Old 07-29-2024, 07:52 PM   #26
kitsbeach
kitsbeach's Avatar
Shifter
Figured I could make a new shifter out of an old 4-speed shifter I picked up. Took a look at a few Hurst shifter models for ideas.
Name:  Shifter donor might get modded into 3-speed shifter-3.jpg
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
1980 C20 Long to short & static drop "Square One"
kitsbeach is offline   Reply With Quote
Old 07-29-2024, 07:57 PM   #27
kitsbeach
kitsbeach's Avatar
Crossmember
By the way the SM465 4-speed crossmember is different than the TH350 crossmember that would have fit my saginaw perfectly.
I didn't remember to take pictures but was just barely able to get the crossmember moved forward enough to attach my trans mount.
I was too impatient to stop and go find the right crossmember, but that would have been the better way to go.
Next time I'm under the truck I'll get a picture and try to post it in here.
Kitsbeach (Ken)
Old 07-29-2024, 08:01 PM   #28
kitsbeach
kitsbeach's Avatar
TH350 Crossmember
This is what the TH350 crossmember looks like in my other truck (1977 C20). This would fit a saginaw or a muncie 4-speed or T10.
Name:  Square Two regular crossmember -1.jpg
Name:  Square Two regular crossmember -2.jpg
Name:  Square Two regular crossmember -3.jpg
Kitsbeach (Ken)
Old 07-29-2024, 08:06 PM   #29
kitsbeach
kitsbeach's Avatar
High hump and shifter boot
I had to bend up my shifter boot frame to fit the awkward position at the back of the high hump.
I just went slowly with the vice grips and screwed it in place as I went and it worked out quit nice.
These are actually double layer shift boots, which should be quieter, but I don't know if I have the patience to bend up the second layer and I'm missing the second boot anyway although I have the frame.
Name:  High hump and shifter boot-1.jpg
Name:  High hump and shifter boot-2.jpg
Name:  High hump and shifter boot-3.jpg
Name:  High hump and shifter boot-4.jpg
Name:  High hump and shifter boot-5.jpg
Kitsbeach (Ken)
Old 07-29-2024, 08:10 PM   #30
kitsbeach
kitsbeach's Avatar
Name:  High hump and shifter boot-6.jpg
Name:  High hump and shifter boot-7.jpg
Name:  High hump and shifter boot-8.jpg
Name:  New shifter with boot-1.jpg
Name:  New shifter with boot-2.jpg
Kitsbeach (Ken)
Old 07-29-2024, 08:19 PM   #31
kitsbeach
kitsbeach's Avatar
Driving
Driving it today. Shifts nice.
One thing I will say is that this Saginaw was from a 6-cylinder and has a very low first gear. The V8 version with a milder first gear would be a closer ratio and a milder jump.
Also this motor, while strong, has the small 1.72 intake valves, so it doesn't like to rev. The combination makes it a pretty slow speed cruiser.
I'm deciding how much I want to spend on this thing but, if I get into it more, might swap on some small chamber 1.94 heads. Of course then I might think about an overdrive trans like a TKX/TKO600/T56 and on and on it goes....
Here's today's pics
Name:  July 29 Square One-4.jpg
Name:  July 29 Square One-1.jpg
Kitsbeach (Ken)
Old 07-29-2024, 08:21 PM   #32
kitsbeach
kitsbeach's Avatar
Dent
That dent in the front is bugging me more than it used to. Its right on a crease so it might be hard to get out. Maybe I can find somebody with some actual skills to give it a try.
Kitsbeach (Ken)
Old 07-30-2024, 08:44 AM   #33
Android04
Android04's Avatar
Re: 3/4 Ton Long to Short & Static Drop Square One
Truck is looking good. Unfortunately that dent/wrinkle on the body line will be a doozy to make it look right.
Leaving this as a patina-ish build?
Android04 is offline   Reply With Quote
Old 07-30-2024, 10:25 AM   #34
Shifty One
Shifty One's Avatar
Fix the front fender, and you'll have to fix the bed crease....fix the bed crease, and then the door ding will need attention, fix that and....
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 08-13-2024, 09:28 PM   #35
kitsbeach
kitsbeach's Avatar
Yes for sure this is a "patina build"
The reason I couldn't help buying it was because it had great patina and no rust through. It has one cab mount that is in need of attention and I will do that.
It came with no bed so the colour match and patina on the back is "faux".
