10-18-2019, 10:01 PM | #1 |
Welding question
Thinking I'm going to go ahead and shorten my 3600 as I've always wanted a short bed. I won't attempt this myself as I realize my limitations. I have a family member who welds for a living who told me my flux core welder would work fine for this but I'm unsure. He says welding both sides would give plenty of penetration but I need reassurance. Thoughts?
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. |
10-18-2019, 10:41 PM | #2 |
Post Whore
Re: Welding question
I personally wouldnt use flux core...I use only gas shielded....flux core will work but it's not the better choice
Using gas is cheap enough and cleaner that it shouldn't even be a question...do you already have a mig? Are you going to cut and shorten the bed as well? Or use diff bedsides
10-18-2019, 11:10 PM | #3 |
If youhave a welder buddy available then he would also, assumably, would have access to a real mig welder. Think ofitthis way. If youtookthe frame tla welding shop would you want them to weld your frame witha flux core?
Nuff said. Real gas mig is the way to go. My opinion. |
10-18-2019, 11:26 PM | #4 |
flux core 220V? I would do it
flux core 110v? I would not. flux core actually works really well on thick material that is cleaned very well and has a good bevel, frame work is textbook flux core work but make sure your gaps are tight, you dont want to try to fill gaps with flux, MIG works better for that. Also I would use multiple passes, knocking slag between, and weld inside and out, and use a reinforcing fish plate over the joint. here is a multi pass vid, you will butt weld instead of use a backer but this is the general idea
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 Last edited by joedoh; 10-18-2019 at 11:39 PM. |
10-19-2019, 07:00 AM | #5 |
I assume you are talking about the frame? and not the sheet metal of the bed.I myself would not use flux core wire.I have shortened a few frames in my time and have alway used solid core wire.When I did my friends frame he had a little 120v welder,it worked a little just for a couple tacks. I brought my bigger miller welder over to finish the job.The Miller welder cost me over a $1000.00 and it was needed to do the job right.There are many different ways to weld,and there are many way to do this job.it all depends on what you are look for.
10-19-2019, 09:02 AM | #6 | |
10-19-2019, 09:04 AM | #7 |
He works at one of the shipyards but doesn’t have one himself.
10-19-2019, 10:12 AM | #8 |
On a related topic, what do you use to clean the metal, acetone, lacquer thinner?
10-19-2019, 10:55 AM | #9 |
Post Whore
I wouldnt do the bed sheetmetal with flux core...it will be a nitemare....the flux will contaminate the welds ...you will be spot welding the seams as you go....not a continuous weld.. and grind,hammer and dolley as you go
Theres a reason why you dont see fluxcore welding in the industry... Have you ever welded any body panel sheetmetal before? For metal cleaning about all I do is grind or sand the surface...and then weld...I dont use any liquid cleaners...I know on aluminum they use alcohol to clean it prior to welding...
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 10-19-2019 at 11:04 AM. |
10-19-2019, 11:36 AM | #10 |
Yep, no flux core.
On the shortening, I hope you are planning on drilling out the spot welds on the stake pockets, then simply cutting the bed side to the desired length then plug welding the stake pockets at the new length. Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
10-19-2019, 02:12 PM | #11 |
In the right hands with the right size welder flux core is every bit as strong as solid core with gas.
It's also good for tacking things together so who ever does the final welding just has to run beads and not have to fuss with getting things lined up. I've got a cheapie stick welder that is more of a carbon arc welder out in the shed that I used to tack things together with and then carry down the street to my buddy to have him weld up with his 225 Lincoln. We pretty well built my T bucket frame that way. I'd be a bit concerned as to who made that welder though as if it a Hobart or other name brand you should be ok but if it harbor freight you may not get the quality of welds you need. These days though most guys gripe against flux coated or stick welding for that matter is that unless you have some serous skill the welds don't look pretty and take a lot of cleanup On the bed sides cut the spot welds and move the posts as Martinsr suggested. That is hours and hours less work and no worries about warping the panels.
10-19-2019, 02:34 PM | #12 |
Yep!
10-19-2019, 08:26 PM | #13 |
I would guess very little mig welding is done in the shipyard, and more likely, if used, it's gas. Smaller Mig Welders are relatively inexpensive and there is a fair market for used ones, if this is a one time project. Gas is the best choice.
