Old 03-22-2026, 11:03 PM   #26
HeavyHauler
Re: Changed trans fluid in my TH400 and now it wants to slip and not get into gear.
Well I got the trans pan sealed tight with zero leaks. I started the truck and put in 5 quarts while it was in neutral. I let the truck warm up and made sure the dipstick was reading at the full mark.
Truck still doesnt move. I shifted through all of the gears and nothing. The trans is original to the truck and has ALOT of miles on it. i cant think of anything else to check. I guess it need to be rebuilt.
Instead of rebuilding it though I might just get a rebuilt 4L80E instead and just put the TH400 in storage.
I am bummed out though as I was hoping to cruise it around some more this summer.
HeavyHauler is offline   Reply With Quote
Old 03-22-2026, 11:47 PM   #27
57taskforce
All about them K’s
57taskforce's Avatar
Did you check the fluid with it level, running, and in park? I see you made mention of neutral but not park. I don’t think you’d loose forward and reverse both because of clean fluid, and definitely not right away on start up. I could see maybe after a few hundred miles of the clean fluid circulating thru the system but not immediately on start up. TH400’s are tough as nails. I bet it’s still low on fluid.
Tyler
57taskforce is online now   Reply With Quote
Old 03-23-2026, 11:55 PM   #28
Getter-Done
Getter-Done's Avatar
Originally Posted by Shifty One View Post
Is it sucking air maybe (filter not tight or similar)
Originally Posted by HeavyHauler View Post
I did not mess with the filter.
Just a Suggestion.
I would check and change the filter and the O-rings on the filter tube.
Those filters are what I call a Floating filter because it is mounted with a Shoulder bolt in most applications.
The early bird gets the worm,
85 Chevy K-20
Old 03-24-2026, 07:46 AM   #29
Joyridin
Sorry, but this makes zero sense. Even if you changed the fluid, the truck would still move if you put the correct amount of fluid back in. It doesn't just quit working the minute the fluid is changed.
Keep adding more fluid. Maybe the dipstick is wrong for some reason. I would have never dropped the pan without changing the filter. Maybe the filter is plugged?
Joyridin is offline   Reply With Quote
Old 03-24-2026, 10:12 AM   #30
SCOTI
SCOTI's Avatar
>50% of the time.... If the fluid & filter is changed on a trans that did not receive 'regular' maintenance (~80-100k miles), it will start slipping/acting-up. I heard this as a youth & called BS. But I learned. I did 'proper' maintenance on new additions to my fleet (3 different rides), inevitably the trans started slipping within miles when I did trans service.
After No.3, I learned to leave them alone. You can get away with a slow-mo fluid change on extended milage transmissions (drain & add fresh fluid every X-miles) but a filter w/complete fluid flush seemed like the beginning of the end-o-life from the units I experienced.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-24-2026, 11:36 AM   #31
MARKDTN
Originally Posted by 57taskforce View Post
Dex 6 won’t hurt it. All this anti synthetic bs is amusing. Dex 6 is so far superior in every way to dex 3 and its reverse compatible meaning when the converter is still full of 3 you can safely run 6 on fluid and filter change. I run it in all my old automatics. It’s far more resistant to heat, the viscosity is more consistent, and it doesn’t foam near as much as 3. Sorry had to vent lol, I see these kinds of posts on some of the other boards I’m on and it drives me nuts how some of these opinions and understandings are skewed.
It does appear that 6 is backwards compatible BUT the viscosity is lower so it may not pump as well in a worn transmission. I'll have to consider that next time I need to change fluid in an older trans.
As far as the post above, I have not had that experience with immediate failure. I too would have changed the filter while I was looking at it, but I have changed fluid (and filter) in several older transmissions without any failures. Guess it's the luck of the draw.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 03-24-2026, 11:40 AM   #32
SCOTI
SCOTI's Avatar
Probably correct (luck of the draw)....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-24-2026, 05:51 PM   #33
Joyridin
Yes, I know that, but that isn't what happened here. He didn't even really change the fluid except what was supposedly in the pan. There is no reason if all he did was drop the pan, seal it, then glue it back in place and add some fluid the trans won't move or at least jar the vehicle. Considering the amount of fluid in the trans and in the converter, which is 11.5-12 quarts, that fluid wouldn't even be 50% new. Something else was either done or is wrong.
Old 03-24-2026, 07:23 PM   #34
HeavyHauler
Here is the exact order of what I have done so far. My truck ran fine last summer all the way into October 2025 and it had a small trans pan leak and I tried to fix it replacing the gasket, fluid and the filter and it still leaked. I then parked it in my garage but it had a bigger trans pan leak over the winter and it leaked ALOT of fluid out during storage.
Now the following is what I did recently.
