Old 08-04-2025, 12:27 PM   #26
6DoF
6DoF's Avatar
Re: 1955 Long Distance Build
good call on the rear shackle hangers. also, dakota digital has a haltech adapter to read everything right into the gauge cluster. i've really liked the DD products so far.
6DoF is offline   Reply With Quote
Old 09-01-2025, 11:00 AM   #27
caseyjones
The RTX gauges look pretty close to stock too...I really like those.
I've started pulling the truck back apart to replace the firewall and floor - With the bed removed you can see some of the exhaust system.
And I realized I haven't posted any updated photos of the engine bay. I have to clean up some of the extra harness leads that I didn't end up using, and some of the connectors have a ton of length that I need to shorten or hide.
caseyjones is offline   Reply With Quote
Old 09-05-2025, 03:15 PM   #28
caseyjones
Some pictures of what I'm starting with:
I have full replacement panels for the firewall, kick panels, outer cowl, and floor pans. Looks like the firewall should be the first panel to come out, then I'll peel back the layers from there. Bracing will be tricky with so much structure having to come out.
Old 10-03-2025, 01:47 PM   #29
caseyjones
I've got the firewall, front floor pans, inner cowl, outer cowl, cowl filler, and lower pillar patches in place. I had to patch up the rocker panels from the pillar forward, too. I didn't end up bracing anything - I never cut the pillars completely away from the rockers and worked a section at a time to keep things in place as much as possible. I reinstalled the doors and hood when I did the outer cowl panels to try to ensure parts fit back up and it seems like i can make it all work again.
Old 10-04-2025, 09:16 AM   #30
Rickysnickers
Rickysnickers's Avatar
Nice work.
Old 10-05-2025, 06:32 AM   #31
B52bobardier1
Hello,
Yes, very nice work. I love your tenacity and self discipline to see it through. I will definitely keep my eye on this build.
Rick
B52bobardier1 is offline   Reply With Quote
