Vin codes ?????????
OK, My Son bought this 1972 K20 4X4 the seller said it was built from 2 trucks and it has a rebuilt WA State Title VTR 04987
Cab has ID Plate Vin # CCE142S1411771 ???? Motor is a 402 I was told ? I found block numbers on the ft. of the pass side of block TO4O2TBJ ????? Can any decode this mess ? Thank You grunt |
Re: Vin codes ?????????
T0402 TBJ
Decodes as T- built in tonowanda 0402 is build date of April 2 Suffix code TBJ doesn't show up as being a 402 but does show up as being a small block. You'll need to recheck that J is correct in TBJ. TBG or TBH show as a 1970 402. Or just post a pic of your motor. http://www.nastyz28.com/gm-chevy-cod...-suffix-15.php |
I was told it came from a Monte Carlo 402 ?
But I dont know for sure ? |
#4 | ||
"I ain't nobody, dork."
Post a picture of the engine.
A Small block will have 4 bolts holding each valve cover on... a Big block will have 7, 4 on bottom and 3 on top. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
![]() Join Date: Jul 2016
Didn't find engine code, are you sure it's correct, seems unlikely to have 402 in the code...
Vin is 72 1/2 ton 2wd, V8, made in St. Louis |
![]() Join Date: Sep 2014
Here you go:
http://67-72chevytrucks.com/vboard/s...d.php?t=570059 Your Cab VIN states a 4x2 (not a 4x4) 1972 1/2 ton pickup with bed, V8 engine and built at the St Louis plant. |
![]() Join Date: Oct 2009
Here is a big block first and small block second side by side so you know what to look for:
It is a big block, but some one told me that 72 trucks never came with a 402 bb in them ???? The CC on the vins tells cab is a 2 wheel drive, but it is a 4X4
and the seller told me it was built from 2 trucks, ?? The top pic is what we have. Thank You for the help |
Probably a '72 Big Block C/10 body swap onto a 4wd frame. The 402 went in trucks starting in '70. There were no big block 4wds till '77 when it was a 454 in a K/30. The frame has a partial VIN on it, but it really isn't important. Your truck is titled accordingly. Y
You can check some things to verify it's a '72 K/20 frame. Does it have an HO52 rear? Both rear shocks mounted forward? Is the cab sitting directly on original cab mounts? Are the front ends of the frame cut off, and is the radiator core support moved back on the frame? If the answers are yes, yes, yes, no, and no it's a pre-73 chassis.
Thank You for all the great information !!
Grunt |
#11 | ||
For whatever reason Big Blocks were also badged as "400" on these trucks. Making a lot of people think they have small block 400's. Another GM anomaly.
Gary
Well I pulled the dist. had it check out at local speed shop, they say it is fine, I put a 680 Holley quick fuel, 12 Degrees Advanced timing, vacuum hose hook to timed port, runs great untill we hit a hill, pings knocks, sounds bad !!!! I did order a new Booster for the power brakes waiting on it, that dam noise just will not go away, do not know what to try next ??? Checked for vacuum leaks around intake , none, this is making me crazy !!!!!!!!!
Grunt |
#13 | |
#14 |
Yes, number 1 up to top, balancer mark on zero ?
This all started after we installed a Tac to the white wire on the MSD box, as it showed in the wire diagram , also installed Volt meter , seems like from that day on is when all the pinging started, but I can not see that causing all the darn pinging when motor get warmed up to 190 ?????????? |
#15 |
Proving it means using a piston stop to find true tdc.
Like here. http://www.crankshaftcoalition.com/w...op_dead_center Maybe you should bypass the msd crap and just use a stand alone distributor like an hei. |
#16 |
That was one of my thoughts also, why did some one put MSD on a stock 402 to start with. A HEI Dist wont fit will have to use a good Dist & Coil and ditch the MSD stuff, makes no since to have it.
Thank You |
#17 |
They used msd because it used to be a quality upgrade. Not so much now.
Why won't an hei fit? Might be a little tight but should be room. Or get a small cap hei like this. http://performancedistributors.com/p...nition-system/ Or a pertronix. http://www.pertronix.com/prod/ig/fla...t/default.aspx |
#18 |
No room against fire wall for HEI, I do not think a stock 402 should need an MSD, so I think I will trash it and just go with a good dist. and coil.
Thanks |
#19 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
My K20 has a big block wedged in it. It has a HEI, it's tight but fits.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
#20 |
Yes, I'd throw in a bone stock distributor and coil also, eliminate the MSD, and try things out. If all good, then convert the stock distrib to electronic somewhere down the road with Pertronix or an equivalent kit. HEI is definitely a reliable and proven system, but in cramped quarters, it's easy to convert a stock points distributor to electronic.
#21 | |
#22 |
All about them K’s
![]() Join Date: Jun 2014
How are you identifying it as a tall deck? I'm not sure they ever made a tall deck 402?? A light duty c 10-30 would have come with a low deck big block and certainly a Monte Carlo would have too.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
#23 |
I assumed all truck motors were a tall deck is what some one told me. I guess i will have to try and read the casting numbers on the rear of the motor, i can not find the suffix to402tbj , so thats out.
I dont know if its a truck or a car 402, it does have a 400 hydromatic tranny. ????????????? Its all frustrating , thank you grunt I DID FIND TBJ SUFFIX CODE AND IT STATED IT WAS A SBC/ IT IS A BIG BLOCK TRUST ME ON THAT ONE, I'LL JUST ORDER UP A 402 INTAKE ,AND A READY TO RUN DIST, AND COIL, PULL THE MSD, AS IT DOES NOT NEED IT ON A STOCK 402 MOTOR. I'M GOING TO GET RID OF THE DAM PINGING AND KNOCKING ONE WAY OR THE OTHER. GRUNT Last edited by grunt67; 08-27-2017 at 09:34 PM. Reason: FOUND TBJ CODE |
#24 |
Here's the easy way to tell what block you have. Just look at the water pump bolts.
http://www.crankshaftcoalition.com/w...#Tall_deck_BBC If it were me, I'd do one thing at a time. Change out the distributor first. Then look at the intake. Keep it simple. You do know about the different intakes, don't you. THere's oval port and square port ones. You likely have an oval port one. What intake and carb do you have? |
#25 |
Right now it has a Edelbrock performer ( quad) intake and a very sloppy installation, I just put a 680 Holly quick fuel carb on it, runs great, except for that on load when warm pinging and knocking, also has a MSD A box on it, with a MSD Dist. I'm sure it is an oval port.
It had a Edelbrock 600 afb thunder jet on it, it sucked. Timing is at 12 inital, 32 Final, advance comes in at 1250 and stops at 2500, timing is on timed port of carb. 92 octane fuel. Everything on that motor was finger tight when we got it. |
| Bookmarks |