1) Replaced trans pan gasket because it was leaking badly but I did not replace the filter because it is like new. The filter bolt was secure and the rubber Oring looked fine. The pan sealed and does not leak anymore.
2)I put in 5 quarts of Type F (truck was not running)
3) I started the truck up, let it idle for about 5 minutes and then checked the fluid level with the truck idling in neutral and the fluid level reads slightly above full. Truck does not want to move.
4) Shifted truck through all the gears while it was still running and it will not move at all.
5) I started the truck up again today, let it run about 5 minutes and checked the fluid while idling in neutral. Fluid level reads slightly above full and truck still doesnt want to move
Old 03-24-2026, 07:27 PM   #35
HeavyHauler
I have had the same experiences in the past and yes this trans has been slipping some in the past and I think it was due to the trans pan leaking when prior owners had it and not keeping enough fluid in it which I think shortened the life of the trans but regardless the truck still ran and moved when I parked it over the recent winter.
Old 03-24-2026, 07:55 PM   #36
HeavyHauler
Went out and started my truck up again. Letting it warm up and checked the fluid level while parked and the level still reads above the full mark. Still no changes.
Old 03-24-2026, 09:46 PM   #37
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
It has not been my experience that servicing a transmission led to failure soon after, and I worked as a mechanic for decades. I guess it's down to the luck of the draw? FWIW, my shift selector shaft seal leaks, and the trans gets low on fluid every once in awhile. I just put more fluid in it. It's done it for years, but adding fluid always brings it back. Trans was rebuilt about 40 years ago and now has about 100k miles on it. OP, I think that your trans was just ready to die.
~Steven
Simi Valley, CA
Old 03-25-2026, 01:10 PM   #38
mike16
Just checking, but you didn't put synthetic fluid in it by chance? That would definitely make it slip.
I doubt it.
Any transmission fluid has the characteristic of being able to clean out varnish and particles in a transmission. On older transmissions it's more pronounced. That's why it was used to " clean" lifters in noisy valve trains.
When you change over to new fluid it will flush out or loosen that varnish or debris.
The particles loosened when the new fluid circulates can jam up the operation of valves and pistons . This will cause shifting problems.
Time for a rebuild and proper periodic servicing in the future.
Synthetic transmission fluid is not your problem. That may have been a cause for engine seal leaks back through the mid 90's but how it became a transmission problem currently is unclear.
mike16 is offline   Reply With Quote
Old 03-26-2026, 08:49 AM   #39
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
Originally Posted by Steeveedee View Post
B&M Trick Shift was about the same as Type F except it was dyed blue. I ran it for years in my hot rods after putting in shift kits. Don't know if it is still blue; it's been awhile.
I would have sworn it was green.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver(divorced)
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD(Sold)
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck(divorced)
73 El Camino SS 454 4 speed my first big block
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 03-26-2026, 02:05 PM   #40
HotWheelsFan
HotWheelsFan's Avatar
GM Hydromatic service guides are helpful, they show fluid routings, diagnostic charts for items to check for and pressure test readings.
As I don't have the books I have used in the past, a quick search did not point to a single failure point. Problem might be as simple as a broken spring in valve body or gasket failure, or anything up to needing the removal for repair.
If trans is old, and has old gaskets and seals, rebuild or replace would be the way to go.
Pressure gauge readings can be found online and would be a great test to perform. If readings are off, the service manual would then be useful.
Bob
HotWheelsFan is offline   Reply With Quote
Old 03-26-2026, 05:51 PM   #41
Shifty One
Shifty One's Avatar
Over-filling will cause foaming. I'd drain some out (cooler line would be easiest) until the level is correct, and start there. Until you rule out the things that you know are wrong, you're only going to frustrate yourself.
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 03-26-2026, 07:37 PM   #42
Rust_never_sleeps
Rust_never_sleeps's Avatar
If it's too full, wouldn't it foam out the vent?
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
Old 03-26-2026, 07:40 PM   #43
Shifty One
Shifty One's Avatar
It might if being driven. I'm just throwing theories here....
Old 03-26-2026, 08:13 PM   #44
3drburb
Did you check the vacuum hose and the modulator on the right side of the trans?
3drburb is offline   Reply With Quote
Old 03-26-2026, 10:03 PM   #45
Rust_never_sleeps
Ah, good point
Old 03-27-2026, 03:43 PM   #46
Shifty One
Shifty One's Avatar
Good one, it's even happened to me a few times, I should have thought of that. Check the vacuum line for splits or tears as well.
Old 03-27-2026, 09:03 PM   #47
HeavyHauler
Yesterday I put your theory to the test and added 2 more quarts. It did nothing but at least I tried. Most likely it is overfilled now but it doesnt matter because I will be pulling it anyway this summer.
