Door glass not sealing
I put all new glass and felt in my doors and my windows are lacking about 1/8 to a 1/4 of an inch from sealing at the top. I already checked to see if the window frame was hitting the fuzzies/anti rattle seals and it is clearing just fine. Any suggestions?
Re: Door glass not sealing
I got my new glass to and it is quite a bit thinner than the original glass. I have not installed any of it yet. I'm going to follow this thread
There is a metal tab right where the vent windows attach ( holds both halves of the door together) these tabs often break or rust through allowing the door to separate in this area that's why only '72 trucks have the dimple/screw to hold these areas together. Here's a picture. I tried to find a picture showing the tab but haven't found one just yet. This is probably the issue your having.
Ben ![]()
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time" ![]() “Serious Black” my 1971 Short Bed Fleetside Sold to an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten” |
My doors are new but i appreaciate the help. Any other ideas??
#5 | |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#6 | |
The Older Generation
LockDoc
Rob, You would have to weld a tab to the inside of the outside door skin for the screw to tap into.
LockDoc
#8 | |
Thanks Doc. Would you happen to have a picture of the tab?
I used the original regulators. I measured both the old and new glass and they measure the same. Is it common for the glass channel to come above the anti rattle felt?
Not above, but should be close. Can you post pictures?
I will tomorrow. If the felt that goes in the door channel was a bit thicker it would be fine. I used repops which a lot of people seem to like.
Just another note to add my original doors had some metal clips in the door channel under the felt. What were they for
#13 |
I know I took one and posted it at one time but I can't find it on here and I can't find it on my computer. I will take another tomorrow if I still have a stripped '72 door out there.
LockDoc
#14 |
I have the metal clips but i did not know what purpose they served
#15 | |
LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 02-07-2017 at 11:22 PM. |
#16 |
2WD Jimmy
![]() Join Date: Mar 2005
FWIW... I had replacement glass for my doors that was reproduction and when I layed it over my original glass, the repop glass was about 1/8 to 1/4" smaller at the top rear quarter. I ended up searching out OEM new old stock to solve that problem.
#17 |
Thanks. I am taking the glass out today. How hard was it to find new oem glass?
#18 |
![]() Join Date: Jul 2016
Used glass should be easy to find, post want to buy in the parts section. The glass may not be going all the way up due to the run channel on the top back and inside the door. There is a small angle transition on the back inside door run channel and sometimes its not all the way pushed into the channel, this is just below the window opening inside the door at the rear.
#19 |
Here is a pic with the original glass on top of the new. It is a bit different in that corner.
#20 |
Could i get some pics of how your glass is set in the sash channell? I would like to compare to the placement of mine.
#21 |
2WD Jimmy
[QUOTHere is a pic with the original glass on top of the new. It is a bit different in that corner.[/QUOTE]
That is exactly what I am talking about. Call Wes at Classic Heart beat.He can help you. http://www.classicheartbeat.com/years.htm |
#22 |
Thanks. Where did you buy the one you had trouble with?
#23 |
LockDoc - I took a picture of my doors (they are aftermarket doors). Is this the tab you were talking about?
#24 |
2WD Jimmy
#25 |
Was the glass you got from Wes made by oer?
