Old 10-03-2016, 09:06 PM   #1
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Knomadd '71 SWB C-10
Looks very nice! Good clearance all around?
I'd be leary of using foam weather strip on the high hump, as it will trap water. Just grab a tube of auto body seam sealer
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC).
gringoloco is offline   Reply With Quote
Old 10-04-2016, 09:34 AM   #2
knomadd
knomadd's Avatar
Thanks for all the compliments guys!
Yep, seems to have plenty. See for yourself
I'm using 45* EZ Clip fittings, in case anyone is wondering.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 10-04-2016, 08:33 AM   #3
Bennett68C10
Bennett68C10's Avatar
Very nice!
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 10-04-2016, 09:37 AM   #4
knomadd
knomadd's Avatar
I got my new PRC aluminum LS swap radiator yesterday. It has dual 16" Spal fans too. Love the one they did for my GTO, so I knew they'd do great for the 71. Took about 4 weeks to get it made and shipped. I can't wait to get it installed and the engine running!!
Not sure if I'll leave it plain or paint it satin black. Thinking black, since I really don't have anything polished in the engine compartment, but it sure looks good as is.
-Duane
Old 10-04-2016, 12:03 PM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
DD compressor mount? Which compressor model? Looks like it fits great!
-Chris
Old 10-04-2016, 11:59 PM   #6
knomadd
knomadd's Avatar
Yes sir! It's a Sanden SD7B10 compressor.
-Duane
Old 10-06-2016, 09:51 AM   #7
knomadd
knomadd's Avatar
Damn, there are a lot of wires for these engines!
-Duane
Old 10-06-2016, 02:21 PM   #8
gringoloco
A guy with a truck
gringoloco's Avatar
Mmmm... spaghetti
-Chris
Old 10-07-2016, 08:14 AM   #9
Bennett68C10
have fun with that!
Keith
66 Suburban
IG: bennett68c10
Old 10-10-2016, 10:44 AM   #10
knomadd
knomadd's Avatar
Hahaha, my thoughts exactly! Thanks guys!!
Well, I moved on from the wiring, figuring I'd have better luck sorting through it with the engine/trans out of the truck.
This weekend I started on fixing the firewall. Was pulling a dent I found when the stud pulled the sheet metal apart. Ground off the paint and bedliner/undercoating crap to find some pinholes. Cut it out and made a patch, which lead to blow outs. I hate thin sheet metal and rust!!!
Well, I ended up with this.
And got it all finished up here
I guess GM never meant for these panels to be flat, so the entire blower motor area is low, which is why the welds still show up. I didn't want to grind through any metal, so I'll have to try and work the steel as best I can. Thankfully I'll be making a panel to cover most of this anyway. Heck, it might have been easier to replace the full face of the firewall in this area, maybe even this section of the cowl too.
-Duane
Old 10-10-2016, 11:18 AM   #11
mcbassin
Still Learning
mcbassin's Avatar
Nice work on the firewall repair and filler. Do you have a plan for the other openings? I know I made the mistake of cutting the whole section out and cutting a one piece filler plate. (HERE) Not a good idea in my opinion. On my next one, I will leave the rolled edges and just make two filler pieces. I had a ton of oil canning issues with the one piece. I've seen the ones made by porterbuilt, they should be better because it has a rolled edge.
I hate repairing the rust in this area. It can be a real pain to get rid of it all.
good luck!
mcbassin is offline   Reply With Quote
Old 10-10-2016, 12:51 PM   #12
knomadd
knomadd's Avatar
good luck!
Thanks Mike. Yeah, I plan on leaving everything the way it is and just making patches for the two large openings, and maybe some small round ones for the bigger holes near it. I want to try and get the Vintage Air brackets figured out first, since I want to get rid of the bolts on the engine side of the firewall. The openings will make it easier to get to both sides with a copper spoon for welding holes shut. I appreciate you sharing your experience though. I'm sure you may have saved me a headache or three if I decided to cut it out later.
-Duane
Old 10-10-2016, 03:50 PM   #13
RRR18
RRR18's Avatar
Location: The Yo, OH->Tuc, AZ->The Yo, OH->Wentzville, MO
Damn that's a lot of wire. It'll be worth all the pain though.
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 10-31-2016, 10:07 AM   #14
knomadd
knomadd's Avatar
Re: Knomadd '71 SWB C-10 "Brutus" 6.0L 6l90e swap
You got that right!
-Duane
Old 10-31-2016, 10:08 AM   #15
knomadd
knomadd's Avatar
uh oh....
-Duane
Old 10-31-2016, 10:15 AM   #16
knomadd
knomadd's Avatar
It's been a while, so it's time for an update. I've been tackling the firewall when I can (so it's slow going), but progress has been made. Here's what I have so far.
I got all the small holes welded in, then I did the drivers side a/c & heater hole...
Filled in the large round hole and final a/c & heater hole. I also started the passenger side firewall radius to match the drivers side.
And on Sunday, I used a scrap piece of 12"x12" wood with a rounded corner to hammer the rolled edge to a better (smoother) form.
-Duane
Old 10-31-2016, 11:10 AM   #17
mcbassin
Still Learning
mcbassin's Avatar
Very nice work on the firewall Duane!
Old 10-31-2016, 04:18 PM   #18
rincones
rincones's Avatar
Looking Good Duane.
Rincon
rincones is offline   Reply With Quote
Old 11-02-2016, 04:39 PM   #19
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
nice work and good use of that wood to get your rounded shoulder!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-05-2016, 02:09 PM   #20
Vic1947
Vic1947's Avatar
Looks nice, Duane. Years ago I had a buddy that would say, "Auto parts by Homer Formby!" when we used wood to make stuff for our hotrods.
Victor
57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX
Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany
Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown
Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas
Vic1947 is offline   Reply With Quote
Old 11-06-2016, 12:28 PM   #21
knomadd
knomadd's Avatar
Thanks guys!
A little more progress this weekend. I got the filler welded in and started on the wire gutter cap.
-Duane
Old 11-06-2016, 06:15 PM   #22
Advanced Design
Advanced Design's Avatar
Nice work on the firewall and gutter....going to look good when done!
Advanced Design is offline   Reply With Quote
Old 11-09-2016, 05:26 PM   #23
Dieselwrencher
Sweet work on the gutter! After I saw a cab done up like that I really wished I would have done mine that way. They look so clean and sleek IMO!
Ryan
Old 11-10-2016, 10:37 AM   #24
MMcMasters
MMcMasters's Avatar
Very nice work on the firewall!
Mike
70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804
Instagram- protouring66
MMcMasters is offline   Reply With Quote
Old 11-11-2016, 10:10 AM   #25
mcbassin
Still Learning
mcbassin's Avatar
Nice work on the firewall Duane.
