Old 02-13-2017, 04:48 PM   #26
67ChevyRedneck
67ChevyRedneck's Avatar
Re: Door glass not sealing
Originally Posted by dme922 View Post
Here is a pic with the original glass on top of the new. It is a bit different in that corner.
Son of a... my plans were to replace all my glass with factory "green tint" glass. How hard is it to cut a flat piece of glass to match another? Sheesh.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-13-2017, 04:51 PM   #27
dme922
dme922's Avatar
I called a local glass place and they said they could cut it out of laminated glass if i had a template. The glass i had trouble with came from LMC but i went ahead and ordered oer brand glass today. Ill let you know if it fits better.
dme922 is offline   Reply With Quote
Old 02-21-2017, 12:17 PM   #28
LockDoc
The Older Generation
LockDoc's Avatar
Originally Posted by Hart_Rod View Post
LockDoc - I took a picture of my doors (they are aftermarket doors). Is this the tab you were talking about?
Wow, I forgot about this thread Rob. Yes that is the tab. Here is a thread I posted some pictures in...
http://67-72chevytrucks.com/vboard/s...d.php?t=633866
Here is a picture of the "J" clip with the measurements also.
LockDoc
Leon
Old 02-21-2017, 01:12 PM   #29
Hart_Rod
Hart_Rod's Avatar
LockDoc
Thanks Leon!
Hart_Rod is offline   Reply With Quote
Old 02-21-2017, 11:17 PM   #30
dme922
dme922's Avatar
I got my new oer door glass and installed the drivers side today. The glass is much closer to the original but i am still lacking a little from the top of the glass going up against the door run seal. It is up in the run but not compressed at the top. Is this common?
Old 02-22-2017, 09:56 PM   #31
dme922
dme922's Avatar
Talk to me guys
Old 02-22-2017, 10:00 PM   #32
LockDoc
LockDoc's Avatar
Talk to me guys
Without actually being there it is really hard to say what is going on. I guess I would just replace the regulator and see what that does.
LockDoc
Leon
Old 02-22-2017, 10:03 PM   #33
dme922
dme922's Avatar
I was just wondering if the top of the glass is suppose to press against the run channel seal
Old 02-22-2017, 10:39 PM   #34
67ChevyRedneck
Lightbulb Re: Door glass not sealing
My doors are new
This. My guess is the door itself isn't formed correctly?
Jesse James
Project "On a Dime"
Old 02-22-2017, 10:53 PM   #35
LockDoc
LockDoc's Avatar
Yes, the glass should fit tight at the top.
This could be a real possibility. What does the gap look like around the outside of the door to body? I am fighting this on my '72 Dually right now....
LockDoc
Leon
Old 02-22-2017, 11:41 PM   #36
randy500
LockDoc
LocDoc, reform the frame of the door to match the cab using a 3 foot 4x4 as a hammer. It moves around quite easily. Use a small 2x spacer so when you hit the frame you are wood on wood to the non lip part of the frame.
There is plenty of depth in the glass channel for it to seal the glass after reshaping.
randy500 is offline   Reply With Quote
Old 02-22-2017, 11:47 PM   #37
randy500
I figured you would see the similar post on this same issue where I explained your problem. The upper glass run channel that extends from top to back then inside the channel inside the door is not seated at the transition from the channel to the door.
To confirm this remove the glass run channel from inside the door, just unbolt it at both places and slide it down a bit. Your window will then roll all the way up into the top of the door confirming the problem. Then when you reinstall the channel make sure at the transition to the door the run channel is fully seated. Problem solved.
You didn't need new glass. The overall shape of the glass is not all that critical since the channel is so deep.
Old 02-23-2017, 11:24 AM   #38
LockDoc
LockDoc's Avatar
I have reformed everything on this door. Believe it or not I have been building these trucks since 2004 and this is the first aftermarket door I have ever worked with. It will also be the last.... The only reason I have it is because it was on the truck when I got it. I have finally figured out that part of the problem is that the holes for the door latch are punched in the wrong place.
If the glass doesn't seal at the top you will get wind noise, It doesn't matter how deep the channel is.
LockDoc
Leon
Old 02-23-2017, 09:30 PM   #39
dme922
dme922's Avatar
The glass i got from LMC was off dimension quite a bit but the glass from oer is very close to the same as original. I am only lacking a 1/16 to 1/8 from the glass sealing at the top. My doors are aftermarket so this may be my issue.
Old 02-24-2017, 12:03 PM   #40
67ChevyRedneck
Can you take a pic of what you're referring to.
The channel at the top of the door is pretty "deep" Are you saying when the window is up there's an actual open gap between the glass and seal?
Jesse James
Project "On a Dime"
Old 02-25-2017, 12:53 PM   #41
dme922
dme922's Avatar
Yes. Its going up in there but not compressing against the seal.
Old 02-25-2017, 02:53 PM   #42
randy500
Take out that back weather-strip channel at the back of the door then roll it up and post back. I'm sure the top to back run weatherstrip is not seated inside the door and the glass is binding at that point.
Old 04-10-2017, 08:40 AM   #43
Hart_Rod
Hart_Rod's Avatar
Did you figure it out?
Old 04-10-2017, 08:51 PM   #44
dme922
dme922's Avatar
I sent back the LMC glass and got the oer glass. They were much closer to original and are sealing.
Old 04-11-2017, 03:51 PM   #45
joewell80
I'm having the same problem, my window will not roll all the way up. After a lot of frustration, I figured out that the metal frame going around the top of my new aftermarket door, is not formed correctly. I plan on removing it and welding the old door frame back on.
joewell80 is offline   Reply With Quote
