Old 10-25-2019, 10:51 AM   #26
mobileortho
mobileortho's Avatar
Re: Welding question
On the subject of reinforcing that section; wouldn't it make sense to take the piece that was cut out, flip it & use to box that area?
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 10-25-2019, 02:21 PM   #27
mongocanfly
Post Whore
mongocanfly's Avatar
I assume your talking about the frame....
when I did my C30 that's the way I did it
On the IH I did a fish plate on the outside and a small piece of old frame on the inside across the bottom of the frame rail
You can see how I did it starting at post 112-114......
http://67-72chevytrucks.com/vboard/s...=750501&page=5
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 10-29-2019, 01:04 PM   #28
mobileortho
That looks great Mongo! I was referring to using the entire section that was removed and just flipping it around to box it but I like what you did.
Robert C.
1950 3600
Old 11-24-2019, 05:25 PM   #29
mobileortho
The Lincoln did the trick! Everything went together pretty good. I used the section that was cut out to box the area for additional strength.
Robert C.
1950 3600
Old 11-24-2019, 06:48 PM   #30
mongocanfly
Post Whore
Thatll work..!!
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 11-25-2019, 02:31 PM   #31
mr48chev
mr48chev's Avatar
Just thinking about it a good number of the older brigade here can remember when you were in tall cotton if you had a 225 Lincoln (red tombstone one not the brown one) in your home garage and a torch with a welding tip to do the sheet metal welding.
Flux core wire feed is pretty much on the same line as stick welding except you don't have to change sticks every minute or so. The best thing about it is that you can weld in the wind outside if you need to and if you are fabbing or repairing something that needs to be strong but doesn't need to be show quality it works pretty good.
I wonder how many guys on here have never had a chipping hammer in their hand to chip the flux residue away from the welds that were done with a stick welder. Some of the younger guys go into as much a panic when you say stick welder as when you say flux core.
My ongoing truck projects:
mr48chev is online now   Reply With Quote
Old 11-26-2019, 12:22 AM   #32
svr
svr's Avatar
Grew up on 7018ac and 6011, still used out in the field
57 short box, 235, T5, C4
http://67-72chevytrucks.com/vboard/s...d.php?t=739132
svr is offline   Reply With Quote
Old 11-26-2019, 03:09 AM   #33
bobinbc
bobinbc's Avatar
This is the exact way I shortened the frame on my old 57 almost 20 years ago, and with a 110V Lincoln wire feed welder too! Still working great
1962 Chevy blue SBFS
1957 Chevy yellow SBSS
1956 GMC red SBSS Nov 2017 ToTM
https://www.facebook.com/groups/Cana...geChevyTrucks/
bobinbc is offline   Reply With Quote
