Old 12-13-2006, 11:29 PM   #1
HotRod73
HotRod73's Avatar
Help With Motor Issue...
just bought a 78' bonanza (what is a bonanza?) and it has a 350/350..
Engine starts up but seems to idle rough, when you put it into gear it kinda shakes the whole truck when you give it gas taking off, it seems slugish too, doesnt seem to have much power... what could be the problem???
HotRod73 is offline   Reply With Quote
Old 12-14-2006, 12:39 AM   #2
HotRod73
HotRod73's Avatar
Re: Help With Motor Issue...
compression on 4 and 6 are lower than the others
Old 12-14-2006, 12:51 AM   #3
JrRacer
Blown head gasket and fire slotted between 4 and 6
84 GMC LONGBED
84 CHEVY LONGBED
03 CHEVY 1500HD 4X4 CREW CAB
JrRacer is offline   Reply With Quote
Old 12-14-2006, 01:01 AM   #4
HotRod73
HotRod73's Avatar
but the oil doesnt look milky or anything and the antifreeze doesn't look like it has oil in it...it does however smoke a little when i step on the gas... i cant tell if its white or blue.... could it still be a blown head gasket???
Old 12-14-2006, 01:19 AM   #5
JrRacer
yes head gasket may be blown between the cylinders and not into the coolant passage
84 GMC LONGBED
84 CHEVY LONGBED
Old 12-14-2006, 01:22 AM   #6
Russell
Professional Grade
Russell's Avatar
Also check your timing, and make sure your valves are adjusted correctly
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 12-15-2006, 11:29 AM   #7
HotRod73
HotRod73's Avatar
idles rough and when put into gear shakes the truck and acts like doesnt wanna go, i changed plugs that is all... so it COULD be a bad head gasket even tho oil and coolant are clean? its 4 and 6 that has the low compression.. would it most likely be this or timing issue?
Old 12-15-2006, 11:31 AM   #8
piecesparts
Parts and more parts
piecesparts's Avatar
Possible cam problem, lobes wore down. Or carbon on the valves.
piecesparts is offline   Reply With Quote
Old 12-15-2006, 01:09 PM   #9
motopatzo
motopatzo's Avatar
If compression is down on 4 and 6 the head gasket would be the first place where I would look also. That is causing the shaking and no power. Because the compression is down on cylinders beside each other, that is why I would tend to beleive it is the head gasket also.
motopatzo is offline   Reply With Quote
Old 12-15-2006, 07:51 PM   #10
HotRod73
HotRod73's Avatar
i checked the passenger side valves and they were all moving fine and pumping oil... didnt get driver side valve cover off which is where the low compression is to see if all the rocker arms on moving on that side... i was told it was most likely the head gasket blown.... and im starting to think that..
Old 12-15-2006, 07:52 PM   #11
HotRod73
HotRod73's Avatar
bad cam wouldn't cause 4 and 6 to be low and have no power and shaking would it?
Old 12-15-2006, 09:17 PM   #12
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
you bet.ive stuck a lot camshafts in old 350 and 305 motors
powerdriver 1958 is offline   Reply With Quote
Old 12-15-2006, 10:38 PM   #13
HotRod73
HotRod73's Avatar
how do i tell if the cam is bad and how would i tell if its the head gasket? is there a way to test before i rip into it and spend money????
Old 12-15-2006, 10:44 PM   #14
HotRod73
HotRod73's Avatar
when i take my air cleaner off, and nail the gas and let off it makes a little pop doesnt that mean bad cam??
Old 12-15-2006, 10:45 PM   #15
HotRod73
HotRod73's Avatar
throught the carb it makes a pop or could it be somethin else
Old 12-16-2006, 08:37 AM   #16
hiway
Mad Scientist
Bad exhaust lobe will backfire thru the carb. What's your compression readings?
Everythang relates to Beer!
86 1/2ton on tons! sbc/465/208/D60/14/35's
81 Postal....with 468 bbc
97 Merc Marq comuter
07 Suburban
02 Danger Ranger
hiway is offline   Reply With Quote
Old 12-16-2006, 10:21 AM   #17
HotRod73
HotRod73's Avatar
i dont know but it was checked and 4 and 6 are low and also my complete exhaust is rusted out, this matter?
it makes a little pop in the carb when i gun it and let off
Old 12-22-2006, 11:22 PM   #18
HotRod73
HotRod73's Avatar
i did compression check today, all my clinders are hitting 90-120 except two that are right next to each other the two middle cylinders on the passenger side they go to like 5 thats all..... so does this sound like head gasket? i pulled the valve cover and my rockers are moving so i know the cam is working, what else could be the problem? a cracked head???
Old 12-22-2006, 11:24 PM   #19
HotRod73
HotRod73's Avatar
im guessing the low ones are 4 and 6 i dont know how to tell the cylinder number but the two next to each other in the middle on passenger side thats low ones 90-120 for the rest, is that good???
Old 12-22-2006, 11:28 PM   #20
sick69
sick69's Avatar
cracked head is possible but I would believe the head gasket is toast. either way the head has to come off to find out
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 12-22-2006, 11:30 PM   #21
sick69
sick69's Avatar
from front to back.....
passenger side= 2 4 6 8
driver side = 1 3 5 7
70 chevy lwb c10
Old 12-22-2006, 11:30 PM   #22
HotRod73
HotRod73's Avatar
doesnt my motor have to overheat in order to blow my head gasket? it doesnt over heat and there is no water/coolant in my oil... just thought if gasket was bad it would over heat or would have to overheat to blow it in first place but it doesnt over heat...
Old 12-22-2006, 11:31 PM   #23
HotRod73
HotRod73's Avatar
so yes 4 and 6 are the ones with bad compression is 90-120 on the rest good or is that low???
Old 12-22-2006, 11:33 PM   #24
7387chevys
drivers side radiator to firewall 1-3-5-7 pass side radiator to firewall 2-4-6-8
Shane
http://boxwrench.net/specs/chevy_sb.htm
7387chevys is offline   Reply With Quote
Old 12-22-2006, 11:33 PM   #25
HotRod73
HotRod73's Avatar
my plugs looked black smelled like gas but looked kinda like oil... i just changed them about 5 miles ago... does that mean anything? really only on the side with low compression
