05-25-2021, 05:41 PM | #26 |
Re: Converting 2WD Heat Stove to 4WD
Question ? I tried to remove the heat stove from my 307. Got the small sheet metal screws loose but no luck with the nut down low ? It’s never been off ever ? Been soaking it with PB but still stuck tightly.
71 C-20 07 Magnum RT AWD |
05-25-2021, 06:03 PM | #27 |
Put some heat on the nut. It will expand and break loose.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
01-28-2024, 03:12 AM | #28 |
Thought I'd add these pics I found online of a NOS heat stove P/N 3982954 which is also finished in black.
01-28-2024, 09:28 AM | #29 |
I'm trying....
What a great pic. Thanks Chris.
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
01-29-2024, 02:55 PM | #30 |
Thank you for the pic. That's the way I restored mine, with the satin black outer and bright plated inner. I was going by the very low mile 1970 that has been pictured here in the past.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
01-30-2024, 02:21 PM | #31 |
I noticed in a few photos the flexible oil dipstick ? The one in my pretty original 71 307 with power brakes has it sticking straight up ? Also has the oil fill pipe , you have to be Houdini to get it out, nearly impossible to reinsert.
Tags |
4x4, exhaust manifold, heat stove, riser |
