![]() Join Date: Oct 2017
Custom reroute for reworked harness
Any one have any pics of work they did to customize the harness, minimize it to tuck and hide wires?
I am working with a dirty reworked 5.3 DBC, NON FLEX-FUEL harness. It has transmission wires still in it and want them gone so I want to redo it, clean it, and maybe reroute wires to shorter paths. Just looking for tips and advice as I start the tear apart of loom. |
Re: Custom reroute for reworked harness
I don't have any pics or advise yet. I haven't started modifying mine. Just keep in mind that your two statements above are likely impossible together. A hidden harness will be significantly longer. A shorter harness will be more visually intrusive.
I meant minimizing it in regards to elimimating wires not needed. I'm not so concerned with length...pcm will go inside cab. I think with all wires undone from loom and routing them in shortest paths will allow pcm connections to go inside cab without having to extend anything. Just wanted to see if anyone had done this with success.
One question i had is do guys need temp. Sensor plug to not turn on eng. Light? |
Yes you will need the temp sensor or it won't run correct. Its very important.
Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
#5 | ||
![]() Join Date: Jul 2009
I've reworked the harnesses on 2 C10s with the PCM inside the cab and 6 with the PCM in the engine bay. Quote:
Good luck with your project. |
Can you verify if i have wires i need?
Running a th350 8 - injectors 2 - coil connector 2 - oxygen sensors 1 - maf 1 - map 1 - alternator 1 - idle air control 1 - tps 1 - crank. Pos. Sensor 1 - Cam pos. Sensor 1 - knock sensors 1 - temp. Sensor 3 - ground terminals Last edited by 69BUCKET; 04-09-2018 at 09:06 PM. Reason: Update |
#7 | |
Depending on what you do for gauges and fans, you may want something for those as well. |
Agreed...2 knock sensors but 1 plug for both of them...but big thank you. I almost forgot about cam sensor.
If you are planning on reworking your own harness, lt1swap.com is an immensely helpful resource.
As for mounting in the cab, the blue/red harnesses are significantly shorter than the blue/green ones. Though I have mounted the pcm in the cab of a 56 truck using a blue/red harness and only needed to lengthen a couple of wires, but it was tight. Though I do completely depin the PCm connectors and customize the routing of all the wires. Makes for a very clean harness. |
When shortening wires, I assume you all are shortening the PCM end? I've figured out how to depin the PCM connector(google "mx123 molex connector manual," and look for a sizable PDF), but I'm not sure what comes next. What crimping tool, and what "bullet" ends are you using on the wires? Any google search terms or links would be appreciated. This will likely be a one-time project, so I don't want to get very spendy with crimping tools.
I have been looking at lt1swap some...along with videos from Rowdy...swap into a jeep. By far best video of how to do a harness. I took my already reworked harness completely apart and ready to eliminate wires not needed that the place I got it from didn't. Next step is place harness clips in place and wire tie the wires to my liking. Hopefully that leaves me enough slack to put PCM in cab. If not, I should be able to put it a safe place in engine bay.
X2 on UCANDOIT2 (Rowdy) from youtube. He almost had me convinced I could rework my own harness...ALMOST.
'71 C-10 SWB Shop Truck Currently 350/350, soon to be LS'd.
#13 | |
#14 |
While you still need the temp sensor, you can move it to the back of the engine on the other bank where it is a lot less conspicuous.
Getting the ECM inside the cab helped a lot, but the coil packs are damned ugly. I shaved them and bought harness extensions so I could either put the coil packs on the inside of the firewall in the cab, or down on the frame rails. Here's a shot of the shaved valve covers painted in a wrinkle black finish- Getting rid of that gawd-awful black conduit and electrical tape is the next order of business. For everything I can't tuck or hide that can be seen when you open the hood, I'll de-pin the connectors and cover the wires with black Techflex, with the last inch or so to the connector covered with heat shrink - no tape allowed! Buy several sizes for a tight fit. I'll also heat shrink at every 'branch' of the harness to clean it up some. You can buy literally 100s of pieces of heat shrink in a kit off ebay for about $10. If you're using any kind of crimp connector (other than the Packard crimper for connector pins) - Stop. Learn how to do a 'western union' or lineman's splice and solder and heat shrink all connections. All the wiring from the front of the engine will run under the intake manifold to the back of the motor and on to the ECM For other parts of the harness that will be out of view, I bought a product called "Roundit 2000" made by Federal Mogul. It looks like a mesh covering but is actually split down the middle to allows you to get at the harness if needed. Well, that's my plan anyway............. |
#15 | |
#16 | |
A good quality uninsulated butt connector crimped using a good set of ratcheting crimpers makes for a better splice than 90% of people can make with a soldering iron. Just cover with some flexible adhesive lined heatshrink for weather protection and be done. Last edited by Wildkarde; 04-11-2018 at 01:24 AM. |
#17 |
I also wondered about soldering and it cracking with stress. I am going to use butt connector with heat shrink tubing. I'll post pics once I'm done...waiting on a couple pigtails.
#18 |
"A good quality uninsulated butt connector crimped using a good set of ratcheting crimpers makes for a better splice"
Couldn't agree more. The problem is that many don't use 'good quality' butt connectors and ratcheting crimpers and will use a Chinese splice kit bought at Autozone. Worse yet is two wires twisted together and wrapped with electrical tape. (or a wire nut from Home Depot) Most guys have a soldering iron though, and with a little care can do a decent splice. I'm about to do a chassis wiring harness on my truck and still a lot to do on my engine harness - any recommendations for crimper brands. It might be time to step up. |
#19 |
I've done quite a few soldered connections on off-road cars and never had a problem. I've heard of factory chassis and engine harnesses having to be replaced on trucks used in oil fields in Texas due to severe environments and lots of miles. (shops in Arizona do a fair amount of them due to pack rats eating the insulation off of cars parked outside)
But a soldered joint can crack and best practice on any wiring is to make sure it is properly bundled and supported so as not to transmit excess stress or vibration into the wires. |
#20 | |
BMW & ASE Master Certified
http://www.te.com/usa-en/product-963...-docs-features And a open barrel crimper for that type and quality adhesive lined heatshrink. If you have no experience and confidence in wiring repair, best bet, buy painless. Don't want to be left stranded due to a poor connection, or intermittent connection and even worse it doesn't run once you lengthened it.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
#21 |
Geez....so what do i do now....?
Don't touch any wires without my electrician buddy present? ...he does like to drink his craft beers when we get together....got it!.... |
#22 | ||
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#23 |
I don't know what you're going to do, but I think I'll go do that 'painless bar' thing. A couple drinks there should set things right!
#24 |
#25 |
Been there, done that. Plan on spending a lot of time reworking each wire.
| Bookmarks |
