Old 05-17-2017, 12:48 AM   #26
68 P.O.S.
Re: Where to find 1972 door panel screws?
Are these the ones you're talking about? From one of our vendors here.
http://classicheartbeat.com/catalog/...r%20screws.htm
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 05-17-2017, 01:29 AM   #27
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Originally Posted by Smitty View Post
Don't know if there is any interest. But the washers shown in my post are in the AU-VE-CO catalog Pt # 16015 #10 Flush Washer. I paid .13 each for them. And fasteners can be found at auveco.com.
Awesome Smitty, Thanks a bunch.
Hmm, not from what I've seen to-date. Maybe someone has seen these original. I like the bezel, assuming everything fits.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 05-31-2017, 12:15 PM   #28
71CHEVYSHORTBED402
Bingo. I took a chance on Amazon, because it worked out cheaper. Same description, but no part number. Now I have 100 and they fit perfect. Thanks Smitty.
Tony
Old 05-31-2017, 01:32 PM   #29
Smitty
Smitty's Avatar
Your welcome. I ended up taking a small piece of scrap 2x4, drilled an indentation with a 1/2 in. drill to hold the washer and used a file to remove material until the screw fit loosely enough to turn independently of the washer. Won't mess up new upholstery on door panels. Will post pictures when truck is finished.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 05-31-2017, 04:49 PM   #30
71CHEVYSHORTBED402
Looking forward to pics., and great idea with that lumber. Did you get replacement panels, restored or use existing? Luck has it I'll use what I've got. They still look new or close enough, less the "chrome" tape coming off the plastic. Seems to be a simple fix. The interior on these trucks was built to last.
Speak of screws, try finding factory type 8-32s for the rear lenses. Yeah common 8-32s work, but from what I see, none are available with the "thread forming" tips, and the fit isn't as good. No shortage here however, I just lifted off the driver.
Tony
Old 05-31-2017, 06:27 PM   #31
Smitty
Smitty's Avatar
I used the metal base model door panels and had them upholstered along with the factory buckets. and visors. I have a friend of my brothers doing all the work. Doing a great job, not cheap but will be worth every penny when he is done.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Old 05-31-2017, 09:41 PM   #32
Smitty
Smitty's Avatar
This is a poor picture of the seats and door panels. The headliner is the same color as the vinyl on the seat and sun visors used the material used on the seats. The tan color on the seats is the true color of the vinyl. Also match the seat belts and shoulder harness from Juliano's. The truck is being painted
Rain Forest Green.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Old 05-31-2017, 10:05 PM   #33
71CHEVYSHORTBED402
Rain Forest Green.
That's all going to look amazing. Tastefully done.
Tony
Old 05-31-2017, 10:54 PM   #34
Smitty
Smitty's Avatar
I'm getting more and more excited with each passing day. This was made possible by the inheritance my folks left me. And a great wife who said if I wished to fulfill the long time dream of a mighty fine truck this was the time. Drive train had been done and has been freshened up. All the rust repaired and several upgrades. Will post pictures upon completion.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Old 07-26-2017, 10:06 AM   #35
WannaBe68
WannaBe68's Avatar
Great thread and perfect timing! I was in the process of trying to figure out how to make the hump type finishing washers work, because I couldn't find any of those flush ones. I'm now the proud owner of 100ea Auveco part #16015...
Thanks again for an awesome thread!!
WannaBe68 is offline   Reply With Quote