10-20-2019, 01:24 AM | #14 | ||
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. Last edited by mobileortho; 10-20-2019 at 01:33 AM. |
10-20-2019, 10:42 PM | #15 |
Found this on the Lincoln Electric site:
Flux-Cored The flux-cored process is only recommended on materials as thin as 20 gauge, a bit thicker than the 24 gauge we said for MIG. In general, this process is best for welding thicker materials with a single pass, especially if you need to weld outdoors such as to repair a tractor out in the field. A 115 volt flux-cored machine using an electrode such as .035" Innershield NR-211-MP will generally allow you to weld steel up to ¼"thick. Note that this is more than double the thickness maximum of 12 gauge with MIG on 115 volts. With the proper electrode on a proper machine, such as .045" Innershield NR-211MP, and a 230 volt input machine, you can weld steel up to 1/2" thick. Note that Innershield® NR-211-MP requires that the machine be setup for DC negative polarity.
10-21-2019, 12:50 PM | #16 |
I was curious as never heard of gas mig over flux core for any reason other than aesthetics.
These guys say ..... flkux core. https://weldingweb.com/showthread.ph...ructural-steel "GMAW in its basic form is known as a cold process and doesn't have the heat input as FCAW or GMAW-S ."
FAKKY 57 PANEL BUILD |
10-21-2019, 05:24 PM | #17 |
Just picked up this used Lincoln for a good price. Says it’s good for up to 5/16” thickness so I should be good.
10-21-2019, 10:00 PM | #18 |
Good choice. Also note that some alloys of mig wire are easier to grind than others. For body work I use "EZ Grind" which is still plenty tough but grinds a *little* easier. Maybe some professional welders can chime in here??
10-22-2019, 03:13 PM | #19 |
ogre has an older lincoln weld-pak 100 that did all the welding on my frame and all the bed mods on 58 truk
my 120volt weld-pak is fluxcore only, it will do 1/4" steel with no problem 1/4" thick mustII xmember was welded in with this welder spring pads welded on axle, brake hydroboost bracket welded i also welded many patch panels into my son's 68 elco you see behind truk nice thing about fluxcore is you can weld outside if needed without the shield gas blowing away: fencing, gates, signs i've carried it up a ladder to weld on bar joists in commercial building, try that lugging a gas bottle very portable if and runs on my generator for side of road repairs fluxcore is easier to use and has a better weld in the hands of a knowledgeable welder or the novice welder oem uses fluxcore to weld on spring pads and hub flanges for most trucks, using a 400 amp power source
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
10-23-2019, 04:31 PM | #20 |
Ogre, I can't wait to get started! Thanks for the info!
10-23-2019, 05:35 PM | #21 | |
given all the lucid and qualified responses I would like to change my statement to: flux core 220V? I would do it flux core 110V? I would do it. good luck mobile!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
10-23-2019, 09:12 PM | #22 |
When shortening the frame rails, do a Z cut for better strength.
10-24-2019, 02:04 PM | #23 | |
but... you always want a gap on welding and grind a bevel on any metal the gap allows you to control puddle and penetration of the weld a properly done weld from one side should have a good look bead on both sides these sheet metal clamps hold a perfect gap for thin stuff i find that fluxcore is very forgiving on less than clean metal it will burn most rust, paint and oil out and still give a very good weld multi pass welding is crucial for any welding method: fluxcore, mig, tig or stick even 10 gauge steel on a critical application should have a root pass, grind and cover pass i learned to weld on pipe, no going in to weld the backside
10-24-2019, 03:57 PM | #24 | |
10-24-2019, 04:33 PM | #25 |
A wealth of knowledge here and all of your replies are much appreciated! At one time, my son was interested in becoming a certified welder so I took him over to the local Community College to look at their program. The instructor told me that they also had a 5 for $50 course offered on weekends for beginners. That's 5 hours of instruction for $50. The little welding that I've done has been self taught (and looks like rat turds!) but I may take that course myself just to learn how to do it the right way. Not that I plan on doing a ton of work, but more so for the knowledge gained.
