Old 07-28-2024, 10:40 PM   #1
kitsbeach
kitsbeach's Avatar
3/4 Ton Long to Short & Static Drop Square One
I just got this truck back on the road after shortening and dropping it, thought I'd post a few pictures of the build.
As I found it:
Name:  First day square one-4.jpg
Today short test drive:
Name:  Brighton July 28- front  quarter view.jpg
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
1980 C20 Long to short & static drop "Square One"
kitsbeach is offline   Reply With Quote
Old 07-28-2024, 10:44 PM   #2
kitsbeach
kitsbeach's Avatar
Re: 3/4 Ton Long to Short & Static Drop Square One
A couple more before and after:
Name:  Square One Day One.jpg
Name:  Brighton July 28 drivers side.jpg
Kitsbeach (Ken)
Old 07-28-2024, 10:53 PM   #3
shambles
Junior Member
Looks great. What static drop did you use? I'd like a nice driver drop.
shambles is offline   Reply With Quote
Old 07-28-2024, 10:57 PM   #4
kitsbeach
kitsbeach's Avatar
I call her Square One because as soon as I bought it I accidentally ended up with another that I call Square Two:
Name:  Square Twp April 12 2024-5.jpg
Square Two is actually a nicer truck but they are both great low mileage trucks with great patina and very little rust.
Kitsbeach (Ken)
Old 07-28-2024, 11:01 PM   #5
kitsbeach
kitsbeach's Avatar
Square One (I believe) was some kind of work truck up in the Fraser Canyon, British Columbia, four or so hours north of Vancouver where I am now.
She's got the bumps and bruises of a yard truck but lots of obvious maintenance. Everything is greased up and running nice. Nicer now that I've cleaned the heck out of it and gone over everything.
Kitsbeach (Ken)
Old 07-28-2024, 11:06 PM   #6
kitsbeach
kitsbeach's Avatar
Ripped the landscape bed off:
Name:  Landscape bed delete-1.jpg
Name:  Landscape bed delete-2.jpg
That was actually hard work. I was told the truck had a service truck bed on it but the guy threw it in the dump so that he could build this and landscape his yard.
Gone now anyway...
Kitsbeach (Ken)
Old 07-28-2024, 11:22 PM   #7
kitsbeach
kitsbeach's Avatar
The first thing I did was backdate the grille to the 73-74 style to get the vibe I wanted:
Before:
Name:  Old grille Sept 2023-4.jpg
Old grille off and orange marker lights added:
Name:  Grille backdate -7 grille removed orange lenses added.jpg
This truck is a 1980 so there was a little change to where the 1973 lower grille bar attaches. I just cut the tabs of the lower grille bar and used some trim tape to install it (pic doesn't show it that well):
Name:  Early lower grill bar tabs cut off to fit 1980-2.jpg
Name:  lower grille bar taped on.jpg
Kitsbeach (Ken)
Old 07-28-2024, 11:24 PM   #8
kitsbeach
kitsbeach's Avatar
Before and after grille backdate:
Name:  1973 grille installed -4 nightime.jpg
Kitsbeach (Ken)
Old 07-28-2024, 11:46 PM   #9
kitsbeach
kitsbeach's Avatar
It's 2 1/2" drop spindles and 3" lowering springs in the front, and just a flip kit in the back but it now has 1/2 ton leaf springs in the back because short beds have 52" springs and long beds have 56" springs and I wanted stock back bumper brackets.
It also has the 16" wheels so it sits a bit different than a 1/2 ton truck would. I kind of like it. Looks short and tough. The front is about a 1/2 inch higher than the back, which I'm also happy with but it may settle.
The 3/4 ton springs up front are a bit bouncy, I may go to 1/2 ton front springs, but I think it would end up a bit lower.
No rubbing at all, its very practical.
Tires are 225/75R16 so pretty skinny
Kitsbeach (Ken)
Old 07-28-2024, 11:51 PM   #10
kitsbeach
kitsbeach's Avatar
Not many people drop and shorten a 3/4 ton but it had very little rust and great patina so I couldn't help myself I had to grab it.
I probably could have done a 1/2 ton conversion all round, but this is what I did.
Kitsbeach (Ken)
Old 07-29-2024, 12:15 AM   #11
kitsbeach
kitsbeach's Avatar
Frame cuts
I did a bit of googling and talking to people this time about the frame cuts and fish plates (I've shortened my '67 too).
I like the thoughts shown in this picture:
Name:  wrong better best fishplate design.jpeg
Also the idea of the fish plate welds going different directions than the stressors, like this example:
Name:  example fish with open ends.jpg
So what I settled on this time was rounded ends on my fish plates so that the welds would be in different angles to the stressors, and also not to weld the plates continuously (used skip welds), so the plates actually have ability to flex.
I got quite a bit of advice on this from pro welders.
Kitsbeach (Ken)
Old 07-29-2024, 12:22 AM   #12
kitsbeach
kitsbeach's Avatar
Frame cuts and fish plates
BUT...I also knew that the chance of me getting the zigzag cuts perfect would be near impossible.
