Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 12-09-2018, 10:35 PM   #26
Big Daddy Bear
Big Daddy Bear's Avatar
Re: project drivabeater: GMT400
Looks good, sure feels good to move things along, don't it?
No bolt or nut in the world will remain tight if you turn it to liquid!!!
Big Daddy Bear is offline   Reply With Quote
Old 12-10-2018, 03:16 AM   #27
Terrick down Under
Terrick down Under's Avatar
Are you going to do the Jeep job on the rag joint?
Terrick down Under is offline   Reply With Quote
Old 12-10-2018, 07:22 AM   #28
dusterbd13
Yes it does. Should have done this month's ago
dusterbd13 is offline   Reply With Quote
Old 12-10-2018, 07:24 AM   #29
dusterbd13
I had been planning to, which is why I've put it off for so long. But the correct parts haven't been found on the days i remember to look at the junkyard
Old 12-13-2018, 01:48 PM   #30
SCOTI
SCOTI's Avatar
Regarding Post #23....
Curious about what adhesives you used? I have to do this to my 99. The dash has succumbed to the TX heat & crumbled to pieces. I have never been a fan of 'dash-caps' but it appears there's really not much of an alternative for these later model trucks.
What brand dash-cap did you use? I see a couple of spots in the pics that could possibly be tweaked for a better appearance if desired but it looks decent enough for the daily grind.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-13-2018, 03:31 PM   #31
dusterbd13
I used an accuform cap. Reason being is it covers the whole cupholder area, and more of the dash. The other brand i can't remember, but it doesnt cover nearly as much. Ive used accuform cap on other applications and been pleased.
They supplied a tube of silicone adhesives, and i supplemented with rtv when the tube ran out. If i had more of a dash to start with, and more time/talent, the fit could have been better.
Old 02-19-2019, 11:05 AM   #32
LT7A
You've brought this truck up a long way. And for very reasonable money. What McMaster Carr product do you use for the sound deadening, and how did you come about using that? I took a look at their website and there were a couple materials that I think would work well, but looked to be a little spendy. I imagine you used something that is pretty cost effective.
Old 02-19-2019, 09:07 PM   #33
dusterbd13
https://www.mcmaster.com/sound-and-v...damping-sheets
i generally use the 13% sheets. I forget how I wound up with these, but they flat WORK.
