Old 01-02-2004, 12:03 AM   #26
mikeoj
Another 14 bolt conversion: http://cgi.ebay.com/ebaymotors/ws/eB...763&indexURL=1
http://cgi.ebay.com/ebaymotors/ws/eB...category=42605
I saw some rebuilt calipers/e-brake for $110,But has since expired(no bids) on e-bay.Also say some used for about half that.
69 Lwb C-10 402/700R4
70 Lwb C-10 250/3pd
Wisc.
mikeoj is offline   Reply With Quote
Old 01-02-2004, 01:13 AM   #27
Shane
Shane's Avatar
Originally posted by ozarkhippie
Anyone know how much rebuilt caddy calipers with the e brake cost?
If I remember correctly, I paid about $79 each for rebuilt Caddy calipers ... BUT, the core charge is $50 EACH caliper. You will need to find a GOOD set of calipers, with brackets and that does not have the piston stuck in order for them to be rebuildable.
EDIT - I did a seach on NAPA Online and found this for ya ... looks like the core charge has gone up quite a bit.
1977-79 Caddy Left Rear Caliper - Remanufactured
1977-79 Caddy Right Rear Caliper - Remanufactured
1977-79 Caddy Seville Rear Rotor
Hope this helps ...
Shane is offline   Reply With Quote
Old 01-02-2004, 02:27 AM   #28
gonebad2
Merciless Butcher
gonebad2's Avatar
88 4x4 Rotor
Gonebad you said you use the rotors off of a 71 to 87 k10. Do the plans say anything about machining the axle? I have emailed the guy you got your plans from but havent got any answers. I was trying to see what parts are needed before I jumped into some thing that is going to cost me too much.
Hey Ozarkhippie, My bad, it says to use a 1988 GM Light Duty 4x4 Front rotor. It says nothing about machining the axle but it does sy, in addition to having the bolt pattern changed to 5 on 5 for a 71/72, the center hole in the rotor needs to be opened up to 3-9/16"...
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 01-02-2004, 03:11 AM   #29
rin68
rin68's Avatar
Here's some pics of the rear disc setup i used. It uses 77-79 Caddy SedanDeVille rotors (had to turn the axle flange down), GM "metric" front calipers, and a backing plate from Steeltech Solutions (he sells these on ebay). I think rear calipers from a 82-92 4wl disc camaro or some caddy calipers would work if you need an e-brake. The rotors are 5x5 and are some stout pieces. I've only had this setup on for a couple weeks now, but it seems to stop real well. Front brakes are stock 71-72 discs. M/cyl is the Classic Performance Products master cylinder/booster/and proportioning valve for a 4wl disc. So far the prop valve seems perfect out of the box, but I'll have to drive it some more to be sure.
Cost: Brackets $80, these could be fabbed easily by someone with the right equipment; Calipers $21/ea no core; Rotors $60/ea; Pads $25; Machining on axles $Free (coworker has a lathe) but should run about $30. I ran new braided steel lines everywhere because I was rebuilding the whole brake/susp setup. oh and the CPP booster/m cyl./prop valve was $399, ouch but it's top notch quality
1968 C10 - 383, non-stop project
1969 Camaro - 327, bone stock family heirloom...soon to be LS/T56, Ridetech, all the goodies
rin68 is offline   Reply With Quote
Old 01-02-2004, 03:33 AM   #30
drink2mny
drink2mny's Avatar
Originally posted by rogf4
I am building an 80 model crew cab 4x4 with 14 bolt ff rear end anybody have any disc brake setup ideas for this rear end
I would love to sell you a kit we make(check signature)
But you can if you want check out pirate4x4, oh yeah it is a link through my site. go to there forum and search 14 bolt.
tons of guys have put up diagrams for it. would however not recomend welding or using spacers for your caliper brackets.
I have seen both break offroad..But not our kits
Are the bolt patterns the same on a 12 bolt in a el camino and your 1/2 tons???
because if it was, we used corvette rotors and used either 1/2 or 3/4 ton chevy backing plates. just trimmed one bolt hole off and bolted it on. fit 15 rim no problem
Support The Board
drink2mny is offline   Reply With Quote
Old 01-02-2004, 04:04 AM   #31
gonebad2
Merciless Butcher
gonebad2's Avatar
I think I will go with the Caddy rotor and the Camaro caliper.... been a great thread. I noticed someone mentioned using Corvette rotors. They might work but they are pricey because the internal part of the hub is machined like a small brake drum. Corvettes use a very small ineffective set of brake shoes for a parking brake inside the rear rotor. I have owned a couple of Corvettes and the parking brake is pretty scary. Chevy would never stick their neck out and call it an EMERGENCY BRAKE and specifically called it a PARKING BRAKE in all of it's publications. There is no way in hell that setup on a Corvette would work if there was a brake failure and you needed an EMERGENCY BRAKE. This has been an excellent thread. I'm glad I started it. Hopefully some of us guys can put together a set of rear discs without having to shell out big bucks.