The zigzag cuts are the most popular on this site and all over the internet, but that means 6 different cuts ON EACH SIDE. Getting them to match up perfectly would be difficult.
So I settled on nice big strong fishplates, with a good design, along with straight cut frame cuts.
Basically wrong on the frame cuts and best on the fish plates.
Kitsbeach (Ken)
Old 07-29-2024, 12:44 AM   #13
kitsbeach
kitsbeach's Avatar
The cuts
For the frame cuts I picked somewhere that would leave room for the fish plate to extend past the cut a lot without running into a spring hanger.
My location was a bit close to the cab, which made it a little hard to work in there later, but it was okay. I re-drilled the cab crossmember holes through the fishplate (trying to find a picture of that).
Anyway here are the cuts:
Name:  Frame cut location.jpg
Name:  Frame cuts-4.jpg
I removed 14" from the middle and later will remove 5 3/4' from the rear (more on that later).
Kitsbeach (Ken)
Old 07-29-2024, 12:45 AM   #14
kitsbeach
kitsbeach's Avatar
No turning back
And here she is cut:
Name:  Frame cuts she's cut 15.jpg
Kitsbeach (Ken)
Old 07-29-2024, 12:47 AM   #15
kitsbeach
kitsbeach's Avatar
Cut and clamped
Name:  Cut and clamped -4.jpg
By the way these jack stands are actually RV jacks, which made it easy to adjust the height precisely.
Kitsbeach (Ken)
Old 07-29-2024, 12:56 AM   #16
kitsbeach
kitsbeach's Avatar
Fish plate design
Here's my fish plate mock up, all done with a grinder:
Name:  Fish plate design -1.jpg
Name:  Fish plate design -2.jpg
Name:  Fish plate design -3.jpg
Name:  Fish plate design -4.jpg
Name:  Fish plate design -5.jpg
That metal is from the 14" piece of the frame that I removed.
Kitsbeach (Ken)
Old 07-29-2024, 12:59 AM   #17
kitsbeach
kitsbeach's Avatar
Fish plate mock up
Bolted the fish plate in place using cab crossmember bolts and some more bolts later (no pics tho):
Name:  Fish plate design -6.jpg
Name:  Fish plate design -7.jpg
Kitsbeach (Ken)
Old 07-29-2024, 01:03 AM   #18
kitsbeach
kitsbeach's Avatar
Left side fish plate
Just realized I have no pictures of the actual frame welding and grinding but here are a couple of the left side fish plate skip welded in place:
Name:  Welded fish plate left side -1.jpg
Name:  Welded fish plate left side -2.jpg
Kitsbeach (Ken)
Old 07-29-2024, 01:05 AM   #19
kitsbeach
kitsbeach's Avatar
Right side fish plate
Name:  Welded fish plate right side -3.jpg
Kitsbeach (Ken)
Old 07-29-2024, 01:08 AM   #20
kitsbeach
kitsbeach's Avatar
Moving again after frame weld
Here she is moving again after the frame weld:
Name:  moving again after cut fram.jpg
All the dirt you see is actually from all the cutting and grinding that went on. My garage will never be the same.!
Kitsbeach (Ken)
Old 07-29-2024, 06:38 PM   #21
shambles
Junior Member
No rubbing at all, its pretty practical.
Cool, Thanks for the info. I've been thinking about the 5/7 or possibly 4/6 drop.
Old 07-29-2024, 06:51 PM   #22
Shifty One
Shifty One's Avatar
Following!
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 07-29-2024, 07:36 PM   #23
kitsbeach
kitsbeach's Avatar
Saginaw 3-speed swap
Some of these pictures are out of order but I swapped in a Saginaw 3-speed manual in place of the (I think) SM465 "bull low" 4-speed.
Adjusted Hurst shifter on the bench beforehand:
Name:  Saginaw shifer adjusted and ready for install best.jpg
Dropped this old hunk out myself, probably wasn't the wisest idea because it was heavy and almost killed me:
Name:  Transmission swap old 4-speed.jpg
Compared input shafts and I didn't need a new clutch disc (yay.!).
Name:  Transmission swap -2 compare input shafts.jpg
Side to side comparison of length and shifter position:
Name:  Transmission swap -3 compare side to side.jpg
Kitsbeach (Ken)
Old 07-29-2024, 07:42 PM   #24
kitsbeach
kitsbeach's Avatar
New trans in
Lifted new trans in (with some help). Its always a bit of a wrestle then finally it pops in.
I had to cut a hole for the new shifter location and unfortunately cut it a little too far back. I'll have to patch it up when I do my floor coverings.
Hate wrecking the nice floors and high hump.
Name:  Shifter hole in floor slightly too big.jpg
Kitsbeach (Ken)
Old 07-29-2024, 07:49 PM   #25
kitsbeach
kitsbeach's Avatar
Shifter hole
Name:  Floor shifter hole-9 copy.jpg
Name:  Floor shifter hole-10 copy.jpg
Kitsbeach (Ken)
