#501 | |
Re: mylow53 build
#502 |
![]() Join Date: Mar 2007
Re: mylow53 build
Cajun-
My doors are tight. I physically have to push them in slightly before trying the unlatch them. I know that won't work when I am relying on the solenoids. We shall see. Marc |
#503 |
Re: mylow53 build
marc i used this to seal the doors the one on the right it's thin enough to fit in and still seals. it has a sticker on the back, so no need for glue
GT
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 Last edited by mylow53; 02-08-2010 at 03:37 PM. |
#504 |
Re: mylow53 build
oops this one is what i used
it's about a 1/2 inch wide GT
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 Last edited by mylow53; 02-08-2010 at 03:56 PM. |
#505 | |
Re: mylow53 build
I might have to give that a try. But without the use of glue, how will I be able to make a mess of things?? I wish I had seen this prior to glueing my seals on. I did get them from Steele, but I think they where the factor seals where yours look to be more universal. Thanks for the info. Marc |
#506 |
Re: mylow53 build
#507 |
Re: mylow53 build
it should do one door or very close to one door. i would get 3 for 2 doors
GT
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 |
#508 |
Re: mylow53 build
heres some photos. you will notice i removed my old seals that were glued in as well
GT
#509 |
Re: mylow53 build
So you used this seal you mentioned earlier on your doors in place of the Steele original replacements and like them? Good to know, since I'm getting closer to having to figure this out on mine....
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
#510 |
Re: mylow53 build
so far there the only ones that allow me to close my door. my truck has had drivers side door issues for as long as i've owned it. i would try the oem first but if it won't close you might try this... i have oem on the passenger door and it closes fine.
#511 |
Re: mylow53 build
Greg-
Your the man. Thanks for the pictures. I noticed in the last picture, you are not using any weather stripping on the bottom. Did you remove this in order to fix your drive door that was not closing? Thanks Marc |
#512 |
Re: mylow53 build
nope just haven't finished. i need some more weather striping...
GT
#513 |
Re: mylow53 build
Look a little deeper in the catalog for the proper weather strip for the doors on the AD truck. He has the right ones for our trucks and they work great
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
#514 |
Re: mylow53 build
I used the ones from Steele that are made for AD trucks and they are too tight. This is the same issue Greg had, so he came up with these universal ones from Steele. I will be giving them a try.
#515 |
Re: mylow53 build
ok i said i would drive this truck didn't I? well i took it to work yesterday cause i haven't driven it for weeks due to the rain. got to work ok but i had to work real late. so i'm driving it home taking la brea in la. and i blew an air bag. dropped the left front on the ground. thankfully it didn't hit the frame! called aaa and asked for a flat bed. by then it was midnight, Not the best place to hang out... the tow truck driver arrived and was happy to drive me to thousand oaks provided i pay him in cash $315.00!!! and no they dont take credit cards. so after a trip to a getto atm he had his money and we were on the way home.
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 Last edited by mylow53; 03-11-2010 at 07:37 PM. |
#516 |
Re: mylow53 build
Did you figure out what is was wearing on/against?
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674 My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost 1960 (400/T350/?) Apache 10 short/fleet side-big window 1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4 2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB Doing my part to warm the globe ![]() |
#517 |
Re: mylow53 build
man thats crappy! sway bar endlink?
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit! http://67-72chevytrucks.com/vboard/s...d.php?t=380212 |
#518 |
Re: mylow53 build
I'm sorry to hear about all that trouble man! but luckily, as you said, it didnt hit the frame....
#519 |
Re: mylow53 build
Wow, that is a fear of mine as well. I guess, I really need to add back my rubber snubbers before I make mine road worthy.
I am glad that nothing worse happened to you or the truck.... Marc |
#520 |
Re: mylow53 build
Hey bud truck looks awesome.. Got a quick question what backspacing are you using on the front? Been following your build for awhile and I got alot of ideas from looking at yours, our front ends are the same mustangII I got 15x7 and going with the gangster white wall instead of mags..
#521 |
Re: mylow53 build
the braded steel brake line was rubbing aparently.... hard to see that when the truck is on the ground.
GT
#522 |
Re: mylow53 build
#523 |
Re: mylow53 build
firestone but i don't fault the bag it stuck in there for 5k before failure
GT
#524 |
Re: mylow53 build
#525 |
Re: mylow53 build
i think around 8 months or so. i didn't build it just to look at!
GT