Old 01-02-2004, 10:22 AM   #32
ozarkhippie
thanks Gonebad. The guy emailed me the answers to my questions. He said his will clear the 15 inch wheels its his 14 bolt kit that wont. I think I will try a set. I got a good used set of caddy calipers last night and I have a almost new set of 92 front rotors, and some new 3/8 flat iron so I'm almost set. I need to do a complete rear brakes on a 72 so I can do this as cheap.
Buy Sale or Trade
71 3/4 4x4
72 1/2 ton cheyenne 4x4
ozarkhippie is offline   Reply With Quote
Old 01-02-2004, 11:06 AM   #33
rogf4
Thanks for all the info guys have most of the parts mentioned lying around so I can go a couple of differant ways Hey Gonebad2 I am glad you started this thread as well
rogf4 is offline   Reply With Quote
Old 01-02-2004, 12:12 PM   #34
slam33
slam33's Avatar
I have the 77 Seville set up. 12" rotors, offset backing plates (rotors point front on left , rear on right )and e-brake calipers. I know the discs will not fit the axles without turning them down becuse I have a set of shafts off the truck. Looks like a 1/8 has to come off, could do that with a grinder when the axles are in and turning in the housing. As for the backing plates I know I have to redrill them. I could use a housing off the truck to do that set up. I got the whole setup for $100 at the bone yard.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 01-02-2004, 02:17 PM   #35
gonebad2
Merciless Butcher
gonebad2's Avatar
Thanks guys....Let me know how it turned out.
Old 01-12-2004, 09:54 PM   #36
ozarkhippie
I got my plans for the brackets today. It says to use 83 camaro calipers for emergency brake. I have used those calipers before on a previous project and the emergency brake cables don't both face forward one faces to the rear. Does anyone know of another rear caliper that will bolt up the same as the 83 camaro and has a emergency brake.
Buy Sale or Trade
71 3/4 4x4
Old 01-12-2004, 10:00 PM   #37
dinnut
dinnut's Avatar
why would the ebrake face cable mount face backwards? sure you didnt have em reversed or something?
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 01-12-2004, 10:03 PM   #38
ozarkhippie
NOoooooooo 83 camaro rear calipers are either right or left not for a particular side
Buy Sale or Trade
71 3/4 4x4
Old 01-12-2004, 10:06 PM   #39
dinnut
dinnut's Avatar
oooh. but it still doesnt make sense for one to be backwards? unless the camaros were just weird like that
70 longbed
496/th400/Ford 9"
Old 01-12-2004, 10:16 PM   #40
zenish
my 89 camaro has drums,but the cables are like that ,one side front,one side rear.
zenish is offline   Reply With Quote
Old 01-12-2004, 11:53 PM   #41
junkyardjohn
junkyardjohn's Avatar
DINNUT --- SEVILLES ARE LIKE THAT ALSO. HOW ABOUT ACTUALLY READING THESE POSTS, & MAYBE LEARNING SOMETHING ABOUT THE SUBJECT, INSTEAD OF REPLYING WITH INCORECT ADVICE. IT'S NO WONDER YOUR POST COUNT IS SO HIGH FOR THE SHORT TIME YOU'VE BEEN HERE. JOHN
( A WISE MAN ONCE SAID.... IT'S BETTER TO REMAIN SILENT & HAVE PEOPLE THINK YOUR STUPID THAN TO OPEN YOUR MOUTH & REMOVE ALL DOUBT)
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 01-13-2004, 02:28 PM   #42
Grim Reaper
Originally posted by jorgensensc
I checked those plans before. When I spoke to him he told me it wouldn't fit a 15 inch rim. This is the same problem I keep running into.
You know why? because they are set to deep into the rim. If you machine the center of the rotor and install the disc on the back side of the flang it works fine.
I worked a little with
AZ-Kickin on their disc brake kit. a few problems that were discovered along the way is the offset using a top hat style rotor off say a newer GM truck and clearing 15's. We also found that there are problems with mounting off the stock flange. That flange is about guaranteed to fail given enough time or it's going to shear the bolts. My truck and Robzilla's 72 Blazer were the test muels on the 12 bolt set up. Rob has a doubler and was snapping off bolts and axle flanges.
AZ Kicking ended up including a weld on bracket to put the brake adaptor plate into Double shear to correct for the problem. as far as I know they are the only company that has done that. Some companies went with a full peice like the one list in the first post but it still has the potential for problems. Disc's can put a twisitng force on the flange the drum didn't. That stock flang is insuficient.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 01-13-2004, 02:39 PM   #43
Grim Reaper
Originally posted by 383 Stroker
Here is a picture of the backing plate.
Not a bad set up but loose those bolts. The stock bolts on the drums exceded grade 8. Them Chinese bolts you got on there are not going to cut it.
Grim-Reaper
Old 01-13-2004, 03:09 PM   #44
383 Stroker
383 Stroker's Avatar
Grim Reaper, I used Lawson grade 8 bolts. Those bolts were just some I used when I was checking the fit of the backing plate.
Video's of my Truck Racing
1967 C-10, 383ci Sbc, TH350, 3200 stall, 3.73 gear
383 Stroker is offline   Reply With Quote
Old 01-13-2004, 03:18 PM   #45
Grim Reaper
Grim-Reaper
