Old 03-08-2017, 11:22 AM   #1
Oregon 1967 GMC
Oregon 1967 GMC's Avatar
Vintage Air Compressor install, I am lost...
I have already put on the evaporator and condenser on the front right with the lines coming out by the battery and the firewall plate etc. and want to go ahead and mount the compressor. I have a little bag of hardware from Vintage Air but no bracket? I installed power steering pump on the front lower left of engine. I've never done air before and have a non-ac truck.
Few questions:
1. Do or should I move alternator to the left side now and how is that accomplished?
2. How do I mount this huge and heavy compressor? Do I need to order a mount separately?
Hey man
67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603
Oregon 1967 GMC is offline   Reply With Quote
Old 03-08-2017, 11:32 AM   #2
Bigdav160
Bigdav160's Avatar
Re: Vintage Air Compressor install, I am lost...
The compressor doesn't care where it's mounted.
You current accessory mountings are not original to the truck so to use those you'll need a compressor mount for the drivers side. The down side to drivers side mounting is there is a lot of ugly hose around the engine compartment.
Camaro:
Truck:
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 03-08-2017, 11:33 AM   #3
72kool
72kool's Avatar
I have not installed an ac unit yet so I am not an expert for that system, but first what engine is it?
Looks like the stock 350 to me from the pictures. All the others I have seen, the alternator is mounted on the driver side and ac compressor mounted on the passenger side. Could you post a picture of what hardware you do have ? Be easier to tell what you may be missing
72kool is offline   Reply With Quote
Old 03-08-2017, 12:09 PM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
You should have absolutely gotten brackets if you purchased one of their "complete" kits.
I had to convert to a DS alternator mount. I bought one used from the forum. I would not go through the mess of putting the A/C on the DS, all of V/A stuff is set up for the PS unless you custom order it.
Check my build below:
http://www.67-72chevytrucks.com/vboa...d.php?t=249479
It's form 2006, so some things have changed, like how it comes out of the firewall and no more cables, it's all electronic now.
You also need to know if your truck has a long water pump or short (based on your pic it *appears* to be all short which is correct for these trucks, 73+ was "long")
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-08-2017, 12:14 PM   #5
Oregon 1967 GMC
It's a small block 400. This is the bag of hardware with some type of T-Handle?
Maybe I'm missing something?
Hey man
Old 03-08-2017, 12:24 PM   #6
67ChevyRedneck
I don't know how different a 400 is but there should be a couple bracket pieces and some spacers, it utilizes both head and exhaust bolts. What do your directions (I know blasphemy) say?
Jesse James
Project "On a Dime"
Old 03-08-2017, 12:52 PM   #7
Oregon 1967 GMC
I decided to look under the house one more time and DUH there it is. Thanks for the advice guys because I will have to relocate alternator to drivers side. I think I'm back on track. Will start by painting this bracket.
Hey man
Old 03-08-2017, 02:41 PM   #8
67ChevyRedneck
Good deal!
Jesse James
Project "On a Dime"
Old 03-08-2017, 03:09 PM   #9
Bigdav160
Bigdav160's Avatar
I think the brackets currently on your truck are "long water pump" brackets.
To swap over to a passenger side compressor you'll need a "short water pump" plus all different brackets and pulleys.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 03-08-2017, 03:53 PM   #10
67ChevyRedneck
That's what I was thinking, but I couldn't remember if that alternator bracket was 73+ only, but the power steering pump looks correct for a 68-72 SWP (looks just like mine?)?
Jesse James
Project "On a Dime"
Old 03-08-2017, 09:15 PM   #11
Oregon 1967 GMC
ahhh I hope you guys are wrong. Yes it is a long water pump. Everything lines up for now. Wow, so I'll have to get a "short water pump" plus all different brackets and pulleys, what a drag. Well where do I start? I would prefer new they can't be that expensive. Should I ask parts store for a certain year truck?
And by the way, what do you do with your pax side interior air vent with the air conditoning unit snug up against it. Take out the handle or just keep it closed?
