Old 08-27-2017, 10:37 PM   #26
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: Vin codes ?????????
Tall blocks were a 366cid and 427cid..
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 08-27-2017, 10:55 PM   #27
grunt67
Thank you for the input. Helps to learn,
Grunt
grunt67 is offline   Reply With Quote
Old 08-29-2017, 12:03 AM   #28
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
I'd recommend backing the timing off until you find the source of the ping. You're going to trash pistons and rod bearings, otherwise. My truck is set to the factory spec initial timing, and only pings a little if I'm pulling a hill with my 26 foot travel trailer in the heat (and gets up to about 230º). I have an HEI; maybe the MSD ignition is doing some early advance that doesn't show up?
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 08-29-2017, 12:41 AM   #29
grunt67
Thank you, Ill try that.
Grunt
Old 08-29-2017, 09:37 AM   #30
clay68c10
clay68c10's Avatar
X2 on the timing adjustment. Why spend money on something that's not broken. Drop your initial down to 8-10 and see how it does.
How's the plugs look? Running lean under load will also make it ping, especially if you have high compression. What pistons are in it? Do a compression test and post up the numbers.
Do some trouble shooting before you just throw parts at it. These old carbed engines are pretty simple. You may be a jet change away from perfection.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 09-01-2017, 04:24 PM   #31
grunt67
Originally Posted by grunt67 View Post
Yes, number 1 up to top, balancer mark on zero ?
This all started after we installed a Tac to the white wire on the MSD box, as it showed in the wire diagram , also installed Volt meter , seems like from that day on is when all the pinging started, but I can not see that causing all the darn pinging when motor get warmed up to 190 ??????????
I found the pinging problem !!!!!!!!! Initial timing was set at 14 degrees, but at 3000 rpm it shot up to 50 degrees in a heart beat, iput in the silver heavy springs, reset timing at 12 degrees, that got rid of 95 % of that pinging ,truck runs great, I bought a new dist and having a engine builder set up the new Dist. to what he thinks it should be for this engine, also put a new coil on it.
So glad to finaly get some where with this engine.
I WANT TO THANK ALL YOU GUYS FOR YOUR GREAT INPUT.
The old Grunt in WA. State.
"" WELL THAT DID NOT LAST LONG, AS SOON AS THE MOTOR GOT WARMED UP ., PING, PING PING !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
