Old 12-23-2006, 12:17 PM   #51
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Re: Help With Motor Issue...
Hey Grinch,
I'm sorry for sounding short. We can help this guy out together. I should be the one called GRINCH today. I'm just in a mood as this is the first Christmas in 7 years my family and I are spending away from my mom who misses her Grandchildren more than anything. Happy Holidays Buddy.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 12-23-2006, 12:25 PM   #52
grinch4om
dang its hot
grinch4om's Avatar
Austria? Good Lord! I understand, I have been away from my home in Maine since 1978. This is the first Christmas I will not be with my grandchildren in Illinois but God is good and he is with me and you! I pray for them all the time. And I'll say one for you and your Mom. Peace bro
grinch4om is offline   Reply With Quote
Old 12-23-2006, 12:28 PM   #53
Bishops Trucks
KEEP ON TRUCKIN'
Thank's, and I'll do the same for you.
JIM
Old 12-23-2006, 07:12 PM   #54
HotRod73
HotRod73's Avatar
took all plugs out and put the compression tester in 6 and it sounded like i could hear air coming form somewhere like woosh woosh woosh as motor turned over.... only that cylinder really does it 4 may too i dont know...
1973 Chevrolet C20 (Under Construction)
HotRod73 is offline   Reply With Quote
Old 12-23-2006, 07:45 PM   #55
grinch4om
dang its hot
grinch4om's Avatar
refer to post #44, determine where air is escaping.
Old 12-23-2006, 08:09 PM   #56
AesC10s
Chevy truck addict
AesC10s's Avatar
Like said many times, im sure you have a blown head gasket. sounds like you have a blown head gasket between 4 and 6. id just pull the head and check it out.
AesC10s is offline   Reply With Quote
Old 12-23-2006, 09:52 PM   #57
79Silv4x4
Workaholic
79Silv4x4's Avatar
I'm no help but I've never seen a thread where the OP replies to his reply so many times in a row. Get a new motor is my thought
79Silv4x4 is offline   Reply With Quote
Old 12-24-2006, 04:16 AM   #58
j hannah
comfortably numb
j hannah's Avatar
Hey, Hot Rod, I have a 74 gmc 3/4 ton, 350. 53,000 origional miles. Ive had alot of chevys through the years. I think these guys are right on with the head gasket. especially if its never been apart before. the factory head gaskets are tin,they tend to blow out between the cyls. I would pull the heads,have them magnafluxed(checked for cracks),and rebuilt. While the heads are off, look at the pistons and cyl.walls,especially 4,and 6. if they arent scored,install the rebuilt heads and you should be good to go. where are you in okla., Im at schulter, about 50 MI south of tulsa.
1974 gmc 3/4 t. c/s
1974 chevy k-10
1973 pontiac grandville(turnpike cruiser)
j hannah is offline   Reply With Quote
Old 12-24-2006, 05:40 PM   #59
HotRod73
HotRod73's Avatar
im in norman...you got any parts or trucks for sale????
Old 12-24-2006, 05:51 PM   #60
kenm78
Broken Down
kenm78's Avatar
Just like (grinch4om) said do a cylinder leakage test... bring your number 4 or 6 up to TDC on the compression stroke remove both #4 and #6 spark plugs add 90-100 PSI through your spark plug hole on cylinder you chose and listen if air escapes through the carburator its a bad intake valve, thourgh the exhuast bad exhuast valve, though the oil fill or pvc bad rings, or if air escapes from sister cylinder you deffently know its the small portion of head gasket between the two that has gone bad. Good luck and I hope you don't spend a arm and leg on repairs.. Merry XMAS
kenm78
1982 Chevy 4X4
Project truck
“It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt”
kenm78 is offline   Reply With Quote
Old 12-24-2006, 06:30 PM   #61
84slopwaggin
84slopwaggin's Avatar
I've often heard that when you install rebuilt heads on a blocks that has alot of miles it often leads to increased oil use, blow by, etc. My opinion just replace the head gasket until you can get a overhaul done.
84slopwaggin is offline   Reply With Quote
Old 12-24-2006, 10:17 PM   #62
HotRod73
HotRod73's Avatar
well i started it... went out and did what i could, i almost got the intake off 4 more bolts left then i will pull head and see whats hidden underneath
Old 12-24-2006, 10:40 PM   #63
HotRod73
HotRod73's Avatar
INTERESTING... i was able to read the castings on the block easily... 3970014... it says 70-76 350 with a 2 or 4 bolt main, i asked the guy i got it from and he said its from another truck and it is a 4 bolt main... is that good?
Old 12-24-2006, 10:49 PM   #64
AesC10s
Chevy truck addict
AesC10s's Avatar
4 Bolt mains are very good. good block to built a high horse motor out of. Very strong block.
Old 12-24-2006, 10:53 PM   #65
HotRod73
HotRod73's Avatar
AwEsOmE!!! It say's 70-76 my truck is a 78 and it has H.E.I.... When did this come out? I want to know the year but its not that bigga deal... If i order 78 chevy c10 parts for a 350 would they still fit even though mine is a 70-76 motor??? by the vin it says came with a 305... also its a bonanza what is that???
Old 12-25-2006, 06:33 PM   #66
HotRod73
HotRod73's Avatar
intake is off, i am starting to think that when its time to REASSEMBLE its going to be a hassle and hard to do... is it???
Old 12-25-2006, 07:39 PM   #67
magnethead
7000 #'s of american IRON
magnethead's Avatar
if you clean the mating surfaces, it shouldn't be too hard
IF you have a boat anchor intake, disregard that statement and get a hoist/a-frame/crane....
magnethead is offline   Reply With Quote
