Merciless Butcher
67-72 Rear Disc Setup
The other day, just for the heck of it, I purchased a set of plans for a rear disc brake setup from a guy on ebay. The plans were drawn on autocad and are excellent. The detail and simplicity is extraordinary. The entire setup is drawn to scale and templates are provided to cut mounting brackets. All you have to do is transfer them to 3/8" plate and cut them out. I should be able to do it no problem with my plasma cutter then some light cleanup afterwards. The plans also include a very comprehensive set of instructions and a complete summary bill of materials. All of the parts are "off the shelf GM parts" that require no modifications. You even get a rear e-brake. A buddy of mine already made a set of rear discs up for me, but I think I will go with these. The cost of the parts shouldn't be over a few hundred bucks. Here is the link if any of you guy's are interested.http://cgi.ebay.com/ebaymotors/ws/eB...tem=2450216153
The auction lists it for an '87 but I spoke with the vendor and he said it will work on a '71/'72 rear end no problem. A guy I know makes Harley parts and I will have him chrome the brackets when they are done. It will be a little while, but I will share pics when I get them done. Just thought I would share this with you guys. It looks pretty good for a rear disc setup for a reasonable price.
Your Bought And Sold....I Got Your Soul! |
![]() Join Date: May 2003
Rear Disc Brakes
I've been researching differant rear disc set-ups and that does look like a nice one. You said that all the parts are off the shelf GM parts that need no mods. Does that include the rotors??
I haven't been able to find rotors that would fit over the axle without machining and or drilling holes to accommodate a six lug bolt pattern. I think that would be a great advantage to be able to replace rotors with off the shelf ones. Gary |
Gary, I would try front rotors from a 71-87 K10. I know that will have the pattern you need.
67-72 Addict!
Some people have used Lincoln or Caddy rears I thought to get the disc brake setup I believe.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Front Rotors
I've tried a set of front rotors from a mid 70,s K10, but they wouldn't fit over the axles without machining either the inside of the rotor and or the outside of the axle flange. If the lincoln or Caddy rotors will fit over the axle flange then drilling new holes wouldn't to bad.
![]() Join Date: Aug 2001
![]() I'VE GOT A 9" FORD REAREND OUT OF A 76 LINCOLN MK4 (I GOT IT COMPLETE OUT OF A BONEYARD FOR $85) IT HAS A 5" ON 5" BOLT PATTERN, DISC BRAKES & AN E-BRAKE. IT'S IN THE SHOP RIGHT NOW. I TRADED A BUNCH OF PARTS TO A BUDDY OF MINE FOR HIM TO REBUILD A POSI UNIT, & INSTALL ALL NEWCLUTCHES, BEARINGS & SEALS IN IT. HE'LL ALSO REMOVE ALL THE PERCHES ON THE TUBE. WHEN I INSTALL IT ..... I'LL HAVE TO SET THE PINION ANGLE, & WELD ON NEW PERCHES & MOUNT A PANHARD BAR (ADJUSTABLE). ![]() ![]()
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 12-31-2003 at 02:56 PM. |
I checked those plans before. When I spoke to him he told me it wouldn't fit a 15 inch rim. This is the same problem I keep running into.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
#8 | |
Merciless Butcher
I'm in the process of installing rear disc brakes on my truck. It's the same setup that is on a mid 90's Impala SS. I had to make the backing plate.This disc brake setup weigh's 25 lbs less then the old drum brakes. Here is a picture.
Here is a picture of the backing plate.
wow. good deal man! can you also find out if there is a way to have 6 lug rear discs? like use the 4x4 rotors? and find out if this is at all possible? you should get those reproduced you could sell them on the parts board!
70 longbed 496/th400/Ford 9" |
Merciless Butcher
Very clean looking 383......You might want to think about using grade 8 bolts though.
#13 |
gonebad2, I'm going to use grade 8 bolts, grade 5 bolts was all I had when I was checking the fit of the backing plate.
#14 |
Not trying to be negative but I ran the 9 inch ford rear end lincoln disc brake set up on my race car and the calipers are crappy just my 2 cents
#15 |
I am building an 80 model crew cab 4x4 with 14 bolt ff rear end anybody have any disc brake setup ideas for this rear end
#16 | |
Merciless Butcher
#17 |
very chattery, wheel hop when heavy pressure applied,not happy with the stopping power
#18 |
The Caddy rotors will NOT fit 71-72 axles flange. The axle flange AND the center hub will have to be turned down in order for the rotor to slip over axle flange.
How do I know? I have already done this modification with the late 70's Caddy Seville stuff. |
#19 |
Gonebad you said you use the rotors off of a 71 to 87 k10. Do the plans say anything about machining the axle? I have emailed the guy you got your plans from but havent got any answers. I was trying to see what parts are needed before I jumped into some thing that is going to cost me too much.
Buy Sale or Trade 71 3/4 4x4 72 1/2 ton cheyenne 4x4 Last edited by ozarkhippie; 01-01-2004 at 10:31 PM. |
#20 |
Found Web Page with SImilar Product
I found a website related to your project a few weeks ago. The company sells some of the fabricated parts that you are describing. All you do is add oem discs, pads, and rotors. Here is the site:
http://www.azkickin.com/home.htm |
#21 | |
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
#22 |
ive heard of lots of people using the 9 inch ford and everybody loves them. maybe u arent using the right master cylinder and prop valve?
#23 |
14 bolt discs
Just adding to the info.Check out this link: http://cgi.ebay.com/ebaymotors/ws/eB...category=33728
69 Lwb C-10 402/700R4 70 Lwb C-10 250/3pd Wisc. |
#24 |
Here's another: http://cgi.ebay.com/ebaymotors/ws/eB...763&indexURL=1
#25 |
Anyone know how much rebuilt caddy calipers with the e brake cost?
Buy Sale or Trade 71 3/4 4x4 72 1/2 ton cheyenne 4x4 |
