![]() Join Date: Oct 2013
Re: Knomadd '71 SWB C-10
Now that's good progress!
- Robbie UNITED BY TRUCKS - classic truck video content YouTube: www.youtube.com/c/unitedbytrucks Instagram: @united_by_trucks Paw Paw '68 508 Dark Blue Custom C10 Teddy '68 GMC SWB 503 Light Green LS Build Mississippi Mud '75 Skyline Blue Patina SBC Build |
Thanks! It's a little slower than I'd like, but I'll get it done soon enough.
I have the VHX gauges installed into the bezel.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) Last edited by knomadd; 07-14-2017 at 10:54 AM. |
![]() Join Date: Dec 2012
Very sharp!!
__________________ Mike 70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804 Instagram- protouring66 |
#4 | |
Thanks! Not much to post, but something for my records I guess. I removed the engine stands after work yesterday to put them in the rear 6 cylinder position and decided to clean up all the muck while I was at it. Turns out there wasn't much paint left under the 40+ years of gunk. I then painted it with some rattle can satin black. ![]() ![]() There's still some crap in front of the cross member that will need to be cleaned up, as well as the frame rails, but this was the extent of what I got done. I'll need to clean the frame rails and put a coat of paint on before I re-mount the engine stands. Hopefully that's tonight's progress.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) Last edited by knomadd; 07-14-2017 at 10:56 AM. |
![]() Join Date: Oct 2012
Man I just got caught up your progress, everything is looking nice. I'll have to stay up this one.
![]() Join Date: Jul 2012
Love those gauges...DD VHX are a real nice set up.
Nice.
I will go by your house this weekend.
Rincon |
#8 | |
![]() Thanks Doug, I'm excited to see them up and running! Thanks Mike! We've got some things going on this weekend, so if the garage door isn't open, I'm probably not home. I'm hoping to get more done while I am home though, so stop by if you catch me outside.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
Tonight I was able to get the a/c unit out, plate off the firewall and some more wires out of the way.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) Last edited by knomadd; 07-14-2017 at 10:55 AM. |
![]() Join Date: Dec 2006
Nice Gauges!
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
Gotta love all the new part pictures! LS is looking like a beast!
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
updates??????????????????????????? lol
c10clubtexas
#13 | |
Thanks Keith!
Aaron, you've been updated more than anyone else. But yes, here's some from the weekend...Here's the floor I started with... ![]() Here's what I currently have... ![]() And what I will end up with... ![]() Still need to get the holes drilled and probably use something like riv-nuts to install it. Wondering what I should use for the sealant between the panels to keep the elements out. Maybe seam sealer on the bottom side? I also mounted up the Dirty Dingo LS low mount A/C bracket for the Sanden SD7 compressor. It fits pretty well. ![]() I test fit the motor (sorry no pics) and it was close. I'll have to move the engine stands back to the rear holes on the frame. I have the motor mounts as far forward as I can on the plates and the oil pan sits on top of the steering center-link. There's enough room from the firewall to the back of the heads to move another 2-3" comfortably, so I think it's the best option. Plus, the trans was sitting on the cross member (which I hadn't moved yet) so it was up too high, causing the front to sit low. All said and done, I at least know what I need to do now to make it fit, so that's good news.
#14 |
![]() Join Date: Apr 2005
I put Fatmat on my high hump, bolted it in. I then took strips of the Fatmat and put over the bolts and edge of the high hump sealing it to the floor. It created a good seal and shouldn't be that hard to remove if the need every arises. Hope that makes sense.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#15 |
Thanks Rob, it does make sense. I still have some of the eastwood mat I used everywhere else on the floor. I thought about using it and I will on the high hump itself, but I'm more worried about the dirt and moisture collecting between the high hump and the floor from under the truck. I don't want to cause rust to form by not attempting to seal it. I hope that makes sense.
#16 |
A guy with a truck
There was sealant applied there at the factory. Wouldn't hurt to run a bead
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC). |
#17 |
A guy with a truck
Looks much better! That lip on the front of the crossmember traps all kinds of filth
#18 |
I absolutely despise that front crossmember lip!! The hatred I have for it is immense lmao
#19 |
Yep, it was a pain to clean. Not my favorite thing to do.
Here is last nights progress... ![]() And tonight, I cleaned and painted the engine stands and new power steering pump so it won't rust. Not too exciting to look at so I didn't take a pic of that.
#20 |
Laid Back
![]() Join Date: Apr 2010
I always use the foam weatherstripping on the flange of the high humps to seal them up..
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
#21 |
Where do you get that from? I'm sure the hardware store stuff isn't quite the same, right?
#22 |
Well, I got the engine set in this weekend. It only took 4 tries to get the mounts right.
#23 | |
Coming along nicely!
#24 |
Still Learning
Looking good Duane! Keep up the good work.
#25 |
6>8 Plugless........
![]() Join Date: Sep 2007
That looks awesome!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
| Bookmarks |
