Old 04-14-2018, 10:36 PM   #26
69BUCKET
Re: Custom reroute for reworked harness
Originally Posted by racecougar View Post
been there, done that. Plan on spending a lot of time reworking each wire.
boom...that's what i'm talking about....so did you separate wires for each clip?...
69BUCKET is offline   Reply With Quote
Old 04-14-2018, 10:54 PM   #27
racecougar
racecougar's Avatar
Separate wires for each clip? What do you mean?
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 04-15-2018, 03:10 PM   #28
69BUCKET
separate wires for each clip? What do you mean?
well...as i've torn mine apart...i've noticed some wires are intertwined. So i was wondering if each pair, or 3 wires per connector were separated before routing and then combining wires to be wrapped.
Old 04-15-2018, 05:37 PM   #29
ls1nova71
ls1nova71's Avatar
You'll find a lot of them are intertwined. I would only take it as far apart as necessary to move whatever wires you think need to be in a different spot. You can take them all the way apart, but I wouldn't recommend it if this is your first time as it's probably the most problem inducing way to do it. I modified almost every wire in this harness, and have no idea how many hours I had in it, but lets just say it was a lot!
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-15-2018, 05:39 PM   #30
racecougar
racecougar's Avatar
Yes, each wire was worked individually.
Old 04-15-2018, 05:43 PM   #31
69BUCKET
That's what I was thinking. I have about 4 hours in it so far....so I will break it down as I need while plugging stuff on engine.
Nova, that is one of my favorite set ups I've seen!! Old school look...but LS!! Nice work!!
Old 04-16-2018, 09:08 AM   #32
69BUCKET
Since people have been active on this thread...I have a question.
Running a TH350 behind the 5.3...can I eliminate the VSS wires?...or where would those connect to?
Old 04-16-2018, 06:45 PM   #33
dayj1
You can delete it. It's a matter of opinion on whether or not it will run "right" if you do. My opinion is that it does not.
As to where to connect the VSS wires if you decide to keep the connections, you need a VSS sensor that you can adapt to your trans. Companies like Dakota Digital sell VSS sensors that screw onto the speedometer output on the tail shaft.
dayj1 is offline   Reply With Quote
Old 04-16-2018, 07:20 PM   #34
69BUCKET
I've read more that it does not affect how it will run on a th350...but could on the 400...i will delete them!..
Old 04-16-2018, 08:00 PM   #35
ls1nova71
ls1nova71's Avatar
It wont affect how the engine runs one bit, but what it will affect is driveability. Those are two different things. Without the speed sensor you will likley have stalling issues when coming to a quick stop, such as coming off a freeway exit ramp where you've been driving, say 65mph, then at the end of the ramp is a red light. Without the VSS the PCM wont realize you've come to that stop and wont compensate for the change quick enough. I found this out years ago when the VSS came unplugged on my old TPI and it began stalling. That was a way simpler system, things have only gotten more complex.
Old 04-16-2018, 08:43 PM   #36
69BUCKET
Well shoot...I guess I will know what my problem is if this happens once I get it going...
Old 04-16-2018, 11:22 PM   #37
69BUCKET
So...if i end up with driveability issues...is this what i need for my th350?...
Old 04-18-2018, 02:57 PM   #38
69BUCKET
Any help with this?...^^^
Old 04-18-2018, 10:48 PM   #39
69BUCKET
Guess I'll start another thread to ask that.
Here is my finished harness. Next time for MY car...I would do a few things different.
