04-07-2013, 10:04 PM | #6526 |
Re: What did you do to your truck today!
temporarly put the cab back on the frame today reinstalled and alinged the doors then test fitted the rockers and corners the pilot/alignment holes i drilled in the hinges worked flawlessly as the doors fell right into place....man i forgot how heavy the doors are
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
04-07-2013, 11:05 PM | #6527 |
Looking great man
1971 GMC Sierra 1959 GMC 100 |
04-08-2013, 05:10 PM | #6528 |
Started to clean my NP205
Very dirty! A little less dirty Nice to have a good workbench /Patrik
C20 4x4 1970 TBI350/TH350/NP205 Sweden |
04-08-2013, 07:19 PM | #6529 |
motor exploder
Did a little work on the firewall, still have a bit of work to do.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
04-08-2013, 09:13 PM | #6530 |
good job Ighell.....
1968 4x4 Frame, with a 67 Cab and Bed A Shorter Step 1999 Dodge 2500 Cummins Diesel |
04-08-2013, 09:18 PM | #6531 |
Mounting time!
1970 Chevy swb, project UGHH! 1987 Grand National http://s168.photobucket.com/albums/u.../1970%20Chevy/ |
04-08-2013, 09:46 PM | #6532 |
Picked up the new starter and solenoid for the panel truck.
04-08-2013, 10:59 PM | #6533 |
Built new exhaust tonight, super 44 mufflers 2 1/2" with 3" turndowns, sounds a bit louder than I thought it would but forgetting Hp makes noise, sure nice noise though. Lights up the 38.5" tires in 2wd without even trying.
04-08-2013, 11:48 PM | #6534 |
Here is the pics of the new rear bumper with the LED's mounted......looks a lot better than the cheesy homemade roll pan the Orig Owner built.
04-09-2013, 01:08 AM | #6535 |
04-09-2013, 08:18 AM | #6536 |
Tore down my NP205.
Posted via Mobile Device /Patrik Posted via Mobile Device Posted via Mobile Device
04-09-2013, 05:49 PM | #6537 |
Installed a glove box insert. PO had removed it
Posted via Mobile Device |
04-09-2013, 06:19 PM | #6538 |
RAT1968 '68 Cab/'71 Parts
Well, last night at 11:30 I was chasing a squeek..Sort of thud. I finally found it using a garden hose and a couple of extra arms and knees, shaking the truck.
It was coming from the gas tank area right around where the filler connects to the tank...at least that's what it sounded like. Since I'd just replaced the tank (with a ton of "anti-squeek gaskets"), and the noise was *definitely* coming from a rub between the tank and cab, I looked, and looked, and looked. Took out the sender to make sure there was no contact with the inside of the tank. Loosened the gas tank bolts, moved crap around. Before I finally went to the trouble of pulling the tank, I climbed under with a 5/8" socket and checked the driver's side rear cab mount. The bolt turned about a half a turn while I was giving it about 70-80 ft lbs. That was the clack-clunk-squeek...Telegraphing itself up the cab and into the walls of the gas tank so clearly that I would have *sworn* it was a tank/cab rubbing. A fine day. Here's the same bolt...but on the passeger's side. I better check that one, too.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
04-10-2013, 09:23 AM | #6539 |
Finally got the bed on Now just have to set all the gaps, sand & buff, then finish interior install. Wont be long now. I would like to thank everyone on this forum for all of the priceless information & knowledge that I frequently referred to!
04-10-2013, 12:43 PM | #6540 |
I got real crazy with my truck today! Get this...I used it as a truck! Crazy I know, but some times you have to go outside the norm.
I stopped adding up how much I spend on my builds, it only makes me doubt my sanity knowing I've spent more than 9 times it's original value new.
04-10-2013, 04:50 PM | #6541 |
That's what trailers are for ! .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
04-10-2013, 05:23 PM | #6542 |
Y'all act like you shouldnt use your Truck
04-10-2013, 05:32 PM | #6543 |
Re: Working Your Old Truck
Some don't , looking at the yards of perfect paint & shiny chrome , I see why not .
Me , I'll use it for work until I'm dead . To - morrow morning I'll drive it to Lake Forest and interview another Body Shop , the guy says he'll be pleased to work on it , I hope I can afford it ~ I'd like to do a body off frame de rust and re paint complete , then I can stop worrying about the rust and concentrate on scratching up the new paint.... . All the young guys here think it's waste , rebuilding it back to a base model , plain jane work truck with painted bumpers but that's what I want . Most of the older guys and all the Mexicans , think it's a great idea , I help them with their old GM Trucks whenever I can .
04-10-2013, 05:44 PM | #6544 |
The bed of my truck is dented from decades of being a work truck, I'm not replacing the floor! I plan on rhino lining right over the dented floor
When I was looking for my project truck I wanted something just nice enough to drive, but not so nice that I would be scared to throw a motorcycle in. Of course when it comes time to make a dump run...... well, I'll just hook up the trailer for that one.
04-10-2013, 06:28 PM | #6545 |
Wood Bed or Metal bed ?
04-10-2013, 06:33 PM | #6546 |
metal, that would just be all sorts of wrong to rhino line a wood bed.
04-10-2013, 06:38 PM | #6547 |
I would just put a Rubber mat over my Wood bed
04-10-2013, 09:00 PM | #6548 |
Guys guess I just love my hotrod a little too much to use it like a truck. Thats what my 4x4 is for. This is strictly for show and go.
But I dont judge the guys who like stock. Our trucks have been hot since they came out and no matter what they will always be hot. So I say stock, modded a little, or full blown tricked out...they all look great. |
04-10-2013, 09:12 PM | #6549 |
Put my windshield back in and put in buddys
Attachment 1090454 Posted via Mobile Device Posted via Mobile Device
67 Chev SWB, 400 SB .040 over, vortec heads, comp XE268 cam, performer EPS intake, edel. 650 AVS carb, 700R4 |
04-10-2013, 09:15 PM | #6550 |
Here's the buddys, carpet's coming.
