Old 01-29-2018, 01:06 AM   #26
Oldironracing
Oldironracing's Avatar
Re: GM connect and cruise engine package
Will this oil pan work 12640748 GM #
OLDIRONRACING
Oldironracing is offline   Reply With Quote
Old 01-29-2018, 04:13 AM   #27
ls1nova71
ls1nova71's Avatar
That's the pan that your crate LS3 engine should have come with. Depending on how low your truck will be, this is an affordable option. http://www.jegs.com/i/GM-Performance...RoCzHYQAvD_BwE It works well in 67-72 trucks, but you may need a 98-02 F body pan if your truck is really low.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-29-2018, 01:58 PM   #28
Low Elco
Well CRAP. Here ya go-
http://67-72chevytrucks.com/vboard/s...d.php?t=563833
Low Elco is offline   Reply With Quote
Old 01-31-2018, 12:46 AM   #29
Oldironracing
What all do I have to have to do the ctsv oil pan swap. Doing a4/6 drop
OLDIRONRACING
Old 02-10-2018, 07:26 PM   #30
Oldironracing
Ok here's a update if anyone wants to know. Motor is in the chassis all went really good. Used the GM hot rod pan. What degree should the engin set at? Should I use the same 3 deg as the original motor was?
OLDIRONRACING
Old 03-18-2018, 05:58 PM   #31
bugmasta
bugmasta's Avatar
following, looking at the same connect and cruise package for my 68. mind sending me the info for the dealer you ordered yours from at $12k?
68 c20 build: http://67-72chevytrucks.com/vboard/s...d.php?t=358130
Club longbed ...cause girls like'em long!!!!!
bugmasta is offline   Reply With Quote
Old 04-19-2018, 09:59 PM   #32
Oldironracing
Nesmith Chevrolet
Clayton Ga..
877-497-3624
Super nice guys.
OLDIRONRACING
Old 04-19-2018, 10:03 PM   #33
Oldironracing
Some work done
OLDIRONRACING
Old 04-19-2018, 10:04 PM   #34
Oldironracing
Little more done
OLDIRONRACING
Old 04-19-2018, 10:07 PM   #35
Oldironracing
What type of front assessoray drive have you guys run??
Looking at the cts-v set up
OLDIRONRACING
Old 04-19-2018, 10:34 PM   #36
RUN GMC
RUN GMC's Avatar
Is that a trans cooler.....if so explain how you are using it......looks killer........
RUN GMC is offline   Reply With Quote
Old 04-19-2018, 11:53 PM   #37
lutronjim
Since I added Vintage Air AC, I went with their belt system.
lutronjim is offline   Reply With Quote
Old 04-20-2018, 11:40 PM   #38
Oldironracing
Yes it's a trans cooler. Swagelok fittings and s/s tubing and some push lock fittings and rubber line.
OLDIRONRACING
Old 04-23-2018, 09:32 PM   #39
Oldironracing
Ok going to try this again. I'm using dirty dingo slider motor mount and CPP stands.
What accessory drive are you guys using. I don't won't to change the water pump or Harmonic balancer.
OLDIRONRACING
Old 05-28-2018, 11:21 PM   #40
Oldironracing
Got a little more done.
OLDIRONRACING
Old 05-28-2018, 11:23 PM   #41
Oldironracing
One more
OLDIRONRACING
Old 05-28-2018, 11:25 PM   #42
Oldironracing
More
OLDIRONRACING
Old 06-04-2018, 02:13 PM   #43
SBTork
Garage wrench
SBTork's Avatar
It's looking real good! Love the trans cooler, keep up the good work!
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 06-04-2018, 10:37 PM   #44
Oldironracing
OLDIRONRACING
Old 06-05-2018, 09:27 AM   #45
davepl
davepl's Avatar
If you're still looking for an accessory drive, I went with Concept One. It looks very pretty and tucks everything nice and down low. This is in my Camaro, but same idea. Cheap? Nope.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-28-2018, 10:02 PM   #46
Ric's/86
It's looking real good! I'm looking at the same connect and cruise package for my 1986
Did you figure out what degree should the engin set at?
Keep up the good work.
Ric's/86 is offline   Reply With Quote
Old 06-30-2018, 09:20 AM   #47
Oldironracing
They say if I match the drive shaft to the engine it should be good. So far everything is lining up and clearing.
OLDIRONRACING
Old 07-07-2018, 10:56 AM   #48
MIKESAD50
I used Holleys front drive system in my Ls swap, I believe it is based off the GM corvette drive set up. didnt have to change W/P or Crank Pulley
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 07-10-2018, 10:43 PM   #49
Oldironracing
The Holley one is the one I'm looking at
OLDIRONRACING
Old 07-10-2018, 11:07 PM   #50
Oldironracing
Been working on it getting some done. My hiding place for ECM.
OLDIRONRACING
