02-10-2015, 10:40 PM | #701 | |
Re: Project: Shiro
02-10-2015, 11:47 PM | #702 |
A day late and $1 short...
Re: Project: Shiro
I don't like the factory side vents, I'll use smaller vintage air vents similar the ones I used on the green stepper.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
02-10-2015, 11:49 PM | #703 |
Re: Project: Shiro
Why don't you like the factory side vents? Too bulky?
02-10-2015, 11:59 PM | #704 |
Re: Project: Shiro
Exactly, the Vintage Air and Billet Specialties vents are smaller and blend very well with the factory styling in my opinion.
02-11-2015, 07:25 AM | #705 | |
Re: Project: Shiro
02-11-2015, 11:12 AM | #706 |
Re: Project: Shiro
I don't know about it being a good reason but it makes sense in my OCD soaked brain.
02-17-2015, 11:03 PM | #708 |
Re: Project: Shiro
OKay... silly question time. I have the cab back on the frame and torqued down and I want to make sure I have a handle on this sheet metal repair process. I'm going to leave the doors on for the moment and start by drilling out the spot rivets in the outer rocker. Once they are out of the way I will remove the inner rocker and however much of the floor I want to replace as well as the lower portion of the kick panels. Once I am to this point I just fit my panels to what I have cut out and work it in reverse order. I know this is a simplistic view, but it will help bring out any special advice any of you may have. So what do you think, am I on the right track. I hope I can muster the testicular fortitude to knock this out myself, if not maybe I give the guys at Nsane Hot Rodz a call!
02-17-2015, 11:46 PM | #709 |
Re: Project: Shiro
Buck here are some pictures from my first cab I did. Measure, measure, measure
Scott |
02-17-2015, 11:51 PM | #710 |
Re: Project: Shiro
Sorry about the individual pictures, I'm on my phone.
Scott Last edited by sduckworth13; 02-17-2015 at 11:59 PM. |
02-17-2015, 11:53 PM | #711 |
Re: Project: Shiro
Welded in.
Scott |
02-17-2015, 11:57 PM | #712 |
Re: Project: Shiro
Make sure you measure from the floor to the lip of the inner rocker where the outer rocker sits in. Then weld your inner rocker in, then your kick panel, then the lower door pillar then your outer rocker. Buck, I probably test fit my door 50x before I got the gap of the outer rocker where I wanted it before I finally welded it in.
Scott Last edited by sduckworth13; 02-18-2015 at 12:08 AM. |
02-17-2015, 11:59 PM | #713 |
Re: Project: Shiro
Here is the final pic.
Scott |
02-18-2015, 07:51 AM | #714 |
Re: Project: Shiro
Thanks for the visuals Scott!
02-18-2015, 09:30 AM | #715 |
Re: Project: Shiro
So there you go, I expect one side to be done by the weekend.....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-18-2015, 10:34 AM | #716 | |
Re: Project: Shiro
The one thing I just though about was the cab corner, where does that fit in the timeline? It looks like it tucks under the aft end of the outer rocker so I'm guessing it can be laid out and cut anytime after the outer rocker and go back in after the inner rocker is installed?
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD Last edited by C10_ustacould; 02-18-2015 at 11:02 AM. Reason: poor grammar |
02-18-2015, 10:47 AM | #717 |
Re: Project: Shiro
Good luck Buck, your welds looked great on the firewall panel so I think your way ahead of the curve and won't have any issues. Just measure a lot and you'll be good. I'm about to start tearing into my new cab and will probably be doing similar repairs again. I won't know anything till I get the outer rocker off, its pretty cold here so I'm going to put it off until it warms up enough to open the garage doors.
Scott |
02-18-2015, 10:14 PM | #718 |
Re: Project: Shiro
Been going back through and reading your build, Buck. You're making killer progress! I am a bit confused on one thing: did you decide to switch to bags or keep the coilovers? I'm sure I missed it but thought I'd just ask.
- Robbie UNITED BY TRUCKS - classic truck video content YouTube: www.youtube.com/c/unitedbytrucks Instagram: @united_by_trucks Paw Paw '68 508 Dark Blue Custom C10 Teddy '68 GMC SWB 503 Light Green LS Build Mississippi Mud '75 Skyline Blue Patina SBC Build |
02-27-2015, 11:02 AM | #719 | |
Re: Project: Shiro
Ordered ebfabman's sheet metal repair videos to aid in the rust repair effort. Hopefully the rust repair goes well and I can get it blown apart for paint and powdercoat soon.
03-01-2015, 11:06 PM | #720 |
Re: Project: Shiro
Fooled around in the shop this afternoon...
Actually started the other day, I wanted to see what was lurking behind the cab corners so I cut a hole in the driver's side and pulled out a bunch of what I guess is seam sealer and a hairball. Yuk! Then I wanted to see how the spot weld bit worked... Worked too well on the top one! Then I figured I would cut a hole in the rocker and take a look and see how much of the inner rocker was corroded... The area where the outer laps over the inner rocker was pretty corroded and the seal retailer lip was rotted away, so why not remove that too, right? A lot of light coming through there. After drilling out a bunch of spot welds the outer rocker is off! Not sure at this point if I am going to change the inner rocker or just patch it. We'll have to wait and see.
03-01-2015, 11:15 PM | #721 |
Re: Project: Shiro
One spot that has me freaking out is the lower pillar, its pretty hammered.
This thing is swiss cheese... ... more cheese I was trying to abracadabra this thing on there but none of the spells I knew worked , I guess I'll have to do it with actual work.
03-02-2015, 12:15 AM | #722 |
Re: Project: Shiro
Buck trade out that door pillar for a Tabco. You'll be surprised at how well it fits.
Scott |
03-02-2015, 12:16 AM | #723 |
Re: Project: Shiro
You can make that work, it will take a little bit of work though.
Scott |
03-02-2015, 12:41 AM | #724 |
Re: Project: Shiro
Who sells tabco pieces?
03-02-2015, 12:48 AM | #725 |
Re: Project: Shiro
Here is a link to there website. https://tabcoparts.com
I couldn't get the online order to go through so I just called them. The online order system is new so it probably needs the kinks worked out.
Scott |