Hey man
Old 03-08-2017, 09:52 PM   #12
sportside
here is a picture of mine. Same bracket, long water pump alternator on passenger side. You should be good to go. You may need to get a straight thermostat housing and new upper radiator hose. There should also be a block off plate included in the kit to remove the passenger side vent.
sportside is offline   Reply With Quote
Old 03-08-2017, 10:45 PM   #13
doc74021
CPP has an eBay store and they sell the brackets to swap the alternator to the driver side for 89 dollars. Then your compressor goes on passenger side and keeps all the hoses looking good.
doc74021 is offline   Reply With Quote
Old 03-09-2017, 09:17 AM   #14
Oregon 1967 GMC
Looks good, I like the big air cleaner, I think I'm going to switch alternator to other side because I have so much room on pax side for all the hoses.
Do I still have to get short water pump and new pulleys?
Hey man
Old 03-09-2017, 10:06 AM   #15
sportside
If you switch to the driver side alternator you will need to change pulleys and water pump as well as get the Correct vintage Air bracket. When I ordered my VA kit they asked for the location of the accessories and supplied the brackets for that particular setup. Personally I do not like the way mine looks. Also this mounting location limits your valve cover height to stock.
Old 03-09-2017, 10:17 AM   #16
Oregon 1967 GMC
Not to second guess anybody but I just talked to Vintage Air (Javier) and he told me all I need is this bracket and I can keep long water pump and same pulleys, no problem. This bracket does look a little weird though.
http://www.ebay.com/itm/Vintage-Air-...FVAT~r&vxp=mtr
Hey man
Old 03-09-2017, 10:38 AM   #17
Oregon 1967 GMC
And by the way, what did you do with your pax side interior air vent with the air conditoning unit snug up against it. Take out the handle or just keep it closed?
Hey man
Old 03-09-2017, 10:49 AM   #18
nyncompute
nyncompute's Avatar
First step I would think is to get a clear idea of what engine it is and whats been done to it. I put that set up on mine and everything pretty much was good to go
1972 K-10 SWB Cheyenne
nyncompute is offline   Reply With Quote
Old 03-09-2017, 02:44 PM   #19
cleszkie
cleszkie's Avatar
I was able to keep my passenger side air vent functional, control rod and all. The VA unit does not snug all the way up to the kick panel. They do provide a molded plastic block-off plate to permanently close the vent, but I suspect that this is for use in factory AC trucks that have a vacuum controlled passenger vent door and no manual control rod like the non-AC trucks.
cleszkie is offline   Reply With Quote
Old 03-09-2017, 09:57 PM   #20
Oregon 1967 GMC
Thanks Mister Cleszkie hmm, not sure what I'll do with mine probably just leave it be.
Hey man
Old 03-09-2017, 09:59 PM   #21
Oregon 1967 GMC
Attachment 1630444
Looks pretty clean, wow I don't know that much about A/C what are the spools of wire for? Looks like a complex setup. And that's pretty much what I have planned for my small block 400.
Hey man
Old 03-09-2017, 10:01 PM   #22
Oregon 1967 GMC
Attachment 1630444
Could I see a photo of the alternator mounting side? If it's a hassle don't worry about it. Thanks for posting this one.
Hey man
Old 03-09-2017, 11:25 PM   #23
nyncompute
nyncompute's Avatar
Thats just excess tubing for the replacement expansion valve. I decided to retain my POA valve. Not the cleanest look but I made it look as best I could at the time.
Old 03-09-2017, 11:27 PM   #24
nyncompute
nyncompute's Avatar
Hope this helps
Old 03-09-2017, 11:55 PM   #25
Oregon 1967 GMC
heck ya that helps. A picture is worth a thousand words or so they say. Just a few more questions; Where did you get your alternator bracket? and are you running a vintage air compressor? And is that the stock fan shroud? if not where from? Sorry here's another? What's your motor and water pump (short or long) type? Thanks a mucho.
Hey man
