Old 03-10-2017, 12:17 AM   #26
nyncompute
nyncompute's Avatar
Re: Vintage Air Compressor install, I am lost...
Where did you get your alternator bracket?
Original to the truck
and are you running a vintage air compressor?
It is supplied with the kit but it basically is a Sanden SD-5 which is a very common light weight compressor ( not like the A6 boat anchor that was original to the truck
And is that the stock fan shroud?
Yes original 72 4x4 shroud?
What's your motor and water pump (short or long) type?
Original 350 short pump.. I also have a 4 core radiator and auxiliary electric fan helping the condenser. (the heat in Las Vegas is brutal)
1972 K-10 SWB Cheyenne
nyncompute is offline   Reply With Quote
Old 03-10-2017, 07:27 AM   #27
NC_John
NC_John's Avatar
Originally Posted by cleszkie View Post
I was able to keep my passenger side air vent functional, control rod and all. The VA unit does not snug all the way up to the kick panel. They do provide a molded plastic block-off plate to permanently close the vent, but I suspect that this is for use in factory AC trucks that have a vacuum controlled passenger vent door and no manual control rod like the non-AC trucks.
Mine clears too (non-AC cab). The right side kick panel vent is still functional.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 03-10-2017, 11:00 AM   #28
Oregon 1967 GMC
Oregon 1967 GMC's Avatar
Nice setup Nyncompute and thanks for all the info!
Hey man
67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603
Oregon 1967 GMC is offline   Reply With Quote
