Old 03-26-2018, 11:12 PM   #26
Jotto82
Re: Detroit locker
Originally Posted by Matt Man View Post
Yep mine is fine as well for daily driving, I agree with both of these posts.
Cool, what is it that makes the loud bang with the DETROIT Locker? Just curyff
Jotto82 is offline   Reply With Quote
Old 03-26-2018, 11:25 PM   #27
4x4k30
4x4k30's Avatar
Re: Detroit locker
you just need a spool if you are gona act like a fool QUOTE I just want both tires to turn when doing a burnout lol[
4x4k30 if trouble was money i would have plenty
4x4k30 is offline   Reply With Quote
Old 03-26-2018, 11:51 PM   #28
Matt Man
Matt Man's Avatar
Re: Detroit locker
The detroit locker makes some noises that the inexperienced might think there is something wrong, but in reality the detroit locker has backlash and when you let off the gas pedal you feel a clunk, this is the locker unloading. The bang has only happened to me 3 times. The first time I took off from a red light and it made a bang and you can feel the rear of the truck push to one side slightly. The 2nd time it happened in my school parking lot while making a very sharp turn. Needless to say it scared some girls walking by The last time it happened I took off from a stop sign turning left and this one was VERY loud first time I got scared from it.
Personally, I would only install a Detroit locker in a 4wd, this is because if you have one tire off the ground the detroit locker will always spin both tires no matter what which is what you want if you wheel your truck hard.
The truetrac on the other hand will only spin both tires if they're both on the ground and one tire loses grip. Which is why I would recommend a truetrac on a 2wd truck. You can get a truetrac to spin both tires if one is in the air if you lightly apply the brakes.
The detroit locker and truetrac are fantastic units, I have a detroit in the rear of my 81 and a truetrac in the front. Both have no clutches to wear out and take no additives, just plain gear oil.
Here is a video on what the bang kind of sounds like, even though this is a cheap spartan locker watch at the 1:38 mark. https://www.youtube.com/watch?v=Mi7ze7149HE
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 03-27-2018, 12:46 AM   #29
kwmech
Re: Detroit locker
Originally Posted by Jeepwm69 View Post
Installation should be the same. Both the Detroit and the trutrac replace the carrier.
Not true, the detroit locker is not a complete unit in the 14 bolt where-as the tru-trac is. You use the existing carrier and take apart the halves, remove the spider gear assy and put in the locking assy. Bolt it back together with the ring gear and remove the holding bolt.
Old 03-27-2018, 06:50 AM   #30
Jotto82
Re: Detroit locker
Lol
Old 03-27-2018, 06:54 AM   #31
Jotto82
Re: Detroit locker
I do have 4WD so I guess I can just pick one. I gotta look at my gear ratios and I will probably just buy everything and then build it all at once. I appreciate all the explanations.
Old 03-27-2018, 10:58 AM   #32
dieseldawg142
dieseldawg142's Avatar
Re: Detroit locker
the detroit "clunk" i find is more noticeable on lighter trucks than on heavier ones. i can't ever recall hearing it in my crew, but got it a couple times in my K5
there is a lot of backlash with the detroit, but in no time you will adjust your driving style to accommodate it and then you won't even notice
dieseldawg142 is offline   Reply With Quote
Old 03-27-2018, 11:18 AM   #33
kwmech
Re: Detroit locker
I found out years ago how to reduce the severity of the detroit when I had the locker in my wrecker snap into itself on a stretched out turn on a mountain road with a full load on the back. Talk about squirrelly at 50 mph. Anyways I drained the diff and pulled the cover thinking I had broken something but didn't. When replacing the oil I put in 2 quarts of Reline Shock Proof and 2 quarts of regular 85/90. Never had that clunk again and it was much quieter.
Old 03-27-2018, 01:29 PM   #34
Jeepwm69
Re: Detroit locker
Well I'll be.....
Had to look into that a bit as I've only done Dana/Spicer Jeep axles.
Looks like the 14 bolt carrier is heavy enough to reuse so the Detroit is just a heavy lunchbox style for that axle.
Learned something new.
As for on the street use, I'd still go with the Truetrac.
I have a Truetrac in the rear of my green Jeep. Invisible on the street, and unless you have a wheel in the air it performs just like a locker.
I have lockrights front and rear on my tan Jeep. They rachet and bang occasionally going around corners, but if you stay off the gas in a turn they usually don't make much noise. They do NOT like it if you have even a couple of PSI difference between the two tires on the axle.
