![]() Join Date: Feb 2018
Detroit locker
I want to switch to posi. Anyone have advice for installing a Detroit locker in a 14 bolt corporate rear end?? I’ll
Re: Detroit locker
A detroit locker is not the same as a posi like a trutrac. Are you going to be running the same ring and pinion?
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 ![]() |
Re: Detroit locker
Detroit Locker is defently different than a "posi" Detroit lockers are probably the easiest to install into a full floater 14 bolt corporate. It takes about a hour and half to install. Mine came with complete instructions.
1990 chevy Crewcab K30 454tbi/th400/np205twin stick/14bltFF,eaton posi/D60. 1972 CST K5 350/th350/12blt,eaton posi/D44 1970 K10 SWB 1970 K20 350/th350 |
Re: Detroit locker
I just want both tires to turn when doing a burnout lol
Re: Detroit locker
Re: Detroit locker
The Detroit is the best and cheapest for a 14 bolt. I personally don't like lockers or posi in my snow buggies.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
Re: Detroit locker
A locker is great for off-road, and for dry pavement if you are willing to put up with some of the side-effects like the ratcheting noise and sometimes unpredictable behavior in turns. But for daily driving in a variety of conditions - rain, snow, ice - it definitely is not a good time. A limited slip unit would be a much better choice.
Re: Detroit locker
Lol can I still do good burnouts? I know that sounds stupid but my kids likes burnouts. Will the limited slip be good for that?
Post Whore
![]() ![]() Join Date: May 2015
Re: Detroit locker
I'm looking at tru trac for my 14bolt....not cheap though..
#10 | |
Re: Detroit locker
Buy the trutrac, you wont be disappointed.
Re: Detroit locker
what about the Eaton Posi? I'm between that and the Truetrac
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
#12 | |
Re: Detroit locker
#13 |
Re: Detroit locker
HTML Code:
what about the Eaton Posi? I'm between that and the Truetrac If you just want to do burn outs, save your $$ for tires and put a spool in it.
#14 |
Re: Detroit locker
If I’m going that far should I put new gears in too? Just do the whole deal at once?
#15 |
![]() Join Date: Mar 2003
Re: Detroit locker
#16 |
Re: Detroit locker
#17 |
Post Whore
Re: Detroit locker
jotto ...I'm of the opinion that if I tear into something I'm gonna replace everything....but....if there's nothing wrong with the gears I'd re-use them.....unless your wanting to change ratios..
#18 | |
Re: Detroit locker
The Detroit is not going to be friendly on the street. Truetracs are great diffs, but not cheap. They don't wear out like Auburn or Eaton units with clutches. If you want cheap and easy locker, you'd want a lunchbox like a Spartan, Aussie, or Lock-Right. They replace the spider gears and thus do not require setting up the gears like you have to do with a carrier replacing diff like a Detroit or a Truetrac. The lunchbox lockers behave just like a Detroit on the pavement thought. Ratcheting noises and banging going around corners and your tires will wear faster. |
#19 |
Re: Detroit locker
best of both worlds here and try choking on this price .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
#20 |
Re: Detroit locker
I’m not sure what ratio I have in there now. Seems like it’s pretty low though. I am on the same page with you about having it apart and just doing it all. None of this has to be done now. I’m just asking questions. I don’t even care to do burnouts to be honest. It was just how I explained what I wanted to achieve. I’ll stay away from the Detroit because that sounds like it’s more of an off road application as opposed to street wear n tear. Can someone tell me how I determine my gear ratios?
#21 |
Post Whore
Re: Detroit locker
pull cover and count teeth is the most accurate...if your wanting burnouts, its a lot easier to spin one than two....
#22 |
Re: Detroit locker
#23 |
Re: Detroit locker
i daily drive my K30 crew with a detroit....it's not nearly as bad as everyone is making it out to be. if your a granny on the throttle, you'll never even know it's back there.
one downside is it is hard to do rightous donuts in the snow or mud, truck has a tendency to want to "push" in circles. but so what, awesome traction all the time, on road and off. only time it chirps going around corners is if i'm heavy on the throttle and have the wheel cranked hard over.... and with my bb and 4:56's, i love the way the ass end stands up if i hammer the throttle, 3 feet of rubber, 4:56's and a detroit, it launches hard for a 4 ton honey.... |
#24 |
Re: Detroit locker
Same here I have run a Detroit locker in both a Dana 70 and 14 bolt daily driver. No issues, you have to know it’s in there to know it’s in there. If you know what I mean. I would put one in a 100 times over, they are tough and pretty much flawless.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
#25 | |
Re: Detroit locker
