Old 10-24-2019, 03:28 AM   #26
prodjay10
Re: What to do with steam line?
Fakky, any idea what size adapter is needed for the upper radiator hose?
prodjay10 is offline   Reply With Quote
Old 10-24-2019, 03:40 AM   #27
prodjay10
I think I'm gonna go this route for ect/coolant temp gauge.
https://www.youtube.com/watch?v=wvfkIUpx8_o
Old 10-25-2019, 12:16 AM   #28
bigmoe
bigmoe's Avatar
This looks interesting. So that sender is compatible with Gen III and IV engines?
bigmoe is offline   Reply With Quote
Old 10-25-2019, 12:58 AM   #29
prodjay10
Apparently. I ordered one along with a pigtail. I'll let you know how it goes. I did read some info about having to make sure it's the proper resistance...
The coolant hose adapter needed for the upper truck hose is 34mm OD since it's ID of that hose.
Old 10-25-2019, 10:25 AM   #30
dayj1
It has the correct thread to screw into the cylinder head. However, the sender is calibrated for GM gauges from about '88 and up. Factory gauges that are older than that won't indicate the proper temp with the newer sender.
dayj1 is offline   Reply With Quote
Old 10-25-2019, 12:54 PM   #31
bigmoe
bigmoe's Avatar
My plan is for aftermarket gauges along with keeping the ECM info.
Old 10-25-2019, 11:41 PM   #32
kipps
Can you clarify? How far off will a squarebody gauge read? What about a '91 Suburban(squarebody) gauge? Is that pre-88 style, or post-88?
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 10-25-2019, 11:57 PM   #33
prodjay10
It depends but my guess is use a scan tool to see what the temp is and check the gauge. Then use resistors to calibrate.
If you search the part number and ls swap you should find the instructions.
Old 10-26-2019, 03:01 PM   #34
dayj1
Here's a good reference on troubleshooting Chevy truck gauges:
http://forum.73-87chevytrucks.com/sm...1241#msg211241
According to the document at the link above the following information pertains to the temp gauge in 79-87 trucks (or up to 91 Suburbans/Blazers/2500s/etc)
The Temp Gauge Needle Should Point to:
Left Line (Cold) when sender resistance = 1,365 Ω (100 degrees)
Middle Line when sender resistance = 96 Ω (210 degrees)
Right Line (Hot) when sender resistance = 55 Ω (260 degrees)
Here is a link to a resistance chart for an "LS" sender. There are actually 2 of these senders inside the 3 wire Camaro sender that was referenced earlier in this thread. There are senders available with 1/2" NPT, 3/8" NPT thread, or 12mm straight threads depending on the original application. Almost all GM temp senders that were intended to be used with an engine computer are electrically the same, but they were all over the board prior to that.
https://ls1tech.com/forums/pcm-diagn...l#post15884132
Here are the LS sender resistances/ temperatures closest to the gauge marks/temp that we used above:
1459 Ω = 104*
177 Ω = 212*
77 Ω = 266*
As you can see, the 100* resistance is about the same for both senders. But, when the engine is at operating temp (about 210*), the LS sender has a resistance of 177 Ω vs the factory truck sender's 96 Ω. For the gauge to point at 210* with the LS sensor, you'd have to subtract about 80 Ω of resistance from the sensor. It's kind of hard to remove resistance by adding resistors. The best bet would be to swap out the resistor on that back of the gauge that biases the two coils in the air core movement (gauge) but that's still never going to be perfect.
The simplest fix is just to tap the unused temp sender hole in the passenger side head to the size of your factory sender and use the sender that goes with the gauge.
Old 10-28-2019, 01:23 AM   #35
prodjay10
Well thanks dayj1 for raining on my parade. Jk! Thanks for the info. I think I’m gonna go with an obd2/tablet solution for speed and temps until I figure out a speedo.
