#26 | |
Re: engine selection help
#27 | |
"An LS swap is the best! It's easy! Buy a donor truck!" I won't argue those claims, but I have a few good stories that can illustrate how a few simple, wrong decisions can make the statements untrue. The Ogre solution, though it costs more, is the closest to plug-n-play. The late model donor option, although it carries a bunch of cool factor, also comes with substantially more work. Last edited by 1project2many; 03-08-2017 at 09:53 AM. |
#28 |
check out the ramjet engine if you want the older small block configuration. it is a plug and play fuel injected engine. you still need some accesories though. if you have a small block in the truck you likely have what you need. I don't know the price but compared to a carbed engine i would do this option first if going smaal block.
there is also the ls crate engine supplied with controller so it is almost a plug and play. I am a mechanic so maybe the wiring is easier for me than most but, really, carbed stuff is not on my list anymore. neither is something with no cats. really starting to hate that old unburned fuel smell out the pipes and all the tuning issues. even when I get behind a carbed car on the highway, I will pass it just because of the smell inside my car from their exhaust. injection is way more maintenance free from my point of view. new vehicles are rated for over 100k before even changing the spark plugs. no more distributor issues etc etc.I get it, some guys grew up around carbs and to them they are easier because they know a bit about them. for me, I will go injection and be driving my car while the others are tinkering and spending money on tune up parts and hans cleaner. just me talking. make up your own mind, but be aware of the costs and time before you pull the trigger and what you will end up with in the end. go to a few rod and tune shops and ask questions. get some estimates to install both styles of engines into your truck. the detailed list will give you some insight into what you will need. |
#29 | |
...on Speedbumpauto's post...that's about right for cost. Were I to do it again, I would do something like Ogre's & dsraven's suggested ramjet solutions (efficient & cool looking) or maybe another first gen SBC similar to the one I have (very happy). Unfortunately, I'm too old to get my head around the looks of LS engines (sorry)...but I do respect that they have a dedicated following here...
Pics of Finished 49 AD: https://www.flickr.com/photos/103194...7686536275403/ Pics of build process: https://www.flickr.com/photos/103194...57684031425944 Last edited by Hampshire; 03-09-2017 at 10:12 PM. |
#30 |
if you are stuck on a carbed engine they make the stuff for an LS engine to run a carb. if you change your mind it would be easily swapped back to injection.
just saying, one more option. |
#31 |
ive always liked the vortec swaps. as a mechanic they are such easy motors to work on. i personally am going with a early 90s TBI 350, just cause i already have the motor laying around
#32 |
Have you considered an LM7 with a carb? MSD makes a stand alone ignition system for these engines. There's a ton of them around and they make good power. You can adapt it to almost any transmission as well.
#33 |
Ok so here is the scenario ...I bought the truck 4/16 w a SB in it..Drove it every day til 11/16..pulled the front clip and bed off to work on what I would consider a prestine frame ...there is no rust or rot at all ...I consider myself extremely lucky that the frame and body are in excellent shape. So I want to bring the truck into the 21st century . 1) Im a hot rodder at heart and I do want the truck to "preform..2) the truck will be going to my grandson when its time so I want to upgrade everything .
With help , I /we just completed a total brake upgrade front disc , rear drum , firewall mounted booster etc . As you all know once you get started on something like this its hard to stop .. I will peck away at the stuff I can handle , rustproffing the frame, sound proofing ,but will be saving up for the motor ,trans wiring,gas tank, wheels and tires etc... So whatever motor I decide on will probably be new I really appreciate all the help I get here ,,,as ive said before , I am not a mechanic , but I have found one that will let me do the work while he looks on ...which is great!!!! I post my progress and you can bet I will be asking questions Thank you all !!!!! |
#34 |
if you have all the stuff for a sbc then I would really consider keeping that scenario, to keep costs down, but upgrading to fuel injection, which may cost a few bucks.the good is that all the mounts, manifolds, rad hoses etc will fit. you may have to fab up some throttle control and fuel tank pump stuff. mostly stuff a backyard mechanic could figure out.
check out the GM performance guys and see what comes with the crate engine, go from there. |
#35 |
OK, I've read all the posts so I'll chime in with my .02 worth. My truck came to me with a 283/327 convervsion and it ran like a scared rabbit. the owner took me for a drive and said, hold on and screeeeeeeeeeeech away went. Very impressive huh? So I trailered this beauty all the way from Georgia to Indiana and shortly thereafter I sold the 283. I had already purchased a Gen VI 454 with the intentions of putting that into the truck, and I did. Now, don't get me wrong, I'm all for the upgrades, late model EFI's, etc. if that's YOUR choice. I'm here to tell you dependability and reliability can also be from maintenace of what you have. Clean gas, clean filters, etc. So you can tell Im' over 55 I guess.
![]() 1940 Ford Dlx Coupe 1969 Mach1 Last edited by my56chevytruck; 03-12-2017 at 10:56 PM. |
