Convert Allison 2 wheel drive into 4x4
Hello,
I am planning on putting a Chevy 8.1L into my 76 K20. The Engine/trans combo that I have available has a Allison 2 wheel drive that I would like to convert to 4 wheel drive. Has anyone else done this? Thoughts on the conversion? Computer, difficulty? What about the transfer case? Thank you. |
Post Whore
![]() ![]() Join Date: May 2015
Re: Convert Allison 2 wheel drive into 4x4
its been done..just google (Allison transmission 2wd to 4wd) sounds like just change out the tailshaft housing...parts aint cheap and that's a big ol transmission...
Thank you Greg.
I had planned on building a 496 but that didn't work out. I can get a low mile 8.1 with allison 2wd for a reasonable price. Cheaper than building the 454 into a 496. I want to run a camper and sometimes pull my boat. Looking for a "draft horse" type setup. Dan |
make sure you research the electronics side of it and the t-case you want to use to see if the computer can even be setup for the low range ratio .
the few guys i have read up on said in the end they wished they had left it 2wd control and used the t-case as its self , or did a divorced case if you have the wheel base length for that .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
I think it can be adapted to a 205 which is what I would do on any bigger motor,.
Got me wrong I like the 208 or 241 for a revvy small block where the lower gear works nicer. |
![]() Join Date: Mar 2003
Install a divorced t-case.
Thank you.
I should know this but I dont....I think I have a 203 T-case and would like to reuse it if possible. This is a long bed truck...if that helps with discussion. I see that there is a tail housing extension and an output shaft that are specific to 4x4. Are those the only 2 major components that I need? BTW, I received the 8.1 and trans yesterday. Pretty cool stuff. I am anxious to get my shouse (shop-house) completed, get the 2 post car lift installed, and really get on this swap. Thank you for the replies/information. Dan |
unless you find a rare divorced ford 203 input gear to make your 203 a divorced then good luck as there is not allision to 203 support i have ever seen . this is IF you have a 203 . what is your shifter pattern ? 4l-n-2-4high ? or do you have 2 spots that say lock ?
and long bed truck and divorced case is o.k. i have done a truck with a 4speed and divorced and had a 15" shaft between the 2 and equal length shafts front and rear .
#9 | |
Since we are snowed in today i have been spending too much time on the computer....
I found this adapter: http://offroaddesign.com/catalog/Tra...seAdapters.htm Part No. FU4092 for a Ford 205 to Allison. I assume it is because the Ford 205 requires the 29 spline? They are saying its a married combo.... |
high loc and low loc = 203 full time case unless part time kit installed .
and the ford case is if your doing driver side axle drop . our gm trucks are pass side drop . you can do married if you want but try and keep it setup as a 2wd trans or see if someone can change the low range ratio to 1.96:1 to match a np205 and run a 205 t-case setup . and then have ORD mod the tail housing for the VSS over the speedo cable .
email chuck at ORD, he can make it work with a stub shaft and spacer, that's what I'm looking at for my NP203/205 doubler to allison setup I'm planning.
'06 2500 HD 4x4. manual transfer case, crank windows. '88 V10 Suburban 4x4,"The Pig Rig" L05, 700r4, NP208, 4x4 beater camper fun truck project. My trucks don't leak oil, they mark their territory. |
#13 |
Guy on ck5 did a ord magnum kit for Allison to 205 but running vss in 205 makes stock ECM not happy with doubler ratios .
#14 |
Saw some of the ck5write up. Anxious to talk to ord as the stuff they offer is amazing! Not worked with them before. Thank you.
#15 |
been ordering from them for years . 15+ now . . . .currently waiting for the 9am open to order more today .
#16 |
Just emailed. Looks like they have some amazing parts. I am really interested i their lift kits. Very complete and a great deal of experience/knowledge there.
Thank you. |
#17 |
just placed my order .
and there lift kits can be super simple to crazy build specs . just ask them and they will build a kit to fit your budget needs . some day i would love to a full front and rear 4 link kit .
#18 |
I did find this out there.....
https://www.advanceadapters.com/prod...0-to-gm-np205/ 50-9421 : 50-9421 - Allison 1000 to GM NP205 (#50-9421) Retail Price: $578.55 |
#19 |
ya no photo's . . . .
and ord sells there kit and shows photo and less money .
#20 |
Chris from ORD got back to me with a lot of info. Great company that will take that kind of time to provide a great response! But to be honest.... I think I am even more lost....
OK, so what if I don't care about the NP 203 and switch to a NP 261? I believe the Allison is 29 spline and the 261 is 29 as well? Anyone know for sure? If that is the case...haha... then I can mary the two. Right? All this and I still have a 2wd trans that I want to modify to 4wd..... but I am more confused because Chris said I have to gut the Allison to make the switch. Or at least I think that is what he said... Has anyone ever actually converted the Allison 1000 from 2wd to 4wd? Thank you again for any and all help/ideas. Dan |
#21 |
Make sure t—case matches your front axle pumpkin position you plan to use .
#22 |
![]() Join Date: Jul 2016
You’re post isn’t getting any traction because it’s in the wrong area, post in the 4x4 section....
You will need an adapter for 29 spline to 23 or whatever the 203 transfer case is, it’s done all the time when the 203 is used as s doubler in front of the 205. I have read the Allison outpuit shaft just comes out the back....I don’t believe it tho because most trans the output shaft is buried inside the trans and retained by a snap ring. Search on google for the conversion, there is a very comprehensive Allison thread on the cumminsforum. |
#23 |
Convert Allison 1000 5sp 2wd into 4wd
Hello,
I am planning on putting a 2003 Chevy 8.1L into my 76 K20. The Engine/trans combo that I have available has a Allison 1000 2wd that I would like to convert to 4wd. Has anyone else done this? Thoughts on the conversion? Computer, difficulty? What about the transfer case? I am thinking NP 241 (Manual shift) due to the availability and electronics. Thoughts? Thank you. |
#24 |
![]() Join Date: Jan 2007
Re: Convert Allison 1000 5sp 2wd into 4wd
I used an Allison 2wd and connected it to a divorced np205. I had to have an intermediate drive shaft made up. I'm not sure it's any cheaper to do it that way...
I can't remember the computer stuff. I never drove the setup and dont know what issues with the computer/speedo came about. Wil
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() |
#25 | |
That's interesting.
Does the divorced case cause any clearance issues? I asked for and got the driveline with the engine/trans from the wrecking yard. It's a 2 piece. Dan Quote:
