Old 09-23-2019, 05:26 PM   #1
MDPotter
MDPotter's Avatar
What to do with steam line?
I had done some research months ago on how to deal with the steam line on my engine but I'm not sure if my plan will work. I don't plan on buying a radiator that has the steam inlet and would rather not have one welded in because it will probably void the warranty. I don't quite understand what happens with the steam lines either. I bought the Dorman 47112 tee so I can tap into a heater hose line, but won't that allow hot coolant to run into the steam line? If so, is that an issue? If it's not an issue, should I tee into the return line?
I have always had this idea that the steam line was basically a vent and that it didn't have coolant running through it so it needed to have a clear outlet such as just beneath the cap on the radiator tank.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 09-23-2019, 07:25 PM   #2
sprint_9
sprint_9's Avatar
Re: What to do with steam line?
The steam line is there to help carry away any steam or air build up in the heads created from hot spots. It will have coolant flowing in it. From what Ive read is the best routing is for it to have a path to the radiator with constant coolant flow. This way any steam can be burped off with the radiator cap.
Now if I remember correctly there is something older, like a trailblazer or something that ran the steam port down by the heater hoses, I dont remember exactly where it went but it was in that area. So you would probably be ok with your plan.
I think a better alternative is tapping the back of the upper radiator hose port on the water pump and threading it for a barb. This gives it a good path to the radiator with good flow, and is nice and clean. There have been a few on here do this including myself. Here is a pic of mine.
sprint_9 is offline   Reply With Quote
Old 09-23-2019, 08:38 PM   #3
mongocanfly
Post Whore
mongocanfly's Avatar
On my C30 I ran it into the water pump as well.....on the IH I'm running it into the top radiator hose....I think as long as it's got somewhere to go itll be ok
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 09-24-2019, 09:18 AM   #4
MDPotter
MDPotter's Avatar
Thanks guys. If I end up with a radiator without a steam inlet, I'll know how to deal with it.
Old 09-25-2019, 06:23 PM   #5
bigmoe
bigmoe's Avatar
I heard it works better if it's routed into somewhere higher, especially to get trapped air out of an engine that's just been filled with coolant. I've seen many that have purchased a T fitting for the upper rad hose. Someone on here will respond with a pic and/or part source.
bigmoe is offline   Reply With Quote
Old 09-25-2019, 07:12 PM   #6
mongocanfly
Post Whore
I simply made my own
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 09-26-2019, 06:01 PM   #7
bigmoe
bigmoe's Avatar
Here is the supplier I was thinking about. Jagsthatrun.com
Old 09-26-2019, 06:53 PM   #8
MDPotter
MDPotter's Avatar
The Jagsthatrun tees are nice, but they seem pretty expensive to me for what they are. I plan on utilizing a steam port on the radiator or getting a cheaper plastic tee for the upper hose.
Old 09-28-2019, 11:47 PM   #9
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
I had a stock 454 radiator, probably same fittings and everything but the size of the core. Simply connected the steam line to the radiator on the passenger below the cap. Had it that way for 7 years as a daily.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 09-29-2019, 10:30 AM   #10
Willie Makeit
Willie Makeit's Avatar
seems a lot of folks are hesitant to drill and tap the water pump? why is that? seems the easiest to route and to make for a cleaner looking install.
Willie Makeit is offline   Reply With Quote
Old 09-29-2019, 10:33 AM   #11
mongocanfly
Post Whore
Willie...Ive found that some water pumps are very thin walled...hard to get a good thread in it
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 09-29-2019, 01:51 PM   #12
ls1nova71
ls1nova71's Avatar
I've drilled and tapped the water pump before, but my only reservation about it is what to do if that water pump ever decides to crap the bed in the middle of nowhere. I usually carry tools to change one, but dont generally carry a drill and tap. But I drive my cars, so that's why I like to keep them closer to stock so I can get replacement parts easily.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 09-30-2019, 08:20 AM   #13
Willie Makeit
Excellent point that I never thought of.
Old 09-30-2019, 03:58 PM   #14
ls1nova71
ls1nova71's Avatar
I know if you had to swap pumps, you could always cap the steam line off in a pinch, but I would just rather not have to mess with it. Maybe that's why I've never had to swap a pump out on a trip? And maybe I just jinxed myself? LOL!
Old 09-30-2019, 07:46 PM   #15
kipps
...my only reservation about it is what to do if that water pump ever decides to crap the bed in the middle of nowhere....I drive my cars, so that's why I like to keep them closer to stock so I can get replacement parts easily.
Totally agree with this sentiment. The common replacement parts of a vehicle need to be kept stock. A goal for anyone doing a LS swap, is that the drivetrain should be as easy to service and repair as the donor vehicle would have been.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 10-04-2019, 07:11 AM   #16
jnickell41
I also tapped the water pump. I also added a plastic tee that fits the heater hose to my roadside parts box. That way if the water pump has to be replaced while away, I can splice into the heater hose and have a place for the steam hose.
jnickell41 is offline   Reply With Quote
Old 10-04-2019, 03:49 PM   #17
skyphix
Before I decided to just use a radiator out of an LS equipped vehicle, I was going to use this.
https://www.amazon.com/Dorman-902-99...0218488&sr=8-4
seems weird to use VW parts on a chevy truck, but beggers can't be choosers...
Eric
1980 C10 SWB
2003 Chevy Suburban 2500 LT
skyphix is offline   Reply With Quote
Old 10-11-2019, 02:40 AM   #18
prodjay10
Wouldn’t your heater core have constant coolant flow? If I remember correctly, there is no shut off valve.
Anyone seen the four seasons version of that tee? I’m trying to find it but can’t.
prodjay10 is offline   Reply With Quote
Old 10-11-2019, 04:49 AM   #19
ls1nova71
ls1nova71's Avatar
67-72 Factory air trucks have a shut off valve as do most aftermarket AC units.
Old 10-11-2019, 01:28 PM   #20
bigmoe
bigmoe's Avatar
This is the one I bought on Ebay that I plan to use. It will allow the coolant to always circulate but allow you to shut off the supply to the heater core. I probably won't even hook up a cable. There's many versions if you search bypass heater valve but this one was pretty inexpensive.
Old 10-11-2019, 07:48 PM   #21
sweetk30
sweetk30's Avatar
ebay item # or link please .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 10-11-2019, 08:22 PM   #22
ls1nova71
ls1nova71's Avatar
That looks just like the heater shut off on an LLV, the small postal trucks that I work on every day. LOL!
Old 10-11-2019, 08:25 PM   #23
ls1nova71
ls1nova71's Avatar
HA! It is! That's too funny.
Old 10-11-2019, 08:37 PM   #24
FAKKY
IM probably going to use this for both my TEMP sensor and steam line.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Top for 1 and Ill drill and tap the flat flange for the other
FAKKY 57 PANEL BUILD
FAKKY is offline   Reply With Quote
Old 10-11-2019, 09:56 PM   #25
prodjay10
FAKKY I like it. Thanks.
That way I can put a valve on the heater core if I have to.
