#26 |
I'm trying....
![]() Join Date: Oct 2013
Re: WTB: 1970 4-bolt 350 long block
That is a really good idea. Thanks for the suggestion. I'll keep in mind as the search goes on.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
#27 |
![]() Join Date: Aug 2009
well i just sold my 70 original 350 to an engine rebuilder and he had texted me last week if i would like to buy back when finished and keep mine numbers matching, the front stamp is V1201TAX , not sure if thats the right date code for you Cheers and good luck hunting
72 Chev Cheyenne Super SB 4x4 350,4spd,buckets, tilt,tach,am-fm,extreme tow hooks,Canadian Model Production 1 of 52 SOLD 70 Chev CST, 350 auto, PS, PB, AC, tach |
#28 | |
I'm trying....
#29 |
Ill have to get a hold of him and ask, i was always under the impression it was a 4-bolt main, and it did come out of a 70 1/2 ton , it was an Oklahoma truck born in the Fremont factory and it mades its way to Canada in 2009
#30 |
I'm trying....
I don't know what the rules were for 2 vs 4 bolt mains. And as with all these things I'm sure there were exceptions or aberrations. What I am assuming (based on anecdote) is that all 3/4T and up were 4 bolt mains. I would tend to think that K trucks would be 4 bolt as well...but again...I don't know it.
Regardless, my hope is to find a 4-bolt version for my project.
#31 |
I'm trying....
Still on the hunt. Thought I was very close on a couple, but unfortunately they didn't check out. Looking at C/K20s, C30s, C40s and C50s as potential donors.
#32 |
![]() Join Date: Sep 2016
Here's one in Kansas. I messaged the owner, he says it's a 1970. It's in a C50 grain truck, so you're getting the manual transmission fan blades, a two barrel intake, and 2wd exhaust manifolds. I haven't been able to find a way to reliably determine whether they're a two bolt main or a four bolt main without pulling the oil pan. I'd be happy to help get it crated and shipped if you wanted to pursue it. https://www.facebook.com/marketplace...rral_code=null
You ever have one of those mornings where you wake up owning more trucks than you did the night before? 1972 K5 1972 K10 1967 K20 bucket truck |
#33 |
![]() Join Date: Dec 2014
I have a 1970 350 four bolt main in my SWB, I ran the numbers and it came out of a 3/4 ton. It is presently in my truck and running, I was gonna pull it next spring and install a crate engine.
I will have to check/locate the date codes again and see if it lines up with those months, when I ran the numbers a couple years ago out of curiosity I promptly forgot them. I shipped an engine from Nebraska last month, its not that expensive really.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
#34 | ||
I'm trying....
#35 |
I'm trying....
Kansas 350 is gone. Oh well....I'll assume it was the wrong date. Onward.
#36 |
![]() Join Date: Aug 2019
I have a lead. #3970010, V0616TAX. Where do I look for the build date casting?
#37 | |
I'm trying....
The TAX suffix means that it is either a 1970 or a 1972. It was built on June 16th. To confirm the year, look on the back, driver's side, there will be a casting number that is either F162 or F160. If it is F160, then it's a 1970.
#38 |
I'm trying....
Here's a quick ref pic I grabbed. Engine pictured was cast on April 23rd, 1974.
#39 |
![]() Join Date: Dec 2013
Try this guy I found using searchtempest.com .
He builds and sells small blocks but also sells short blocks and parts . https://wilmington.craigslist.org/pt...352982320.html Also there are a few used parts dealers in the Murfeesboro area that are scrapping trucks . I'm still looking but this is crazy 350 4 bolts used to be everywhere . ![]()
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#40 | |
I'm trying....
#41 |
Bingo ! 350 / 4 bolt / 0010 / drivers side dip stick this could be the one ? just up the road from me about 20 miles ,If you don't want it I may buy it . $200.00
https://www.facebook.com/marketplace...Anull%7D%22%7D
#42 | |
I'm trying....
#43 |
I'm trying....
TN 4 bolt was gone. It was a good deal.
#44 |
I'm trying....
Still on the hunt.
#45 |
#46 | |
I'm trying....
According the database that I use for decoding these suffixes though, TRJ is a '72 code. Maybe a misread if not an engine swap?
#47 | |
Posted via Mobile Device |
#48 |
![]() Join Date: Nov 2018
Man I thought I posted before. Get in touch with “uncle” I know for a fact he has a 70 350 because I took it to him. Just not sure if he sold it or not
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
#49 | |
I'm trying....
I think I may have found a match this evening in TN. If nothing changes, heading up there on Sunday. Numbers check out and looks the part. Hopefully no defects or fouled internals. But I'm not calling it good until I've got it in hand and apart. I'll post here once I know for sure. Fingers crossed.
#50 | |
