#501 |
![]() Join Date: Jun 2002
Re: Previous owner '68
It works for me! I love high dollar trucks, but people want to see trucks and cars they could actually afford.
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 Last edited by raggedjim; 02-07-2025 at 09:40 AM. |
#502 |
![]() Join Date: Oct 2012
Great progress on the rust repairs!
Scott 1970 C10 Restomod|454/700R4|LWB-->SWB Build Thread 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
#503 |
Thanks! Still have lots more to do. Bought more welding wire yesterday!
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
#504 |
Still working at the cab, I knew it would be a challenge but I have time and patience.
The cowl was rotted out on both sides, so I patched it up. I know, i excel at mediocracy, but I am the future previous owner.
#505 |
Firewall from the outside.
#506 |
I can hear all the young turks shouting "Get a better cab!".
Nope, I shall wallow in this pit of rust and despair and will come out of the far side burnt, bruised, and victorious. At least that is the plan.
#507 |
If you have time and patience, you'll get it done!
#508 |
Luckily I'm retired so I do have more time than some of you younger guys.
As far as patience, it comes and goes! I've quit this build 4 times, but restarted the next day!
#509 |
![]() Join Date: Apr 2008
I admire your persistence and work
71 C10 72 K20 72 K10 Super Kirk |
#510 |
Thanks! It keeps me busy for sure.
#511 |
Got the kick panel and a-pillar welded in.
#512 |
Also welded up some rust spots on inner kick panel. I'm seriously thinking about deleting the vents, the repairs needed are above my ability and I never used the ones in my other trucks. Are there any guys out there that have done this and regretted it later?
#513 |
![]() ![]() Join Date: Jan 2005
Nice progress on the rust repairs. The only reason I like having a vent on my '68 is so I can leave it cracked open to allow somewhere for the pressure to escape when shutting the doors. I've considered adding a pressure relief valve in the door frame like the later trucks have.
#514 | |
#515 | |
#516 |
This is why I cut into the cab supports even when they look okay from the outside. Full of sand, dirt, and rust.
#517 |
At least the b-pillar looks pretty good.
#518 |
A-pillar also looked good but given all the crap I've pulled out of the rockers and other pillars I decided to cut it off. Good thing, it was stuffed.
#519 |
Wow, that is quite the dirt pile and furball you removed from the rockers!
#520 | |
The rockers had their own pile.
#521 |
![]() Join Date: Mar 2011
lots of progress since last looked
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#522 |
Thanks! It's been a fix one thing, move to another thing then fix it kinda process. It won't be perfect but at least it won't leak!
#523 |
I've been working on the passenger side floor. You guys know the routine.
#524 |
Threw a door on to check clearance with the rocker mocked up... No good, had to cut and hack the floor panel rocker relief to get it all to fit. Seems like I remember this being a problem for me before.
#525 |
Decided to mount the passengers cab corner. I've never liked doing them, but it didn't go too bad.
Door needs some adjustment but it's coming off soon.
| Bookmarks |