I have a Powertrax no-slip in the rear of my other tan Jeep. It's about the same as the lock-right, just doesn't make the noises.
I would 100% go with the truetrac for a street driven truck. Buy once, cry once.
Jeepwm69 is offline   Reply With Quote
Old 03-27-2018, 05:46 PM   #35
Jotto82
Re: Detroit locker
Well I'll be.....
Amen to the buy once cry once.
Old 03-27-2018, 06:47 PM   #36
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Detroit locker
" buy once cry once. ".....so true ...so true
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-27-2018, 10:57 PM   #37
SunSoaked
SunSoaked's Avatar
Re: Detroit locker
Been running a Detroit Locker in my 85 K20 (14 bolt transplant from a CUCV) for two years. Have yet to hear/feel any clunk or lockup.I know it's working because it leaves a nice parallel set of lines of black rubber when I hammer it. I am completely satisfied with it.
SunSoaked is offline   Reply With Quote
Old 03-28-2018, 11:28 PM   #38
Jotto82
Re: Detroit locker
So if I decide on trutrac do just choose the gear ratio I want? Sounds like that’s a complete unit. I think I have 4:56?gears now but I think 4:10 might be bettter. Any options on what has been effective for them? Finished product is a low end torque power house. Motor has been completely rebuilt about10k ago so I’m thinking get the rear end setup how I want it then throwing in a nice loping cam and a decent top end kit. 350 400 HP and proper gearing and I’ll have a beast.
Old 03-29-2018, 12:46 AM   #39
kwmech
Re: Detroit locker
So if I decide on trutrac do just choose the gear ratio I want? Sounds like that’s a complete unit. I think I have 4:56?gears now but I think 4:10 might be better. Any options on what has been effective for them? Finished product is a low end torque power house. Motor has been completely rebuilt about 10k ago so I’m thinking get the rear end setup how I want it then throwing in a nice loping cam and a decent top end kit. 350 400 HP and proper gearing and I’ll have a beast.
Ratio would depend on tire size, engine and transmission, AND being 4wd you'll have to possibly match the front.
Old 03-29-2018, 01:40 AM   #40
mongocanfly
Post Whore
Re: Detroit locker
and here ya go on the gear calculator...
http://www.csgnetwork.com/multirpmcalc.html
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 03-29-2018, 07:07 AM   #41
homemade87
Re: Detroit locker
There is no gears that come with this ( I think this is what your asking ). You use the gears you have unless you are planning a gears change and ordering gears as well .
Removing the pinion for a gear change changes the hole ball game as far as gear set up.
homemade87 is offline   Reply With Quote
Old 03-29-2018, 05:04 PM   #42
sweetk30
sweetk30's Avatar
Re: Detroit locker
there is a carrier split for gear ratio's . you need to know what you have or are swapping to so you can get the correct one.
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 03-29-2018, 07:33 PM   #43
Jotto82
Re: Detroit locker
Yes that was what I was asking. An earlier post made it sound like it was essentially a complete unit with gears. I probably just read it wrong.
Old 03-29-2018, 10:46 PM   #44
JacobSchni
JacobSchni's Avatar
Re: Detroit locker
i have a detroit in my 83. it has a 14ff 4.10 gears and 680hp. honestly its not bad at all. barely notice it. you can tell its there, but mainly on fast turns from a stop. Definitely would reccomend.
1983 Scottsdale K10 496 /t400 fmvb /208 /D60 and 14ff with Locker /35x12.5x15 mt baja mtz
680hp/720ftlbs of NA fun
JacobSchni is offline   Reply With Quote
Old 03-29-2018, 11:14 PM   #45
Jotto82
Re: Detroit locker
Damn 680hp. I just drooled all over my phone.
Old 04-04-2018, 10:29 AM   #46
trukman1
Re: Detroit locker
I like my Detroit but it does require some getting used to ESPECIALLY in slippery conditions! Not the best in snow...can get a little tricky till you get used to it.
Read the safety disclosure if you go that route. Sounds like you have an open carrier which is required with the Detroit.
Sounds like your leaning towards something else anyway just wanted to put this out there.
1967 K30 461/TH400/Np205/D60/14FF/BDS
MTZ 375/75/16 on 16x10 Pro Comps
trukman1 is offline   Reply With Quote
