#26 |
Re: Where do I even start
#27 |
Well I went to mom and dafs this morning to get a good lool over the truck. Good news is the floor pand are not rusted out and only the passenger rocker panel will need to be replaced. There is a spot in the bed floor that had about 4 holes from rust and there is a support heam underneath the holes that is rusted out. Not too bad. Dad decided he wanted to take the bed off and start doing some body work. I guess we are going further into this than I originally thought. That is fine with me. He will start working on the bed while I start working on the mechanicals starting in the rear. New springs, shocks, wiring, brake lines, bushings and brakes are going to be in order as well as a rear end rebuild. I'm going to have my hands full but its going to be fun getting to take this on with my dad. I need to do more research on what rear end I have and where to buy rebuild parts. Also a lot of research on brakes. Also will need to clean up the frame somehow and paint it. I was thinking a wire brush wheel might work pretty good to clean the frame. Any ideas here? Here are a couple of pics from today.
#28 |
Do a search for posts on POR 15.
#29 |
For the love of all that is even remotely holy please do yourself a favor and keep it original, at least until its up and running. That paint will have the absolute perfect patina after the CLR treatment. Just get her shining, meticulously clean the interior, and engine compartment then do a full fluid swap, empty the gas tank before you try to start it up, make sure it runs, shifts and stops well. If you still have time to work on it before you go back to work then address any rubber that needs replacing, like door seals and cab bushings.
You have a special truck there for sure. Not just because of the obvious rarity and condition of the truck, but the chance to do this with the man who put all the miles on it. I have no idea about the relationship you have with your dad, but I'd give my eye teeth to have had that chance. Such a great truck man... ![]()
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
#30 | |
#31 | |
Wire wheels on a drill work well for stripping the frame/suspension parts. They also sell a DIY sandblast set-up now the uses water-pressure w/sand media for road grime clean-up. Google 'Dustless Blasting' after the CLR process. And.... White or Lt Gray Scotch-Brite pads for the painted surfaces; 0000 steel wool for trim for the CLR process.
#32 | |
#33 |
Understood. That additional background info makes a HUGE difference vs. someone slingin' a rattle can w/o understanding things.
#34 | |
We got our truck in January, drove it off the trailer and in to the garage and started tearing apart. Been frustrating seeing a partially built truck out there ever since. Finally starting to put things back on the cab and the frame/drive train is almost completely reassembled. Actually just got the exhaust in today. It would have been much more fun to do it piecemeal and be able to enjoy driving it over the past several months. |
#35 | |||
How about setting up a build thread? Brian
#36 | |
#37 |
Here is a quick update. I now have the frame cleaned and treated. I have been working on the front end and now have everything to heat the control arms and steering components back on. I also have a disc brake system I bought for the front as well as brake lines. I alsopicked up some 15x8 rally wheels today that I am going to steip down and refinish. Dad has been working on the bed still a little at a time but we are still having a great time doong this together.
#38 |
Looking good. Keep at it
1971 C20 Longhorn 350/350 "Conquistador" |
#39 |
Here is another quick update. Got most of the front end put back together minus brake lines and steering components. My CPP disc brake kit I got from summit fit beautifully with no issues or mods required. I'm starting to get excited. Also I am very happy to report that my 15x8 rally wheels clear everything great.