Kitsbeach (Ken)
Old 08-13-2024, 09:29 PM   #36
kitsbeach
kitsbeach's Avatar
You know it.!
Kitsbeach (Ken)
Old 08-13-2024, 09:47 PM   #37
kitsbeach
kitsbeach's Avatar
C-notch
Here is the c-notch I bought from Switch Suspension
Name:  Switch notch beefy-1.jpg
Name:  Switch notch beefy-2.jpg
Name:  Switch notch beefy-3.jpg
I'm very happy with the guys at Switch Suspension. I bought the full 6/8 drop kit, minus the front spindles which were unavailable from Western Chassis at the time. There were a few hiccups during the install and when I phoned I usually talked to Edgar, and he always knew exactly what I was talking about like C20 differences. There were a few problems with some of the parts but we found work arounds (more on that later).
I was NOT very happy with Western Chassis. I needed the C20 drop spindles and, at the time I was ordering (Dec 2023), Western Chassis were the only ones making them.
I ordered them and they charged my credit card (most places don't charge until parts are shipped) and then I began the wait.
First they were supposed to arrive in January, then February, then in March I was told they had arrived and just needed to be unpacked and sent to me. Then in late March I phoned again and they said I was on the backorder list again. They didn't have enough to fill my order!
Doesn't Western know how many are on backorder and how many were coming in?
Kitsbeach (Ken)
Old 08-13-2024, 10:03 PM   #38
kitsbeach
kitsbeach's Avatar
c-notch
Install of notch went well.
My frame had a perfect alignment hole (which I double checked by measuring from the front spring hanger because the front hanger distance doesn't change vs rear shackles do move).
Name:  My frame had perfect alignment hole-1.jpg
I made a paper template then drilled the corners before I started cutting the frame.
Name:  C-notch marked frame then double checked with paper.jpg
Name:  C-notch drilled corners before cutting .jpg
The best feature of the Switch suspension notch is this little pointer to help line up the final fit.
Name:  best feature of switch notch is this pointer .jpg
After many test fits and much grinding to perfection she was in place.
Name:  100th test fit c-notch.jpg
Kitsbeach (Ken)
Old 08-13-2024, 10:13 PM   #39
kitsbeach
kitsbeach's Avatar
Flip kit
I'll post up the flip kit install next.
Kitsbeach (Ken)
Old 08-16-2024, 12:06 AM   #40
kitsbeach
kitsbeach's Avatar
Flip kit
Here are a few pictures of the flip kit and shock extenders being installed.
The one problem I encountered was that the leaf spring plate came very close to the shock mounts. It was impossible to get a nut on the bolt for the shock extenders.
In the end I just welded the end of the bolt, and will have to grind if off if I ever want to take this apart.
By the way in my case I could have re-used the OEM leaf spring plate by flipping them upside down. That would have created more room. But I had already bolted on the flip kit before I tried to install the shock extenders.
The OEM leaf spring plates have a bump for a pin on 3/4 ton springs, but I used 1/2 ton springs that have no pin.
Flip kit installed right side:
Name:  Flip kit installed right side.jpg
another pic of right side:
Name:  Flip kit installed right side 2.jpg
Next three shots show how close shock mount is to leaf spring plate (not much room for shock extenders):
Name:  shock mounts very close to leaf brackets.jpg
Name:  shock extenders very close to leaf spring plates.jpg
Name:  Leaf spring plate very close to shock mount.jpg
Kitsbeach (Ken)
Old 08-16-2024, 12:14 AM   #41
kitsbeach
kitsbeach's Avatar
Switch Suspension Flip kit
Here are what the shock extenders look like:
Name:  Shock mount extenders c20 switch.jpg
Here they are installed (you can't see the back where I welded the bolt in but there was no room for the nut):
Name:  Shock mounts very close to leafs-2.jpg
Here is the truck rolling again waiting for Western Chassis drop spindles that never did arrive:
Name:  Rear drop done waiting for front parts.jpg
Kitsbeach (Ken)
Old 08-16-2024, 12:31 AM   #42
kitsbeach
kitsbeach's Avatar
Belltech rear shocks don't come with mounts..!!
Another problem with the Switch Suspension flip kit is that the Belltech rear drop shocks do not come with mounts.
Very frustrating.
That turned a 15 minute shock install job into a two week job while I found some mounts that were similar, had them shipped to Canada, and then had them machined to the right size.
