#28 |
All about them K’s
![]() Join Date: Jun 2014
Re: Changed trans fluid in my TH400 and now it wants to slip and not get into gear.
Did you check the fluid with it level, running, and in park? I see you made mention of neutral but not park. I don’t think you’d loose forward and reverse both because of clean fluid, and definitely not right away on start up. I could see maybe after a few hundred miles of the clean fluid circulating thru the system but not immediately on start up. TH400’s are tough as nails. I bet it’s still low on fluid.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s Last edited by 57taskforce; 03-22-2026 at 11:52 PM. |
| Bookmarks |
