05-04-2007, 05:08 PM | #51 |
Re: Shock Relocation
You need a spacer & you need the proper 'shock' washers. Shock washers are the same O.D. as the bushing & are cupped similarly.
05-04-2007, 05:56 PM | #52 | |
Grand PooBaa Member
When I nistalled the shock, the holding wire came lose, and the shocks extended, so after mounting the top of the shock, I had to force the bottom of the shock with a jack to get it up to mount the screw in the shock hole. Just a thought if thats the cause of my problems. |
05-04-2007, 07:09 PM | #53 |
67-72 Addict!
VDOG, I feel for ya having to go thru all this BS just to get your shocks installed!. I hope you get it all worked out soon.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
05-04-2007, 07:19 PM | #54 |
someday it will be done!
jeez sorry to hear of your troubles.
I'm really starting to think that CPP is a good company to avoid buying from.First with the tubular control arms and now this. Really hope you get it figured out soon.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
05-04-2007, 07:54 PM | #55 |
Grand PooBaa Member
Thanks 70C10, I will get back to work on the truck tomorrow and I will have a few more pictures to post. Plan on reinstalling the shocks and changing axles tomorrow.
05-04-2007, 07:55 PM | #56 |
Grand PooBaa Member
Rollie tell me about the tubular control arms, I did not hear who had the problem?
05-04-2007, 08:55 PM | #57 |
All gas shocks are a pain to install. The trick is to compress them farther than necessary & then as they extend back to full length, stab them in the hole (or on the stud.... some really high pressure gas shocks are worse than others).
Vdog, there should be a spacer that's roughly .50 ~.75" thick between the shock grommet & the lower shock bracket . It should be pretty big too diameter wise. In the diagram 71tahoe posted, it looks like the spacer you're talking about is the shock grommets 'sleeve'. If you don't have an actual spacer, use a nut w/a large washer. I had to space my lower shock eye over & used the nut/washer combo. I can get some pics tomorrow if there's confusion.
05-04-2007, 08:58 PM | #58 |
The problem is that apparently only select upper ball joints seem to fit w/o modifications.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-04-2007 at 08:58 PM. |
05-05-2007, 02:03 AM | #59 |
^ what he said.I don't recall the name of the fella but there is a thread about it in the suspension forum.
05-05-2007, 05:41 PM | #60 |
1969 Short, Fleet, and Beat
Hey guys, this one has me scratching my head. We dropped my buddies 72 SWB Super Chayenne and we did not use the shock relocation kit. All we did was put in 4" dropped coils and the 4" drop shock (same brand as he is useing duestech? pardon the spelling) and we had no alignment problem with the shocks or the axle. We used the stock panhard bar.
I am starting to think if these extra parts are even needed? huero. |
05-05-2007, 06:20 PM | #61 | |
05-07-2007, 12:52 PM | #62 | |
Grand PooBaa Member
Did not get a chance to work on my truck this weekend. Probably today I will get started. |
05-07-2007, 01:26 PM | #63 |
the problem is not the bushing moving, as you can tell from the picture it is perpindicular to the mount. your problem is the shock is not is not mounted on the lower mount in line with the top mount. as stated before you need to space out the bottom of the shock to match the top using a lower mounting stud or nut and washer to get the right affect.
05-07-2007, 01:27 PM | #64 |
The relocation kits do relocate the shocks - it repositions the shock at a more upright angle, allowing the shock to work as it was designed. I noticed a much improved ride after installing the kit on my truck which has a 4" rear drop. As the truck is lowered, the angle of the rear shocks moves more toward horizontal. This causes the shock to not move thru it's stroke as much, and thus is not able to dampen as it should.
Rudy Fierros '95 Honda VFR750F Used to have a '71 Chevy Stepside, Guards Red, Lowered 4" rear, 3" front, White Oak bed wood, 700R4 w/373 gears until some low life stole it! |
05-07-2007, 01:44 PM | #65 |
Have you gotten the issue resolved yet? I feel for you, I just put the 5" drop kit from ECE in and it went pretty quick and simple. But I know from past projects how one little issue can turn into a huge headache of issues. Hope you've figured it out.
1971 Chevy C-10-sold 1969 GMC 4x4-sold 1997 Chevy Z71 2003 Grand Prix |
05-07-2007, 08:29 PM | #66 | |
Grand PooBaa Member
Weekend was shot to heck and could not get anything done. Will post pictures of progess tomorrow. |
06-01-2007, 09:33 AM | #67 |
If you haven't found anything yet, this may work. At least give better geometry than what you have and it's made sturdy enough for coilovers.
Speedway Motors http://www.speedwaymotors.com 91636010-PLN Aluminum Coilover Mount Support, Plain $10.95 EA Last edited by 71tahoe; 06-01-2007 at 09:34 AM. |
06-10-2007, 12:28 AM | #68 | |
Grand PooBaa Member
How do you align or center the rearend?
