Old 06-16-2018, 09:33 PM   #26
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Help identifying, please!
Thank you for the additional pics. Inboard cab mount therefore 64 and newer frame mount.
Old 06-16-2018, 09:35 PM   #27
aerotruk63
aerotruk63's Avatar
Single master again 63 and newer.
The more pictures you supply the more we can decipher the parts to help you.
Old 06-16-2018, 09:40 PM   #28
aerotruk63
aerotruk63's Avatar
Originally Posted by pimpston65 View Post
Is that K10 with ps?
Steering dampner for those big tires.
Old 06-16-2018, 10:10 PM   #29
ostie82
Thank you Aerotruk!
Btw, what do you mean by “inboard cab mounts”? The cab mounts are outside the frame rails.
ostie82 is offline   Reply With Quote
Old 06-16-2018, 10:16 PM   #30
ostie82
Also, the steering box is on the outside of the frame rail, if that helps any.
Old 06-16-2018, 10:48 PM   #31
jayoldschool
Moderator
70s/80s small block
jayoldschool is offline   Reply With Quote
Old 06-16-2018, 11:43 PM   #32
Captainfab
60-66 Nut
From what I can see, the frame and running gear are '63-'66.
Old 06-16-2018, 11:46 PM   #33
Captainfab
60-66 Nut
I believe he means that they are the '63-'66 style which are closer to the frame than the '60-'62 front cab mounts.
Originally Posted by ostie82 View Post
Thank you Aerotruk!
All GM trucks prior to '88 have the steering box on the outside of the frame.
Old 06-17-2018, 01:39 PM   #34
61K10
61K10's Avatar
also cab mounting cushions on 60-62 are square not round. And nice tk. another one saved! Have fun.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 06-17-2018, 04:05 PM   #35
andyh1956
Looks like some cooler lines for an auto transmission going to the front hanging down. If the right side looks as good as the left I say you done good!
andyh1956 is offline   Reply With Quote
