learn. I liked my truck as soon I seen it and, I over looked what was under the paint. I would avoid anything overly tarred (undercoated) If I would have seen the coming out of rust that was hiding, which is now showing through. The paint was aged but looked good and over time things started showing up.
Know what you want, a truck that's completely done, nothing to do just drive and general maintenance or a project. Avoid rust, and poor repairs in the rockers, cab corners, cab floor on the inside and out above and around the windshield same with the back window, look at the firewall, area around the master brake cyl , corners and bottoms of doors, door jams up, down all around, tailgate bottom , wheel well edges in out all around , under the battery by the radiator support , frame rail the connecting points with all the cross rails, trailing arms. Is the motor and trans rebuilt or oily filthy dirty . how the wire's in the engine compartment under the dash or anywhere underneath the truck, is it all chopped up? Take it for a ride, does it handle good listen for sounds how's the shocks, what work been done to all and anything. Hope I stayed on topic, I'm sure more will chime in, this is a great site for info. Also, all that was said already is great advice. But,,, them 67-70 with good proper drum brakes are not bad either and a little better with the power brake set up. Nick Last edited by NGN; 01-16-2017 at 12:12 PM. |
#10 | |
I suppose the most obvious sign of shortening would be the frame. |
That's a long list of stuff to check, but probably worth doing before handing over a bunch of money. I think people get caught up in the excitement of wanting a new vehicle and might tend to rush an inspection and cut corners. Then as the weeks or months pass, you end up discovering a bunch of problems. How many projects started off with basic goals but turned into a more lengthy and expensive batch of work because more problems became apparent?
Yeah that's what I wanted to say. LOL
Nick |
#13 |
![]() Join Date: Oct 2011
In my opinion...there are 3 things to avoid with these trucks when you are getting your first truck
1) Rust in the cab or the box 2) A cab with rust or a box with rust 3) A rusty box or a rusty cab. ....after that, I think it gets easier....and perhaps cheaper....lol. ![]() Seriously tho'...a lot of this will depend as much on you as the truck you might choose. In other words...where are your skills at? what level is your work space and your tool group at? do you have a spouse/wife and are they on board with this?....and very importantly...what is your '1st year' budget and what would you like your first 3-6 months of truck ownership to look like? These will have a great bearing on the type of advice that might be useful. ![]() all good Coley ![]()
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
#14 | |
Honestly, I don't know how to properly deal with a box with a heavily rusted floor. Can one get new just replacement floor bottom? I can see the risk of replacing the bottom of a truck box is that the thing could get out-of-square pretty quick. It would have to be braced with cross braces temporarily while the bottom was removed. As far as working space, it will be tight. I will have to get my wife to give up her half of the (2 car) garage if I remove the body parts from the frame. This would motivate me to work more quickly and get the body back on. I would build a paint booth inside the garage if I had to paint the thing. Tool-wise, I have many tools for body work and general mechanical work. Budget-wise, I would commit to a bunch of cash expenses to see the project through, expecting to spend more than what I initially figured. |
#15 | |||
Everything else will just look like a normal short bed. Gary
#16 |
Its interesting about watching for and checking for 'shortened' long beds that been cut down.
A lot of guys have done this...and are doing it all the time and probably want relatively big money for the net result of their work. This begs the question....does this modification devalue the truck?...and based on some of the feedback so far....it might. ![]() Coley ![]()
#17 |
If it's done well, what's the issue? It's a way to bargain if you can spot it, but how much less is it worth really? Is it like finding someone passing off a 307 Malibu for a 350 SS?
1982 K10 SWB 1987 V20 - Sold - Doh! |
#18 | |
#19 |
![]() Join Date: May 2007
Most every one of these trucks by now have rust in the floors, rockers, and doors know that going in. Stay away from rust in the roof, windshield, and dash areas. Most everything is available for these trucks as reproduction parts. Happy Hunting
#20 |
Keepin an eye out
I myself would avoid long beds made into short beds... especially if youre paying decent money.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
#21 | |
#22 |
The other thing I'm running into, and it's really a whole different topic, is the issue of buying a truck needing work versus buying a truck that's already been fixed up. I believe you never generally get your money out of these projects, so do I spend $4K on a truck and put $11K in it, or just buy a completed one for $15K. It's difficult to answer because every truck has differences. Like I said, it's really a different debate, not part of this thread.
#23 |
#24 | |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
http://www.ebay.com/itm/292001361114...%3AMEBIDX%3AIT
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#25 |
![]() Join Date: Oct 2016
I guess looking at the wheel base on the SPID, glove box label, is the most obvious. 127 inches means it was originally a long bed. Then ask yourself if it matters.
72 White Cheyenne, The Ghost |
