I'm trying....
![]() Join Date: Oct 2013
WTB: 1970 4-bolt 350 long block
OK guys...I'm going on a bit of a fishing expedition for a reasonably correct replacement engine for my 1970 K20 built in June of '70.
Baseline Goals 1) 1970 350 4-bolt mains (with correct heads) engine casting 3970010 2) Build date casting between Jan-May 1970 (AXX0-EXX0) 3) Buildable engine (no known cracks, over bore, etc) Bonus (not required) 4) Suffix stamp TAY 5) Within driving distance 6) Complete engine with brackets/fan No real expectations here. And cost/shipping will be a consideration. But after a bit of searching...figured it can't hurt to ask. Thanks, Brad
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
![]() Join Date: May 2011
Re: WTB: 1970 4-bolt 350 long block
I have a 350 I picked up a couple of months ago, I'll check it out and let you know.
I'm trying....
Thanks Dwayne. Fingers crossed.
Brad,
Facebook Marketplace is where everything is sold now instead of Craigslist... I just picked up a date coded motor for a 67 project... I searched auto parts and autos..... was even looking to buy a complete junk car to get a dated motor. Good luck with your search. Stuart
1970 2WD Blazer 454 1972 C-10 Extended Cab 350 SBC |
I have the casting but looks like a 71
#6 | |
I'm trying....
Thanks Dwayne. Just out of curiosity...have you pulled the pan? Is it a four bolt? Edited to remove a stupid question. Obviously it was put together on Feb 17, 1971.
![]() Join Date: Dec 2013
I'll ask around I found this one a while back for $300.00 .
![]() http://67-72chevytrucks.com/vboard/s....php?p=8106706 It looks a little different now .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#8 | |
I'm trying....
I can pull the pan if you decide your interested in a 71. I remember Eric looking for a 70 block for a blazer a few years back and believe he had trouble finding one.
#10 | |
I'm trying....
I'm going to keep looking. But if you had a moment in the coming weeks when you were inclined to pull the pan...and it was a 4 bolt...it wouldn't be a bad fall back position at all from my point of view.
OK, I'm up against it, trying to get a Jimmy ready for truck Carlisle which is the first weekend in August. If you don't find anything by then, I'll pull it and see what's under there. It has flywheel to water pump has a pulley but no fan. Carb to oil pan but no air cleaner or spacer. Distributor, coil and exhaust manifolds all that's there.
#12 | |
I'm trying....
Best of luck on the Jimmy.
#13 |
![]() Join Date: Dec 2003
#14 |
#15 |
![]() Join Date: Nov 2014
I think I have one or two in the shop. One out and one in a 70 Blazer. Both complete. Located in Colorado Springs, CO.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
#16 |
I'm trying....
Sorry I missed this post. PM sent.
#17 |
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count Last edited by SoCoC10; 07-19-2021 at 10:02 PM. |
#18 |
I'm trying....
Thanks Troy. But I read that as K0331CPA. Which translates into:
K: Ontario built 0331: March 31st CPA: '76 X and F body or '80 G body cars So I'd pass on that one. But still interested in the other if it matches up.
#19 |
And the other one out of a 1970 Blazer is a “Hecho en Mexico”. Sorry I couldn’t be of help. Good luck w/your search.
#20 |
I'm trying....
No sweat. Thanks for checking!
#21 |
Out of curiosity, not that I'm looking to get rid of it, but I looked at my stamp on my new rebuild that is on the stand waiting to drop in. Sort of felt bad for you though as it seems to match. It's the original motor for my truck. So, they're still out there.
V0415TBC Other block I have was not what you were looking for. |
#22 |
I'm trying....
Well I am a bit jealous, but don't feel bad for me. Lotta really nice folks on this board have kicked a few bushes on my behalf and wouldn't you know it, some potential solutions have popped up. Just waiting to see which one pans out. I'm pretty confident one of them will.
#23 |
Junior Member
![]() Join Date: Jun 2019
I have 2 motors 1970 I just haven’t had time to check the numbers, one is out and rebuilt from previous owner and the other one I will be pulling out from the truck this weekend if weather permits, I will check for you sir
#24 |
I'm trying....
Thanks!
#25 |
![]() Join Date: Sep 2016
Have you thought about buying an old C50 grain truck with a 350? They never got driven more than a few hundred miles a year, most of them are completely original. Around here they sell for about $1000.https://www.facebook.com/marketplace...d-0fe686c0c504
You ever have one of those mornings where you wake up owning more trucks than you did the night before? 1972 K5 1972 K10 1967 K20 bucket truck |
