Old 02-18-2019, 02:09 AM   #26
OldCreek
OldCreek's Avatar
Re: Convert Allison 1000 5sp 2wd into 4wd
Originally Posted by Shtudwn View Post
That's interesting.
Does the divorced case cause any clearance issues?
I asked for and got the driveline with the engine/trans from the wrecking yard. It's a 2 piece.
Dan
Not from the divorced case. The Allison was huge and I had a body lift to clear the tunnel. I had a 3" body lift but iirc I could gotten away with 1" - 2". (I had to have the body lift because of the frame I was using and what I was trying to accomplish.)
Wil
Sorry, i can't find the pic of the intermediate shaft setup. I do have a pic of a cutting brake set up on the back of the np205, btw.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 02-18-2019, 02:15 AM   #27
OldCreek
OldCreek's Avatar
You do have to work your angles, though. i.e.trans to divorced case and div case to rear and front pinions. The trans to divorced case has to have at least some angle to keep the u-joints greased. (So I've read online.)
You need to keep your angles appropriate and have the right cardan joints, etc., to keep the vibrations down and keep from wearing out u-joints. At least, that's the research I did....not sure I did it right. I sold the truck before I ever drove her.
Wil
Old 02-18-2019, 02:53 AM   #28
kwmech
Would have been nice to see that truck run down the road. Just the other day I was thinking about that.
Old 02-18-2019, 01:35 PM   #29
OldCreek
OldCreek's Avatar
I hear you.
I was just so tired. New baby, new business, no time and a garage that was packed with trucks and parts.
Old 02-19-2019, 12:30 PM   #30
77c10bowtie
77c10bowtie's Avatar
if you decide to convert the 2wd allison to 4wd then you must stand the trans up tall on its bellhousing and remove the tailshaft that way, if you remove the tailshaft housing and reinstall the new one with the trans laying down on its pan you have an extremely high chance of messing up the bearing in the back and you will not know it until it is too late and you ruin the trans.
77c10bowtie is offline   Reply With Quote
