#601 |
Re: A 15 year old's project. Rusty 62 stepside
I believe so, I will find out for sure in the next day or two when I get it fired up
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
#602 |
Post Whore
![]() Join Date: Mar 2013
Hood bird looks good!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#603 |
Thanks tj
#604 |
![]() ![]() Join Date: Jul 2002
Waiting....No truck noise yet.........waiting.....No truck noise yet...waiting..... Is it time yet??
#605 | |
![]() But on a positive note I did finish rebuilding the engine for my dirt bike, I did a big bore kit, clutch and bigger valves. http://youtu.be/_hzehgbL5mM so now I'll get to spend some more time on the truck. ![]()
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution Last edited by 62stepside longbox; 05-07-2016 at 04:38 PM. |
#606 |
Just filled up the t5 with penzoil's finest. Got it started up and right away I could tell that the gasket is now sealing. It's really quite, except for backfiring. Yep still having problems. It starts easily now but it just won't idle, I have to keep the rpm's up then it just backfires and usually dies. I've played around with the air fuel mixture screw and just can't get it to idle or run smooth. Here's a video http://youtu.be/k-DiHR2XeO4
#607 |
Oh never mind guys, once it warmed up it would run smoothly but would idle too low and then die. I bumped the idle up and it runs great now, idles at 300rpm. Exhaust has a nice sound to it. http://youtu.be/0Zxcsv9oupM
#608 |
that's great to here that it is fixed
#609 |
#610 |
Post Whore
Sounds Great man! Good job!
#611 |
#612 |
Got a bit of work done on the rig today, fabbed up an inner rocker for the passenger side. Still needs some grinding but it's starting to take shape
#613 |
Glad you got it running right, always a big relief. On your piston shifter, I wonder if a engraving shop could cut your Shifter pattern in it for you? Then you cut put some paint in the new reliefs? Just a thought. I'm enjoying watching you work on this
#614 |
Awesome man! Starting it is always a high point in the build
#615 | |
Thanks Scott, yeah it sure feels good to get it running
#616 |
Got quite a bit done after school. I finished making the inner rocker panel and got it fully welded in, now it just needs to be ground smooth.
#617 |
Post Whore
Nice!
#618 |
Nice work as always. How long did it take you to weld in the inner rocker? How do you go about doing it? Do you tack a few spots here and there and then let cool for a while?
'66 GMC K25 (305 V6, SM420) aka "Mabel" Link to project http://67-72chevytrucks.com/vboard/s...d.php?t=698082 All gone - '66 CJ5, '69 C25, '69 C25 Camper Special, '79 C10 Big Ten/Bonanza, '84 K10 Silverado |
#619 |
Nice work!
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
#620 |
![]() ![]() Join Date: Oct 2011
Very nice work Nik
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" ![]() Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
#621 | |
Thanks tj
It took about 15 minutes of welding. It's ok if the metal heats up a bit since it is part of the floor and it's all covered by the rocker and floor mat. I usually tack a couple places then use a small hammer to persuade it into the spot I want then more tacking. Thanks Thank you
#622 |
I thought I'd show you guys a donor truck I'm picking up in the next week or so.
1978 GMC Sierra that is complete minus the motor. $300. I will be using the front crossmember for the 62 so I can have disk brakes and cheaper front end parts. I'll also use the rear axle plus all four 15" 5 lug steeleies so that it is 5 lug all around instead of having 5 on the front and 6 on the rear. I'm considering also doing power steering. |
#623 |
02
#624 |
Post Whore
Good find!
#625 |
That '78 will provide lots of good parts. I'd recommend doing the power steering. It sure is nice to have when you're backing into a tight parking spot at a cruise night surrounded by spectators.
* My 63 C10 SWB Fleetside (converted to BBW): http://67-72chevytrucks.com/vboard/s...58#post6851558 @johnny_lamebridge on Instagram ![]() |
