Old 08-26-2025, 11:04 PM   #26
Getter-Done
Getter-Done's Avatar
Re: Side vent door - diagram?
Originally Posted by b-mac View Post
I believe this cab has the same problem I have...
Really appreciate it though!
I will say you are correct.
In the next few days I will try to find that vent door.
I am almost positive it does not have the lever on it.
The early bird gets the worm,
85 Chevy K-20
Old 08-27-2025, 11:35 PM   #27
Second Series
Second Series's Avatar
I went through this with my truck. The bracket was in the bottom of the cowl cavity. The welds were no match for the door springs, it’s a poor design. There is a hole on the vent right side channel, the bracket has an embossed shape that lines up with the hole. That gets the bracket in the right location, but it doesn’t address the angle. The way the spring is, there are two positions, open and closed. I figured the bracket on mine needed to be mounted at 55 degrees. I found out the hard way when at first I had welded the bracket closer to 45 degrees and the door wouldn’t close flush. I’m not a pro welder so I used bolts to mount the bracket. There’s also the foam gasket that goes in the channel, but with everything aligned the spring clamps the door shut. There is a picture of my 55 degree mounting template in my build thread post #167. I hope this helps.
'47 Panel to '88 K2500 Frame Swap
Mechanical Speedometer Drive Solution
1947.2 1 ton Chevy Panel
1955.2 Chevy 6700 Bus/RV
1990 Chevy K1500
Second Series is offline   Reply With Quote