I ended up using a set of front upper mounts and machined them to the correct diameter to match the Belltech shocks.
Switch suggested using the original mounts and lightly reaming out the shocks themselves but the original mounts are over 40 years old and were not coming off the original shocks in one piece.
Here are some pics of them installed.
Top mount:
Name:  Rear shock top mounts modified.jpg
Shocks are very close to the leaf spring plate (this could be improved by Switch by making the plates the same size as the OEM plates):
Name:  Rear shock very close to leaf spring plate.jpg
Bottom mount:
Name:  Rear shock installed bottom mount.jpg
Moral of the story is do not buy Belltech rear shocks until they start offering shock mounts with them. The Switch guys were very helpful but the shocks are a bad product.
Name:  Belltech 9549 Street Performance shock set (rears need hard to find mounting studs)-1.jpg
I'm curious if others have had this problem and what they did about it?
Kitsbeach (Ken)
Old 08-16-2024, 12:34 AM   #43
kitsbeach
kitsbeach's Avatar
Belltech shocks don't come with mounts
PS on my '67 I wanted a certain brand of shocks and hunted around and did the math until I found an OEM fitment that matched my truck (Toyota shocks I believe). That might be an alternative if Switch/Belltech insist on selling rear shocks with no mounts.
There are no mounts anywhere on the internet that I could find that fit the Belltech rear shocks.
Kitsbeach (Ken)
Old 08-19-2024, 01:33 AM   #44
kitsbeach
kitsbeach's Avatar
frame paint
Ended up painting the frame as I went.
Name:  rear frame painted -4.jpg
Name:  rear frame painted -5.jpg
Name:  rear frame painted -6.jpg
This started as a quick and dirty driver/patina build but the paint does make it look better even though it is not perfect.
Kitsbeach (Ken)
Old 08-19-2024, 01:46 AM   #45
kitsbeach
kitsbeach's Avatar
bed floor cuts
Started cutting the bed floor. It needed 14" removed from the front but I decided to lap it and stitch weld it to save a whole lot of welding on bumpy dented bed floor, therefore I removed 12" or so.
I figured butt welding would be too time-consuming with all the waves in the bed floors, not to mention various dents and scars from the years.
"Measure twice, cut once" is the saying and I almost cut too much out. I was scratching my head thinking about this but finally got going and it all worked out.
Name:  First bed floor cuts front-1.jpg
Name:  First bed floor cuts front-2.jpg
Kitsbeach (Ken)
Old 08-19-2024, 01:50 AM   #46
kitsbeach
kitsbeach's Avatar
bed floor front welds
Here's some pictures of the bottom front of the bed and the stitch welds
Name:  Lap weld bottom front-1.jpg
Name:  Lap weld bottom front-2.jpg
Later on I will seam seal the whole thing
Kitsbeach (Ken)
Old 08-19-2024, 01:57 AM   #47
kitsbeach
kitsbeach's Avatar
front bed support needed repair
The bed supports nearest the wheels were both rusty but I managed to save some money and used the deleted bed supports to get me what I needed.
The front just needed a patch piece.
Name:  Patch rusty bed support -1.jpg
Name:  Patch rusty bed support -2.jpg
Name:  Patch rusty bed support -3.jpg
Kitsbeach (Ken)
Old 08-19-2024, 02:00 AM   #48
kitsbeach
kitsbeach's Avatar
bedfloor front
Here is a pic of the top before I welded it
Name:  Lap weld from top before top side welds-2.jpg
Kitsbeach (Ken)
Old 08-19-2024, 02:04 AM   #49
kitsbeach
kitsbeach's Avatar
bed floor rear
For the rear of the bed I copied a fellow on Youtube named "coyote customs" and just cut the back of the floor off and beat it down. Saved another ton of welding.
This is a shot from his video that shows the rear corners that need cut and moved.
Name:  cut rear corner coyote customs.jpg
Kitsbeach (Ken)
Old 08-19-2024, 02:08 AM   #50
kitsbeach
kitsbeach's Avatar
youtube heroes
By the way coyote customs and Dave Welch from Brothers are my heroes.
Coyote works so fast he basically cuts down a bed without editing. He just goes at it.
Dave Welch does some very good videos about the bedsides. He includes the differences in the bedsides over the years. My newer bed (1985 I think) had a combination of all the differences, so I had to adapt a few people's methods. I'll post that up soon.
Kitsbeach (Ken)
