04-05-2018, 01:14 PM | #6526 |
Re: What did you do to your truck today? Chapter II
Just got back from a test drive after replacing front coils and shorter rear blocks. Ride quality is better but I don't like the look as much. I'm waiting on new hood hinges so I can throw the hood back on and call it done.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
04-05-2018, 01:43 PM | #6527 |
Need a before and after pic of ride height
04-05-2018, 04:14 PM | #6528 |
plumbed in new PCV line, fuel, and vacuum advance. Looks nice and not just hoses. I found that spark plug ends fit perfect on the PCV to 3/8 tubing. I've done a bit of small tubing work.
04-05-2018, 04:25 PM | #6529 |
Like the clean look!
1970 C10 Short Stepper with 71/72 front clip. |
04-05-2018, 04:26 PM | #6530 |
04-05-2018, 04:39 PM | #6531 |
Her you go:First is before second third after
04-05-2018, 04:41 PM | #6532 |
MetalDoc excellent job plumbing the fuel and vacuum lines!
04-05-2018, 04:58 PM | #6533 |
I hate to say it but the lowered look is more my taste. I was going to raise mine back up an inch in the front and 2 in the rear, but now I think I'm only going up an inch in the back, it sits too flat, needs more rake.
I'm thinking about shrink wrap on them to make them black and thanks. |
04-05-2018, 05:00 PM | #6534 |
Slightly higher (almost unnoticeable) in the front, but still looks awesome.
04-05-2018, 07:35 PM | #6535 |
Upgraded the charging system in the truck today. Picked up a full volt and got my wipers to operate normally. Also added brothers trucks fuel fill cover to my cab.
04-06-2018, 01:00 PM | #6536 |
installed my side and back glass a couple nights ago. waiting on the backorder vent rubber.
Steven '67 SWB, 250ci, 3OTT.......this is my first build...... I wonder if my grand kids will say, "I would give anything to have my grand dads 2005 Chevrolet Z71" |
04-06-2018, 03:23 PM | #6537 |
I painted the lines and I like it. I'm waiting for the paint to dry on the new intake bolts to match all black hardware.
04-06-2018, 03:48 PM | #6538 |
Nice touch, I like it, clean and simple. Now when are you firing up the BBQ eh? I have a vision of ribs. Could be wrong but I don't think so.
04-06-2018, 05:02 PM | #6539 |
Thanks man I haven't done any ribs for a while now but will this tide ya over.
04-06-2018, 06:13 PM | #6540 |
New parts! Who doesn't like them? Hope to know how much fuel I have.
04-06-2018, 06:17 PM | #6541 |
04-07-2018, 03:53 PM | #6542 |
I made my windshild washer work.
It turned out to be a lot more work that anticipated, but the cowl really needed a good cleaning out. Now all hoses are new, and the washer works just fine |
04-07-2018, 06:47 PM | #6543 |
So I cruised down to my NAPA store this morn and bought a tube of Permatex Gear Oil sealer to fix a nuisance leak on the differential cover. Back home and jacked the old girl up, removed the old cover, cleaned every thing up,stuck a shop towel in the housing to keep the gear lube from seeping out while I applied the sealer and gasket. Applied the sealer to the housing cover and proceeded to install the bolts. I was on the fifth bolt when I realized I forgot to take the shop towel out! I had to remove the cover, gasket and clean up the big mess. I don't have pics cause I had sealer all over everything and couldn't touch my I phone. I'll try again tomorrow after I get more sealer. This could have been a catastrophe if the dim light in my brain hadn't come on. That's what I did to my truck today.
04-07-2018, 07:05 PM | #6544 |
Good thing the bulb lit before you went for a drive! It would've been much more work after that.
Anyway: Work done today, hasn't to be done tomorrow. I always think that, when getting in from the garage after a partiqularly bad day |
04-07-2018, 07:11 PM | #6545 |
Went with my neighbor/friend to get a 70 long bed for parts.Borrowed 2 wheel dolly to tow 6 miles. When we got there found the ring gear carrier in bed.Had to put on dolly backwards.Thank good ness no motor or trans so it wasent too bad.
'71 Cheyenne Super LWB - Second Owner in 39 Years! '70 CST/10 SWB - Soon to be Daughter's truck when finished |
04-07-2018, 08:00 PM | #6546 |
Old member
Ramp truck got a aux set of batteries installed and charge off the truck battery. I also installed a 3 gallon air tank with compressor for road side assistance if needed.
I think Ill buy a small box to cover the batteries and store some rigging stuff also. I have the tilt column working on it also. I found out today the bowl on the tilt is aluminum . I used plumbers putty to fill up the holes. I'll give it a couple of days to harden and see how it does sanding it. I came up with a easy way to keep the bowl from moving also. I took the 2 screws that hold the neutral safety switch and placed longer screws in to hold it in place.
04-07-2018, 09:22 PM | #6547 |
Washed it then it rained
04-07-2018, 09:53 PM | #6548 |
Cleaning
04-08-2018, 11:06 AM | #6549 |
Where's my beer?
Installed new back up lights that have been sitting on the shelf for years. I rarely drive it at night, so it's not been a big issue. Unfortunately the right side is not working, so I need to investigate.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
04-08-2018, 06:56 PM | #6550 |
I haven't had backup lights on my truck since I bought it. It's not too big of a deal. But, those ditches tend to jump out at me when backing out of the driveway.
1969 GMC 2500. 250 I6, 4-speed w/ granny low |
